Nicholas moore
- 5
I'm working on a project which will involve placing a superluminescent diode in a rocket, which will get launched in desert (obviously the SLD is just part of a greater system, the objective is not the operation of an SLD)
What I need to know is if you think I could make, or where I can track down and buy, a small driver and temperature control unit to avoid all the different kinds of impending threats to an SLD.
Typically these devices for powering and monitoring the SLD are large, because the SLD is used in a lab setting, because preserving SLD lifetime is an important design parameter, and because stability of the driver impacts lab measurements; so in your answer keep in mind that the driver stability only needs to be good enough and that the SLD only needs to last through a couple dozen tests until the summer when the rocket gets launched.
Optimistic, and perhaps naive,
Thank you,
-N
Thank you,
-N
