Explanation of time dilation due to c being the maximum speed
In summary, the conversation discusses a video that explains time dilation due to velocity by stating that light and light interactions inside a moving body must travel a longer distance in space, resulting in a slower passage of time. The speaker expresses objections to this explanation and discusses the concept of proper time and coordinate time. They also mention the Lorentz transformations and the transverse Doppler effect. The conversation ends with a question about the interpretation of maximum speed and its application to a muon's decay.
MachPrincipe
44
I have seen a video in which the time dilation due to velocity is explained by saying that light and light interactions inside a moving body must travel a longer distance in space, which reduces the passage of time.
Video:
This explanation is new to me, and in fact, I recently heard an almost identical one a few months ago. Til now I have always considered that time itself was affected by speed, and that what is described above was more a consequence (effect) than a cause. As most, they would be equivalent.
I am suspecting that this kind of explanation comes from some relatively recent book or other science divulgation media, which has popularized this view.
I have these objections to that explanation, and because I am too used to the usual, conventional, explanation, would be very glad that someone can correct me if I am wrong in some of my objections.
My objections are these:
  1. Time dilation is a consequence coming directly from the 2 postulates. Lorentz transformations apply and we have time dilation, which affects directly to rate of clocks.
  2. Time is "going slower" (time dilation) for the moving object, i. e., the proper time of the (moving) ship is shortened respect to (rest) Earth.
  3. In the explanation due to speed interactions (video and similar ones), it is assumed that there exists a maximum speed, that this speed is that of light, and that time emerges from this maximum speed, so for particles distant each other, and moving, it will take a longer time to communicate, and the passage of time will be lesser for these particles. Also that all sorts of interactions, even subatomic, will attain to this speed.
  4. All the assumptions in point 3 are derived from the result of c = maximum speed, which comes from Lorentz transf. if we start with the 2 postulates, so indeed we are already stating that time dilation applies (circularity).
  5. For a muon, and its spontaneous radioactive decay, being a point particle and the decay a stochastic quantum process, the explanation of maximum speed would not seem to apply and would not explain the dilatation which allows them to travel through the entire atmosphere of the Earth. Time dilation explains it.
  6. As for transveral Doppler effect, I am not sure if the interpretation of maximum speed of light would explain it, but slower time passage does, directly (this I am not sure).
My sensation with this explanation is that it is closer to the Lorentzian interpretation of relativity, rather than actual Einstenian relativity.
Suggestions are appreciated.
Just a quick comment on that aspect of your statements. Time is going slower for the moving object relative to Earth, yes, but likewise the time on the Earth is going slower for the observer on the spaceship. Proper time does NOT slow down for either one. Proper time for the traveler is what is measured in a reference frame in which the traveler is at rest and proper time for the Earthbound is what is measured in the reference frame in which the Earth bound person is at rest. Both proper times are ticking at one second per second. Of course, if the traveler turns around and comes back, he will have experienced a different number of seconds but that's differential aging, not time dilation per se.
Yes, you are completely right. I was referring to proper time (clock at rest aboard the ship) and coordinate time (clock at rest in Earth). Also agree on the reciprocity of both systems. As for the interpretation, minute 5 of video, and my interpretation and judgement of it, what do you think?
They may be referring to a "light clock", which is one of the simplest models in which one can see how the invariant speed of light leads to the prediction of time dilation. This article gives a reasonably simple presentation:
http://galileoandeinstein.physics.virginia.edu/lectures/srelwhat.html
Why not?
Transverse Doppler is a consequence of the Lorentz transformations, just like time dilation.
And it is lengthened, not shortened. Two seconds or ticks in the moving clock ta
Why not?
