whatisreality
- 290
- 1
Show that any geodesic with constant ##\theta## lies on the equator of a sphere, with the north pole being on the ##\theta = 0## line. Hence explain why all geodesics on a sphere will be arcs of a great circle.
I've had a go at it, but I'm wondering if my reasoning on the second part is correct.
Previously in the question I showed that ##\frac{d^2\theta}{d\sigma^2} = k^2 \frac{cos(\theta)}{sin^3{\theta}}##. For constant theta, ##\frac{d^2\theta}{d\sigma^2} = 0## so we require ##cos(\theta)=0##, and therefore that ##\theta = \frac{m\pi}{2} \pm m\pi##. If I take ##\theta## to be measured from the north pole, then for any ##m## the solution will lie on the equator.
Great circles are circles formed by the intersection of a plane containing the center of the sphere with the sphere itself. A plane through the centre of the sphere which also intersects with all points on the equator is a great circle. And the geodesics with ##\theta = \frac{m\pi}{2} \pm m\pi## are arcs of this circle.
Here's where it gets a bit sketchy... my thoughts are that the axes are defined arbitrarily. I could do some sort of co-ordinate transformation and repeat the calculation, with the same result, that geodesics on the new equator are arcs of a great circle. The equator would have moved, but there's nothing special about where the equator is. The above reasoning will still hold whatever direction I point the axes in, as long as the origin is the centre of the sphere. That means that whatever great circle I choose, the geodesics will be arcs of it. Because they might be arcs of constant theta in the new co-ordinate systems, but transforming back to the original system they'd be geodesics that don't necessarily have constant theta.
I'm really unsure about this and I'm not explaining it well at all. Is that reasoning correct or wildly wrong? Any help is very much appreciated, thank you!
