Explanation of E-field torque and initial angle
In summary, a dipole moment is placed in an electric field and a torque of 0.1 N.m is applied to it. The dipole reaches equilibrium at an unknown angle, and its potential energy in this state is -0.2J. To find the initial angle between the dipole moment and the electric field, the maximum torque is divided by the potential energy and the inverse tangent is taken. The correct answer is approximately 26.5 degrees, but 30 degrees may also be accepted as a rounded answer.
jonochar
Hello,
A dipole moment is placed in a uniform electric field oriented along an unknown direction. The maximum torque applied to the dipole is equal to 0.1 N.m. When the dipole reaches equilibrium its potential energy is equal to -0.2 J. What was the initial angle between the direction of the dipole moment and the direction of the electric field?
torque = pEsin(theta)
Potential Energy = pEcos(theta)
Work = pEcos(Θ2) - pEcos(Θ1)
I got the correct answer, which was about 26.5°. What I am unsure about is why that worked, and how would I have understood that intuitively, I googled the question after attempting it for a while.
To get that answer. The maximum torque was divided by the potential energy, and then the inverse tan was taken to get the angle. I'm not sure what this means and I would appreciate help.
edit: also, it's possible that this may be the wrong answer, I selected 30 degrees (multiple choice) and assumed it may have been rounded, since my teacher likes to round out to easier numbers
Potential energy is not pEcos(x) when the dipole is at its minimum energy alignment. That's its potential energy when it's aligned to the original angle x.
That angle is indeed 30 deg.
This is a poorly worded problem, which makes it confusing. What they mean is that the dipole is placed in an electric field -> while a torque of 0.1N/m is applied to it <-. Under the influence of the torque it remains at some unknown angle theta. After the torque is released it returns to its equilibrium (lowest energy) state. The potential energy of that state is -0.2 J.
FAQ: Explanation of E-field torque and initial angle
What is E-field torque?
E-field torque is a force that acts on an electrically charged object when it is placed in an electric field. It causes the object to rotate around an axis, similar to how a magnet rotates in a magnetic field.
How is E-field torque calculated?
E-field torque is calculated by multiplying the electric field strength by the charge of the object and the perpendicular distance between the object and the field. This can be represented by the equation T = Q x E x sinθ, where T is torque, Q is charge, E is electric field strength, and θ is the angle between the field and the object.
What is the significance of the initial angle in E-field torque?
The initial angle in E-field torque refers to the angle between the electric field and the object at the beginning of the rotation. It determines the direction and speed of the rotation, as well as the amount of torque exerted on the object.
How does changing the initial angle affect E-field torque?
Changing the initial angle can greatly impact the strength and direction of E-field torque. As the initial angle increases, the torque also increases, reaching its maximum when the angle is perpendicular to the electric field. However, if the angle is parallel to the field, there will be no torque exerted on the object.
What is the practical application of understanding E-field torque and initial angle?
Understanding E-field torque and initial angle is important in various fields such as physics, engineering, and electronics. It is used in the design and functioning of electric motors, generators, and other electrical devices that rely on the conversion of electrical energy into mechanical energy. It also helps in understanding the behavior of charged particles in electric fields, which is essential in fields such as plasma physics and particle accelerators.