I am not succeeding at explaining me. I do not claim that TDE is not coming from Lorentz transformations. I am not claiming that muon extended half life does not happen. I say that the video is, implicitly or explicitly, that time itself is not affected by speed. The interpretation is that bodily processes (in the brain, in other organs, inside the computer aboard) are slowed because the light and any other interacting medium has this maximum speed, c, and thus everything goes slower, time is like freezing. This would consider time as an emerging property. Thus, processes where electromagnetic signals are not involved, or where there are no distances for the information to travel, like a pointlike particle as a muon decaying, the explanation, analogy or whatever you call this explanation is not appliable. In contrast, time by itself being delayed is what would explain this delayed decay. Also about the transverse Doppler, I do not see right now how longitudinal speed can affect in this interpretation,, while effective slowing of time does. In fact, longitudinal Doppler effect has a mixture of classical and time dilation and transverse Doppler is purely relativistic. By as the new interpretation is in fact, right about maximum speed, this is why I consider it to be quite equivalent in predictions, but with the points of circularity, limitations for muon, etc, etc.
It appears to be an application of the same effect described by the traditional analysis of a light clock. However, they get it wrong. At about the 6-minute mark they mention that people in the rocket are traveling "closer to the speed of light" than people on Earth. That is simply false and contradicts both postulates. To see that their explanation is preposterous, note that they cannot use it to explain why people on the rocket will observe clocks on Earth running slow. According to their arguments, people on Earth will be seen to have their clocks running faster because the subatomic particles in their bodies have a shorter distance to travel than the ones in people on the rocket. And for that reason people on Earth age faster than people on the rocket.
That is an inaccurate depiction of the difference in proper time experienced by the twins in the twin paradox. The correct explanation involves the asymmetry in their paths through spacetime, and in the video there is no mention of that asymmetry, only the erroneous closer-to-c asymmetry I mentioned. A valid explanation of the twin paradox involves at least some reference to a valid asymmetry, otherwise one is limited to describing things only from the viewpoint of the one twin who's inertial and avoiding the fact that the same analysis won't work for the noninertial twin. One must at least mention the fact that it won't work
I do not think the video presents anything of substance that hasn't already been presented by others. Those mistakes have been around as long as people have been describing Einstein's relativity, and they will likely continue to be created in ways that might seem new but perhaps aren't.
I missed the part of the nearest to c - my native language is not English. But then, please read what I recall from a friend in a dinner: he explained time dilation this way: imagine a ship going at c minus a very small quantity. As it travels so fast, when they turn on a lamp in the rear part, it will take ages for the light to reach the front part. As c is constant, time must be frozen in the ship or they would measure a very slow light speed.
That explanation is symmetrical and simpler than usual light clock analysis, maybe because you pretend to get the idea, not the formula. The novelty here would be to associate the light interaction with «time flow» itself. In any case, he (video author) does not explain lenth contraction either, not relativity of simultaneity.
That's just silly. I'm assuming that's your point, that your friend has it all wrong.
Let's say it's a very very long ship (1 light second long, or 300 000 km) so it takes the light flash one second to go from the rear of the ship to the front.
Suppose the ship is moving at a speed of 0.96c relative to someone watching it pass. In that person's frame of reference it will travel a distance of 7 light seconds and so take 7 seconds to reach the front of the ship.
Since MachPrincipe tells us his native language is not English, I took his use of the word frozen to mean sluggish, or slow. I could be wrong.
I believe that this is the phenomenon the producers of the video were trying to describe, but they buggered it up.
Well, in fact you can retain a normal length, ten meters, and put an absurd speed, let's say 0.999999999999...99999c. First, you will have a very noticeable length contraction, which is never mentioned, but it is clear that light will take a lot of time to reach the front end. In order to keep this a low proper time, time will go so slowly as to appear almost frozen. In fact, this is exactly the light clock idea, but carried to the extreme and without calculations being important, it is just for dramatic purposes, to convince of the time dilation effect. It is the other assumption which bothers me: that it is not time by itself which goes slower due to speed, but it is the difficulty, let's say so, of interaction of particles with each other which makes time to appear almost frozen. It is a very subtle assumption, I have read it in other posts somewhere in internet, and I think it is wrong and circular.
The numbers I posted take length contraction into account. If you had a ship length of 300 m, the time on the ship would be one microsecond, and the time measured by the observer would seven microseconds.
