Explain why this is correct (Optimization Problem)
In summary,The length and width of a rectangle are determined by the equation x=y. If y>x then y is the length. If x>y then x is the length... but it does not matter to the maths, we can focus on either.
IbrahimA
A piece of wire, 100 cm long, needs to be bent to form a rectangle. Determine the dimensions of a rectangle with the maximum area.
P = 2(l+w)
A = lw
This is what I don't understand, the solutions that I saw from looking around is:
l = x
w = (100 -2x) / 2
I don't understand why is width portrayed as shown above, and why the length is also potrayed as above, the solution goes onto:
A = (x)(100 - 2x / 2)
A = (x)(50 = x)
A = 50x - x^2
A prime = 50 - x^2
Insert 0 for A prime
0 = 50 - x^2
x=25
With therefore means the length and width are 25cm.
I understand the algebra, I do not understand how to get the length and width equation, wondering if someone could explain it to me.
P = 2(l+w)
A = lw
l = x
w = (100 -2x) / 2
The 100 cm of wire will be the perimeter of the rectangle. From your formula for P, solve for the width w in terms of l. Also, introducing x as a variable is more complicating than just using w and l.
A = (x)(50 = x)
The first equation above is not written correctly. The second group in parentheses is 100 - 2x/2, which is properly interpreted as ##100 - \frac {2x} 2= 100 - x##. Obviously that's not what you meant, so the equation should have been written as A = x(100 - 2x)/2.
The second equation has a typo -- you wrote = instead of -.
[IbrahimA said:
A = 50x - x^2
A prime = 50 - x^2
0 = 50 - x^2
x=25
Forget about the characteristic of length and width... a rectangle has two pairs of parallel sides... one pair has length x and the other has length y. Note the special case that x=y is allowed even though we said "rectangle".
At this stage the x and y aee just labels... the next step uses maths to describe how these are related to the area and the perimeter. If the area is A and the perimeter is p, write down the equations for these in terms of x and y.
You need an ewuation for area in terms of only one other variable... so pick x or y, doesn't matter which, and make A depend only on that.
Note. Your final working contains two errors which cancel each other out... check the derivative.
Related to Explain why this is correct (Optimization Problem)
1. What is an optimization problem?
An optimization problem is a mathematical problem that involves finding the best possible solution from a set of possible solutions, known as the "optimal" solution. It is used to maximize or minimize a certain objective function, subject to certain constraints.
2. Why is optimization important in science?
Optimization is important in science because it allows scientists to find the most efficient and effective solutions to complex problems. It is used in a variety of fields, such as engineering, economics, and biology, to improve processes and make better decisions.
3. What are some common applications of optimization in scientific research?
Some common applications of optimization in scientific research include designing efficient transportation systems, optimizing drug dosages for medical treatments, and finding the most cost-effective solutions in business and finance.
4. What are the steps involved in solving an optimization problem?
The steps involved in solving an optimization problem include defining the objective function, determining the constraints, finding the feasible region, identifying the optimal solution, and verifying the solution meets all constraints.
5. Can optimization problems have multiple optimal solutions?
Yes, optimization problems can have multiple optimal solutions. This occurs when there are multiple solutions that satisfy all constraints and have the same optimal value for the objective function. In these cases, any of the optimal solutions can be considered equally valid.
  • Mechanical Engineering
