Explaining sinh and cosh graphically
  • Thread starter Seung Tai Kang
In summary, sinh and cosh are mathematical functions that are graphically represented as curves on a coordinate plane. These functions are closely related to each other and are commonly used in the study of hyperbolic functions. The sinh curve appears as a symmetrical curve with a positive and negative branch, while the cosh curve is a similar but mirrored curve. Both curves have an asymptote at y=1, and their shapes are influenced by the exponential function and the Pythagorean identity. Understanding the graphical representation of sinh and cosh is essential in solving equations involving these functions and in analyzing real-world phenomena such as population growth and radioactive decay.
Seung Tai Kang
tanh x is 12/13 . Then cosh x is 12/5 and sinh is 13/5. This can be found algebraically by finding x.
tanh x= sinh x/cosh x
The answer can be found algebraically by finding x. tanh x= sinh x /cosh x.
tanh(x) =
sinh(x) / cosh(x) =
((1/2) * (e^(x) - e^(-x))) / ((1/2) * (e^(x) + e^(-x))) =>
(e^(x) - e^(-x)) / (e^(x) + e^(-x))
12 / 13 = (e^(x) - e^(-x)) / (e^(x) + e^(-x))
12 * (e^(x) + e^(-x)) = 13 * (e^(x) - e^(-x))
12 * e^(x) + 12 * e^(-x) = 13 * e^(x) - 13 * e^(-x))
25 * e^(-x) = e^(x)
25 = e^(2x)
ln(25) = 2x
2 * ln(5) = 2x
x = ln(5)
sinh(x) =
(1/2) * (e^(x) - e^(-x)) =>
(1/2) * (5 - (1/5)) =>
(1/2) * (24/5) =>
12/5
cosh(x) =
(1/2) * (e^(x) + e^(-x)) =
(1/2) * (26/5) =>
13/5
But I believe there must be a graphical explanation using hyperbola too, just as there are algebraic and graphic explanations for trigonometry using circles and triangle.
Can someone explain it to me graphically using hyperbola?
It is just the same as the circle, but using the unit hyperbola instead of the unit circle. Also, ##x## is not a regular angle, but a hyperbolic angle. The unit hyperbola can be parametrised by a hyperbolic angle ##\theta## as
x = \cosh(\theta), \quad y = \sinh(\theta),
since this implies that ##x^2 - y^2 = 1##. Draw a line through the origin and ##x = 13, y = 12##. Where it crosses the hyperbola, the ##x##-value is ##\cosh(\theta)## and the ##y##-value is ##\sinh(\theta)##. Of course, to do this you will need to draw the hyperbola properly first.
However, your problem is more easily solved using the hyperbolic identity ##\cosh^2(\theta) - \sinh^2(\theta) = 1## to relate ##\cosh(\theta)## and ##\sinh(\theta)## to ##\tanh(\theta)##. You do not need to go via the definitions in terms of exponential functions.
x=12 and y=13 does not cross the origin but just a straight line parallel to x and y-axis at x=12 and y=13 respectively. I guess you may have meant it with respect to θ but could you elaborate on it?
You have misread the post. There is only one line. It passes through the origin and the point ##(x,y) = (12,13)##. Two points are sufficient to uniquely identify a line.
FAQ: Explaining sinh and cosh graphically
1. What are sinh and cosh functions?
Sinh and cosh are mathematical functions that are related to the hyperbolic sine (sinh) and hyperbolic cosine (cosh) of a complex number. They are commonly used in physics and engineering to describe the behavior of systems with exponential growth or decay.
2. How are sinh and cosh functions related to the regular sine and cosine functions?
The sinh and cosh functions are analogous to the regular sine and cosine functions, but they are defined using the exponential function instead of the trigonometric functions. They have similar properties and can be used interchangeably in some cases, but they have different graphs and behaviors.
3. How do you graph sinh and cosh functions?
To graph sinh and cosh functions, you can use a graphing calculator or plot them by hand. The graphs of sinh and cosh functions are smooth curves that resemble the regular sine and cosine graphs, but they have a steeper slope and never cross the x-axis.
4. What are the key features of a sinh and cosh graph?
The key features of a sinh and cosh graph include the shape of the curve, the amplitude, the period, and the asymptotes. The shape of the curve is similar to the regular sine and cosine graphs, but with a steeper slope. The amplitude is the maximum distance of the curve from the x-axis, and the period is the distance between two consecutive peaks or troughs. The graph also has two horizontal asymptotes, which are the lines that the curve approaches but never crosses.
5. How can I use sinh and cosh functions to solve real-world problems?
Sinh and cosh functions can be used to model real-world scenarios involving exponential growth or decay, such as population growth, radioactive decay, or the charging and discharging of a capacitor. By graphing these functions and analyzing their behavior, you can make predictions and solve problems related to these scenarios.
