Explan this phenomena with a hot steel rod
In summary, a common phenomenon in forges involves heating one end of a metal rod and quickly cooling it in cold water. This creates a gradient where the middle of the rod becomes the hottest part, resulting in a heat flow from the middle to both ends. This can be seen in a simple experiment using a silver spoon. The heat flow may be enough to burn one's hand, so caution is advised. The difference in temperature between the middle and ends of the rod is what causes the heat to flow quickly after quenching.
TSN79
424
A friend of mine told me this; you take a metal pole or rod and hold on to one end while warming up the other until it's red hot. Then you stick the warm end into cold water. One would expect it to cool down, and it does, but what happens is the end you're holding on to very quickly gets so hot you can't hold on, as if the heat runs up the rod in order to escape the cold. I've never tried this so I have to take his word for it, but can anyone explain what happens physically?
This is commonly seen in forges. All you have done is create a gradient so that the middle of the rod is fairly hot (perhaps 400C) while the fire end is very hot and the hand end is fairly cool (perhaps 50C). Now, when you quench the fire end, the middle becomes the hottest part of the rod. There is a heat flow from that middle to both ends and it may be enough to burn your hand (many people use tongs or gloves to hold the rod for this part). You would get the same effect (only slightly faster) if you just took the rod out of the fire and held it in the air.
You can do a simple experiment to see this effect. Take a silver spoon (has to be silver). Hold one end and put the other end in boiling water. As soon as the end you are holding becomes warm, remove the spoon from the hot water. It will burn you quickly. Make sure you are able to drop the spoon as soon as it starts to burn - this is capable of blistering your fingers. I suppose you could even try dunking the hot end in ice water to see the full effect, but again this may blister your hand, so be careful.
The middle part of the rod would be just as hot before I quench the fire end, so why doesn't the heat flow to my hand just as fast before quench it?
Don't confuse heat flow with temperature. The heat was indeed flowing, but not enough time had lapsed for the temperature to rise significantly.
Related to Explan this phenomena with a hot steel rod
1. What is the phenomenon of a hot steel rod?
The phenomenon of a hot steel rod refers to the transfer of thermal energy from a heat source to the steel rod, causing its temperature to increase and potentially leading to changes in its physical properties.
2. How does heat transfer occur in a hot steel rod?
Heat transfer in a hot steel rod occurs through the process of conduction, where the molecules of the rod vibrate and transfer heat energy to neighboring molecules, eventually causing the entire rod to heat up.
3. Why does a hot steel rod change color when heated?
When a steel rod is heated, the increased temperature causes the atoms within the rod to vibrate more rapidly, which in turn causes the electrons to absorb and re-emit light at a different frequency. This results in a change in color, as different frequencies of light correspond to different colors.
4. Can a hot steel rod cool down on its own?
Yes, a hot steel rod can cool down on its own through the process of thermal radiation, where the heated molecules emit infrared radiation and lose thermal energy, causing the rod to gradually cool down.
5. What are some practical applications of a hot steel rod?
A hot steel rod has various practical applications, such as in welding, where the high temperature of the rod is used to melt and join metal pieces together. It can also be used in cooking, as a heat source for grilling or roasting food items. In addition, a hot steel rod can be used in scientific experiments to study the effects of heat transfer and thermal conductivity.
  • Materials and Chemical Engineering
  • DIY Projects
  • Thermodynamics
  • Atomic and Condensed Matter
