I Explanation of all "its linearly independent derivatives"
Hall
I'm studying Differential Equations from Tenenbaum's, and currently going through non-homogeneous second order linear differential equations with constant coefficients. Method of Undetermined Coefficients is the concerned topic here. I will put forth my doubt through an example. Let's say we are asked to solve
\begin{align*}
y'' + 4y = x \sin 2x\\
\textrm{complexifying the equation} \\
\tilde{y''} + 4 \tilde{y} = x e^{(2x) i} \\
\end{align*}
If we see the associated homogeneous differential equation
\begin{align*}
y'' + 4y = 0 \\
\textrm{Characteristic equation} \\
m^2 + 4 = 0 \\
m = \pm 2i \\
y_c = c e^{(2i) x} \\
\end{align*}
Now, Tenenbaum writes,
Case 2. ##Q(x)## [the RHS of a non-homogeneous differential equation] contains a term which, ignoring constant coefficients, is ##x^k## times a term ##u(x)## of ##y_c##, where ##k## is zero or a positive integer. In this case a particular solution ##y_p## of [non-homogeneous differential equattion] will be a linear combination of ##x^{k+1} u(x)## and all its linearly independent derivatives.
So, in our case ##u(x) = e^{(2x) i}## and ##k=1##; ##y_p## should be a linear combination of ##x^2 e^{(2i) x}## and its linearly independent derivatives. What are its linearly independent derivatives? A set is called independent if none of the members can be obtained by combining the rest of them linearly. Let's begin differentiating our candy
\begin{align*}
f(x) = x^2 e^{(2x) i } \\
f'(x) = 2x e^{(2x) i } + 2i x^2 e^{(2x) i } \\
f''(x) = 2 e^{(2x) i } + 8i x e^{(2x) i }-4 x^2 e^{(2x) i } \\
f'''(x) = 12i e^{(2x) i } - 24 x e^{(2x) i } - 8i x e^{(2x) i }\\
\end{align*}
Well, it seems to me that ##f'''(x)## can be expressed as linear combination of ##f"(x)## and ##f'(x)## (but I'm not sure. So, according to Tenenbaum, the solution should like
y_p = A x^2 e^{(2x) i } + 2Bx e^{(2x) i } + 2B i x^2 e^{(2x) i } + 2C e^{(2x) i } + 8C i x e^{(2x) i } - 4C x^2 e^{(2x) i }
I'm not sure if I'm right, but this task of finding linearly independent derivatives doesn't seem a very good alternative to solving the actual DE. Can you please say something on this **linear independent derivatives**?
\begin{align*}
\end{align*}
Your original ODE is second order, so you don't need to go beyond f''(x). The functions f, f', and f'' are linearly independent.
Also, what do you mean by "differentiating our candy"? Is that a typo?
He learnt Pdes in the street, Mark44, unlike us ;).
\begin{align*}
\end{align*}
\begin{align*}
y'' + 4y = 0 \\
m^2 + 4 = 0 \\
m = \pm 2i \\
\end{align*}
\begin{align*}
\end{align*}
Kindly your insight on this;
I think for the homogenous part we shall have;
##y_c (x)= A\cos 2x +B\sin 2x##
then for the inhomogenous part; we can let
##y_p(x)= C[x \sin 2x]##
##y^{'}_p(x)= C[ \sin 2x+2x\cos 2x]##
##y^{''}_p(x)= C[2\cos2x+2\cos2x-4\sin2x]## ...
##C[2\cos2x+2\cos2x-4\sin2x]+4C[ \sin 2x+2x\cos 2x]=[x \sin 2x]##
##C[4\cos2x-4\sin2x]+4C[ \sin 2x+2x\cos 2x]=[x \sin 2x]##
then solving can take normal course with given two boundary conditions...
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