The light clock scenario need not include any calculations. It's more obvious to me because it doesn't involve length contraction. That's the beauty of it.
It is in fact a mechanism. One must use some mechanism to introduce the notion of time dilation. Then make the argument that if that mechanism measures time, then all other time-measuring mechanisms will give the same result. From there it's a philosophical issue that we're dealing with time itself rather than a measurement of time.
This does seem dubious. It also seems unnecessary; the argument using the invariant speed of light is already sufficient.
I agree. Summarising some of the comments, I have the following view:
Light clock can be used to show the time dilation. Applied in a direction transversal to the path, no length contraction is needed to show that there exists a time dilation. Of course, this popular explanation does not proof the time dilation concept, but shows an easy example of it.
The concept in the video seems to be a popular way of explaining time dilation. It ignores length contraction, so it is rather poor as an explanation. It uses a modified version of the light clock explanation, using not a tranversal direction but a longitudinal direction (this is why the ignored length contraction should be needed. It would complicate the explanation, so this is why this is not a satisfactory way of explaining the effect, at least if you do not make some maths).
The concept of time dilation being an emerging property associated with "time flow" itself is a philosophical concept more than a scientific one. It has its own problems. Trying to reconcile the idea with a Lorentzian view of relativity is a bad idea, as the main achievement of special relativity is to make all considerations of Lorentzian POV superfluous and unnecesary (Lorentz introduced a time which was more a mathematical artifact than a "real" time).
That said, I found again this reference. Many years ago I found it and read it, but I never bought the idea. Now it re-surfaces again. I think it is associated with the concept (badly expressed in the popular video).
Direct calculation of time dilation, Oleg D. Jefimenko, Am. J. Phys. 64, 812 (1996)
It demonstrates that time dilation is a consequence of the two postulates. Demonstrating that a conclusion follows from a set of premises is the usual definition of a proof.
That demonstration of time dilation is valid. It's the same as the one given by your friend where the light signal is sent from the rear of a moving ship to the front. It doesn't mention length contraction, so in that sense it ignores it, but it is nevertheless there. It just goes unmentioned. The problem in the video is that they are treating the dilated time as if it's a proper time.
The only philosophical question here is whether the thing measured by clocks is really time. If one adopts a notion of time as being something other than that, it's a purely philosophical notion of time that has no basis in physical reality.
I understand at last! Well, it is not proper time what they are talking about, but you can make the proper time enter into arena very easily: just allow the light signal to. bounce bacl to the origin and you are done. Even if it didn't take any time or very small time to make this path from tje POV of the Earth, still with the explanation of the video you are ahowwing the concept of time dilation. The more subtle problem of the simultaneity would be left to explaiin why the ship does not detect any assymetry in the two halves of the ray travel.
As for the time dilation being proved with just the light clock example, I do not buy it. I have no objection if you already have the Lorentz transformations. If you start just from the two principles and go straight to time dilation, I do not think that it is enough to demonstrate time dilation, you don't already know if the things will be coherent in all inertial reference systems and all directions. Just go back to Einstein derivation of time dilation. First the coordinate transformations. If not, you would need proving an infinite set of particular cases, and light clock with tranversal path is just one of them.
No, you will still have an amount of time that depends on the relative speed of the observer. Proper time is the time that elapses between two events that occur at the same place in some reference frame.
This follows from the definition ##(\Delta \tau)^2=(\Delta t)^2-(\Delta x)^2##. Only when ##\Delta x=0## is the time ##\Delta t## equal to the proper time. It's value is the same regardless of the speed of the observer.
You do need to demonstrate that lengths perpendicular to the direction of motion are the same in both frames, and that is easy to do using just the first postulate. You also need isotropicity of space, but that is something you need in any proof of time dilation.
