Explain the Schrodinger equation
The discussion focuses on the request for a simple explanation of the Schrödinger equation in quantum mechanics, specifically regarding its components like the Laplace operator and wave function. Participants emphasize the importance of demonstrating prior knowledge and effort in understanding the topic before receiving help. The equation itself describes how the quantum state of a physical system changes over time, with the Hamiltonian operator representing the total energy of the system. There is a clear need for foundational knowledge in calculus and differential equations to fully grasp the concepts involved. Overall, the conversation highlights the complexity of the Schrödinger equation and the prerequisite understanding required for meaningful assistance.
Huzaifa
Please explain in simple words, the meaning of the Schrodinger wave equation in the quantum mechanics model of atom.
$$\frac{\partial^{2} \psi}{\partial x^{2}}+\frac{\partial^{2} \psi}{\partial y^{2}}+\frac{\partial^{2} \psi}{\partial z^{2}}+\frac{8 \pi^{2} m}{h^{2}}(E-U) \psi=0$$
Please explain in simple words, the meaning of the Schrodinger wave equation in the quantum mechanics model of atom. $$\frac{\partial^{2} \psi}{\partial x^{2}}+\frac{\partial^{2} \psi}{\partial y^{2}}+\frac{\partial^{2} \psi}{\partial z^{2}}+\frac{8 \pi^{2} m}{h^{2}}(E-U) \psi=0$$
Welcome to PF. :smile:
We require that you show some effort on your schoolwork questions before we can offer tutorial help. What reading have you been doing about SE? What have you learned so far? What class is this for?
https://en.wikipedia.org/wiki/Schrödinger_equation
\nabla ^{2}\psi +\frac{8 \pi^{2} m}{h^{2}}(E-U) \psi=0
I am not able to understand the Laplace operator and the wave function. I do not have the knowledge of
differential equations. In the time-independent Schrödinger equation for Hydrogen atom, HΨ = EΨ, where H is Hamiltonian operator.
Please explain Laplace operator Hamiltonian operator and wave function without differential equations. Thank you.
You haven't answered the questions asked of you by @berkeman in Post#2 yet! And you haven't told us what you do understand - for example if you are familiar with basic calculus.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
