Explain Why we get hut by kicking a brick
  • Thread starter area51
  • Tags
    Explain
In summary, when we push the brick lying on the floor with our foot, the Brick applies the same opposite force to our foot. This difference is the amount of force. When we kick the brick quickly, the Brick applies a lot of acceleration so a large force- which, by Newton's third law, the brick also applies to our foot. By the way, "friction on the floor" does NOT make the brick move. It slows the brick- friction always acts against motion. The friction is the reason that, once the brick is moving, you must apply "almost" no force. If there were no friction, once the brick started moving, it would continue to move with no additional force.
area51
Explain Why we get hurt by kicking a brick
You can easily move a brick lying on a floor by gently pushing it by your foot. But
you hurt your foot when you try to kick the brick. Explain why? (in 60 to 80 words)
Theory Question
Explanation: When we gently push the brick with foot, The Force we apply on the brick by pushing and friction by floor makes it move. But when we kick the brick lying on the floor, From Newtons third law of motion: Every action has equal and opposite reaction. the brick applies the same opposite force that we apply on the brick by kicking and we get hurt.
is it right?
No, that's not right. Newton's third law of motion applies in both cases. Even when slowly moving the brick, the brick applies the same force to your foot.
The difference is the amount of the force. If you move a brick slowly, you are applying a very slight acceleration to get it moving, then almost no acceleration so, since F= ma, very slight force, then almost no force. When you kick a brick quickly, you apply a lot of acceleration so a large force- which, by Newton's third law, the brick also applies to your foot.
so in ur words, can u answer it in 60-80 words the above question
so is this answer correct,
Answer: Here Newton's third law of motion applies on both cases. when we push the brick lying on the floor with our foot. The Brick applies the same opposite force to our foot. here the difference is amount of force. when we push the brick we apply less acceleration to move it. its almost no acceleration. But when we kick the brick quickly we apply a lot of acceleration on it so the force increases, by Newton's third law "every action has an equal and opposite reaction", the brick also applies the same force on our foot and we get hurt.
ur post helped me a lot and cleared my confusion in physics, hope u'll help me in future
FAQ: Explain Why we get hut by kicking a brick
Why does kicking a brick hurt?
When we kick a brick, the force from our foot is transferred to the brick, causing it to push back against our foot with an equal force. This force can cause damage to the soft tissues and nerves in our foot, resulting in pain.
What factors contribute to the pain when kicking a brick?
The pain experienced when kicking a brick is influenced by several factors, including the force of the kick, the location on the foot that makes contact with the brick, and the sensitivity of the individual's nerves and soft tissues.
Why do some people experience more pain when kicking a brick than others?
Individuals with a higher pain tolerance or thicker skin may experience less pain when kicking a brick compared to those with a lower pain tolerance or thinner skin. Additionally, factors such as the strength and speed of the kick can also impact the amount of pain felt.
Is there a way to kick a brick without feeling pain?
No, it is not possible to kick a brick without experiencing some level of pain. The force and impact of the kick will always result in some degree of discomfort or pain.
Can kicking a brick cause long-term damage?
It is possible for kicking a brick to cause long-term damage, especially if the force of the kick is strong enough to cause a serious injury. Repeatedly kicking a brick could also potentially lead to chronic pain or damage to the muscles and bones in the foot.