We don't understand each other here even if I believed that I got finally your point. My situation is: event 1, the light ray starts at one end of ship in direction to front end.Reaches the mirror, event 2 and it is reflected back to the starting point, arriving later, event 3. The time lapse between events 3 and 1 is a proper time, as they happen at x=0 of the ship coordinate system. As for the Earth. the coordinate time of events 3 and 1 is different, the coordinate time is not proper time as the x'1 and x'3 are different, and t'3-t'1 is greater than t3-t1, time dilaation. In the extreme example put in my post, you only need half a way to see the enormous differences of times of each inertial system.
Agree with that. But still ai am skeptical that you have proof of time dilation without going first through Lorentz transform. It could happen that you get time dilation in that scenario using only the principles but in another scenario you get a different expression for time diñation, i.e., a contradiction. So either you cover all spacetime with the gedanken experiments or you go first with the transformations of coordinates which ensures the self-consistence of the postulates being reconciliable each other in spite of its initial appearance.
Yes, you're right. I was thinking of the presentation in the video. The time measured by Earth observers is not a proper time. Sorry for not making that clear.
In that video they show that rocket particles have to travel a further distance than they would if the rocket weren't moving. That is true only for observers, like Earth observers, who observe the rocket in motion. Earth observers measure the time the particles have to travel, but that is not a proper time. In the video they imply that it is. You cannot make that a proper time by having the particles reflect and return to their original position relative to the rocket.
Surely the video explanation is wrong and messed up, but I got the concept. In fact, I always found the distinction among proper coordinates and coordinate coordinates (!) rather superfluous. You could do any calculation by using proper time alone, introducing later extra calculations. I did it so always when volunteering to the blackboard, to the dismay of teacher, but I insisted I would not use those misleading Lorentz transformations (I was young and rebel, then).
dayalanand roy said:
In most of the explanations or examples of time dilation given on internet, the source of light and the ray of light emitted from it travel in the moving ship/carriage/rocket itself. In this condition, should the light source not suffer from inertia itself? And does the ray of light moving in the ship actually exhibit the peculiar behavior of the constancy of light's speed?
Light speed is constant regardless of the motion of the source. Momentum/speed of the source is irrelevant. That is the very essence of Special Relativity.
he obkection to explanation seems to be that no relativity of simoultaneity is taken into account. That is right in most of the cases; but for speeds high enough, time dilation is shown even with this factor, because the mean time on a 2-way path would be greater in movement than for a stationary example. The embarkment example you talk about deals with this question.
Distinguished members
There are some discussions about the philosophical aspects of time as well in this post. What do we actually mean by the 'time' that is getting dilated here? I shall only give some excerpts from the Einstein's same book (Relativity- The special and general theory)- I know you all are well aware with these excerpts; I want you only to give a fresh look on them.
1. ‘In order to have a complete description of the motion, we must specify how the body alters its position with time, i.e. for every point on the trajectory it must be stated at what time the body is situated there. These data must be supplemented by such a definition of time that, in virtue of this definition, these time values can be regarded essentially as magnitudes (result of measurements) capable of observation. (Part 1,chapter III)
2.We are thus led also to a definition of time in physics. For this purpose we suppose that clocks of identical construction are placed at points A, B and C…, and that they are set in such a manner that the positions of their pointers are simultaneously….the same. Under these conditions we understand by the ‘time’ of an event the reading (position of the hands) of that one of these clocks which is in the immediate vicinity (in space) of the event which is essentially capable of observation. (Part 1, chapter VIII).
3.‘Every reference body (co-ordinate system) has its own particular time, unless we are told the reference body to which the statement of time refers, there is no meaning in a statement of the time of an event.(Part 1, chapter VIII).
4. ‘In every gravitational field, a clock will go more quickly or less quickly, according to the position in which the clock is situated (at rest). For this reason it is not possible to obtain a reasonable definition of time with the aid of clocks which are arranged at rest with respect to the body of reference. A similar difficulty presents itself when we attempt to apply our earlier definition of simultaneity in such a case, but I do not wish to go any farther into this question.’ (Part III, chapter 23)
Mendel Sachs quotes Einstein from a lecture he gave to the Prussian Academy of Sciences in 1921.
