Explain why long wave radio does not cut out in tunnel.
In summary, the conversation discusses why a car tuned to FM radio experiences cut-outs when entering a tunnel, while a car tuned to long wave reception does not. The answer involves diffraction and interference, with the longer wavelength of long wave signals causing less interference when passing through the tunnel. However, the exact explanation may be more complex depending on the specific materials and conditions of the tunnel.
bsmm11
Explain why if your car is tuned to FM, it cuts out when you enter a tunnel but doesn’t if you are tuned to long wave reception.
(λ of FM: 3m, λ of long wave: 1500m)
Well, what I think is that..
As the λ of the long wave is much longer than the width of the entrance of the tunnel, there will be diffraction when the wave goes into the tunnel. Diffraction will cause destructive interference, and depending on the car's position there will be cut-out.
Therefore, I think FM should be the one with no cut out in the tunnel (which is of course contrary to my personal experience).
Please enlighten me. :shy:
The situation for radio in tunnels is actually quite complex
http://www.thenakedscientists.com/forum/index.php?topic=34178.0
http://ask.metafilter.com/15693/Radios-in-tunnels
- so the question is actually about the most recent topic in your course. If that is diffraction and interference, then you are likely giving the correct answer.
However: for diffraction through an aperture, you need the opening to be smaller than the wavelength - which is what you have in both cases. So it is probably not quite right.
http://ngsir.netfirms.com/englishhtm/Diffraction.htm
... has a widget to investigate slit-width vs wavelength in diffraction.
Also - when you drive through the tunnel, do you get a radio signal fading in and out or is it just gone? (If it goes at all.)
You can also think about what the tunnels are made out of and how the different wavelength radiowaves behave with those ematerials.
Related to Explain why long wave radio does not cut out in tunnel.
1. Why does long wave radio not cut out in a tunnel?
Long wave radio signals have a lower frequency compared to other radio waves, which allows them to travel longer distances and penetrate through solid objects like tunnels. This means that the radio waves can still reach the receiver even when inside a tunnel.
2. Can other types of radio waves cut out in a tunnel?
Yes, other types of radio waves with higher frequencies, such as FM or AM radio, can experience signal loss or interference in tunnels due to their shorter wavelengths. This makes long wave radio more suitable for communication in areas with obstacles like tunnels.
3. How does the wavelength of radio waves affect their ability to travel through obstacles?
The longer the wavelength of a radio wave, the better it can travel through obstacles like tunnels. This is because longer wavelengths have lower frequencies, allowing them to diffract and bend around objects more easily compared to shorter wavelengths.
4. Is there a limit to the distance that long wave radio signals can travel?
Yes, like all radio waves, long wave radio signals can only travel a certain distance before losing their strength and becoming too weak to be detected by a receiver. This distance can vary depending on factors such as atmospheric conditions and the power of the transmitter.
5. Can other factors besides wavelength affect the ability of radio waves to travel through tunnels?
Yes, the strength of the radio transmitter and the sensitivity of the receiver can also play a role in the ability of radio waves to travel through tunnels. Additionally, the materials used to construct the tunnel, such as metals or concrete, can also impact the signal's strength and quality.
