Explanation for high boiling point of Iodine Monobromide as compared to Iodine Monofluoride
The melting point of IBr is significantly higher at 42°C compared to IF, which melts at -45°C. This discrepancy raises questions about the forces influencing melting points, especially given that fluorine's high electronegativity suggests stronger dipole-dipole interactions in IF. Two primary factors are considered: Firstly, heavier molecules generally have higher melting and boiling points due to increased electron count, although this can be influenced by dipole moments. Secondly, the molecular geometry plays a crucial role; IBr has a more favorable shape with iodine and bromine being similar in size, allowing for better packing in the crystal lattice. In contrast, the smaller fluorine atom in IF may lead to less effective packing and weaker intermolecular interactions. These factors highlight the complexity behind melting point disparities beyond simple bond polarity.
neilparker62
Insights Author
Apparently the melting point of IBr is 42 Celsius whereas that of IF is -45 Celsius. As Fluorine is highly electronegative, the dipole-dipole bonds in IF should be a lot stronger than in IBr. So I am wondering what forces are responsible for the huge disparity in melting points - the complete opposite of what one might expect based on bond polarity.
Chemistry news on Phys.org
Two things that come to mind:
1. Heavier molecules have more electrons, so typically heavier molecules have higher melting/boiling points (yes, this is assuming "all else kept equal", and you are perfectly right dipole moment could easily falsify this assumption).
2. Geometry - IBr is much more "well shaped" with I and Br being of comparable sizes. F is much smaller, so can be crystal lattice of a solid IF is not well packed and average distance between molecules is relatively high, which makes their interactions weaker.
These are just guesses of what is worth checking, not things that I would consider "the answer".
Likes neilparker62 and Lord Jestocost
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
