- #36
AlephZero
- 6,982
- 299
voko said:Lift off meaning it is no longer acted on by any force from the pulley? How is that different from my previous analysis?
If your analysis is correct, there is no difference. It could also be extended to the "balls on a string" experiment by taking the pulley as a polygon instead of a circle.
But it is a much more controllable system to experiment with. Given the mass per unit length of chain, you can set the chain velocity and tension to any values independently, by choosing the chain lengths on each side of the pulley. It removes the unknown initial conditions caused by "throwing" the end of the chain out of the pot.
There are (at least) two ways to interpret the instabilities. The simple way is to assume they are stable perturbations from a steady state solution, and start by looking at the steady state only.The fluctuation in the radius of curvature due to the clearly visible instabilities in motion will have a greater effect than gravity, so taking the smaller effect into consideration while ignoring the bigger seems strange to me.
Another possibility is that this is an inherently chaotic system, and the "steady state" is just the visual appearance of an attractor. That might lead to a model which is fundamentally different from a chain over a pulley.
