Explanation of a chemical reaction
In summary, the white residue is zinc oxide and the blue fluorescence is caused by the formation of zinc chloride when reacting with heat.
smithy1992
Good afternoon,
The following experiment+observation is given. I look for the explanation of the observations (means: why 1. a white residuum appears and 2. why a blue fluorescence is detected).
Brass consists of zinc, tin and copper, the following reaction shall analyse these properties:
1. Solubilize in in half concentrated HNO3
2. Evaporation until dry
3. Add diluted HCl
-> a white residuum appears
4. Add zinc-granules
5. Heating in a test tube (half fulled with water)
-> observation: blue fluorescence
I assumed that the white residdum is zinc!?
Thank you very much for your aid.
Franziska
The white residue that appeared is likely zinc oxide, which forms when zinc reacts with the diluted HCl. The blue fluorescence is likely due to the formation of zinc chloride when zinc reacts with the heat. Zinc chloride is known to emit a blue light when exposed to ultraviolet light.
Good afternoon Franziska,
From the given experiment and observations, it appears that the white residuum is indeed zinc. This is because when brass is dissolved in half concentrated HNO3, it reacts with the zinc present in the brass, forming zinc nitrate and releasing hydrogen gas. When the solution is evaporated until dry, the zinc nitrate is left behind as a white residuum.
The addition of diluted HCl in step 3 serves to neutralize any excess HNO3 and also dissolves any remaining zinc nitrate. This results in the formation of zinc chloride, which is a white solid.
When zinc granules are added in step 4 and the mixture is heated in a test tube, the zinc reacts with the water present in the test tube, forming zinc oxide and releasing hydrogen gas. The heating also helps to break down any remaining zinc nitrate and zinc chloride.
The blue fluorescence observed in step 5 is due to the presence of zinc oxide. When heated, zinc oxide releases energy in the form of light, resulting in the blue fluorescence.
Overall, the chemical reaction that is occurring in this experiment is the dissolution of brass in nitric acid, followed by the formation of zinc nitrate and zinc chloride. The addition of zinc granules and heating leads to the formation of zinc oxide, which produces the blue fluorescence. I hope this helps to explain the observations you have made. Please let me know if you have any further questions or need clarification.
Related to Explanation of a chemical reaction
1. What is a chemical reaction?
A chemical reaction is a process in which substances, known as reactants, interact with each other to form new substances, known as products. This process involves the breaking and forming of chemical bonds.
2. What is the purpose of explaining a chemical reaction?
The purpose of explaining a chemical reaction is to understand how and why a reaction occurs. This knowledge can be used to predict the outcome of reactions, design new experiments, and develop new products.
3. How is a chemical reaction represented?
A chemical reaction is often represented using a chemical equation, which shows the reactants on the left side and the products on the right side. The reactants and products are separated by an arrow, which indicates the direction of the reaction.
4. What factors can affect a chemical reaction?
Several factors can affect a chemical reaction, including temperature, concentration, surface area, and the presence of a catalyst. These factors can alter the rate of the reaction and the products formed.
5. What is the difference between a physical and chemical change?
A physical change involves a change in the physical properties of a substance, such as its shape, size, or state (solid, liquid, gas). A chemical change, on the other hand, involves a change in the chemical properties of a substance, resulting in the formation of new substances with different properties.
35K
  • Biology and Medical
  • Classical Physics