‘Geometry predicts nothing about relations of real things, but only geometry together with the purport of physical laws can do so…..The idea of the measuring rod and the idea of the clock coordinated with it in the theory of relativity do not find their exact correspondence in the real world. It is also clear that the solid body and the clock do not in the conceptual edifice of physics play the part of irreducible elements, but that of composite structures which may not play any independent part in theoretical physics.’
Sachs continues, ‘Einstein then went out to say that in spite of the foregoing comment, we should temporarily support the use of length and time transformations as though they were physically real, because ‘we are still far from possessing such certain knowledge of theoretical principles as to be able to give exact theoretical constructions of solid bodies and clocks’.
(M. Sachs, "On Einstein's Later View of the Twin Paradox", Foundations of Physics, Vol. 15, No.9, 1985)
Thanks.
Thanks.
Thanks
"At about the 6-minute mark they mention that people in the rocket are traveling "closer to the speed of light" than people on Earth. That is simply false and contradicts both postulates."
Agreed.
And from there on it just gets even worse, lacking any logic whatsoever. What's the point about the car traveling across the country versus next door?? None.
I did not read the last half dozen or so posts, but another way to see the explanation in the video is simply wrong from about the 6 minute 20 second time is to note that according to that [incorrect] explanation, light [photons, gravitons,etc] moving perpendicular to the direction of motion of the vehicle would have different ["molecular, gravitational etc" interaction times than the particles moving in the direction of vehicle travel. Matter and gravity itself would be disrupted with different interactions speeds in different directions.
Besides, we aren't we all 'traveling at light speed' relative to something, somewhere in the distant universe?
But the kid in the video deserves a lot of credit for getting as far as he did. The error is one so many make when discovering relativity, and quantum mechanics, for that matter: There is no 'logic', except Einstein's, why relative time is effected by speed and gravity [potential].
"It’s nature that is bizarre, not the presentation." A. Zee.
They were simply explaining the relationship between distance traveled and speed. The faster you travel the further you'll travel in a given amount of time.
The point they were making was that all processes will take a longer amount of time. I realize I'm granting them latitude here, but they were making an argument like the argument used to explain why the traditional light clock runs slow when observed from a moving frame: Light takes more time to travel the greater distance.
They go wrong by presenting a dilated time, and then interpreting it as a proper time. In other words, the rocket photons traveling for a longer time when viewed from the Earth frame can't explain why people in the rocket age less. If it could then Earth photons traveling for a longer time when viewed from the rocket frame could be used to explain why people on Earth age less. Aging is a process that involves the passage of proper time, not the passage of dilated time. You measure proper time in one frame of reference. You need two frames of reference to measure dilated time. Aging is something that happens in one frame of reference.
I don't understand this last objection. Earth clocks will show time dilation too, and the explanation is equivalent. This taking by granted that he was explaining the clock paradox and not the twin paradox.
No single clock can show time dilation. You need two clocks moving relative to each other.
The traveling twin returned home and was younger than the stay-at-home twin. That's the twin paradox.
Not sure what you mean by the clock paradox. If you mean that each observer co-moving with his clock will see the other's as moving slow, that issue was not at all addressed in the video.
I agree that you need two clocks to show any time dilation. That was given by granted. I need to see the video again.
Clock paradox, as I understand it, is the apparent paradox under the concept of symmetrical time dilation. In the twin paradox, it is allowed to break this symmetry by letting the ship return to Earth.
I don't know if the distinction has been made in consensus. Sometimes clock paradox and twin paradox are seen as equivalent terms to refer to the exact same concept.
In infamous Dingle controversy, he used to talk of clock paradox and explicitly used the first definition.
I am not sure if I am the only one making this distinction, I suspect either I read it somewhere in a paper or infered from different treatments given by different authors.
I agree, then, that you probably do need to watch the video again. Time dilation was presented in a way that was partly right in that it explained why Earth observers conclude that rocket clocks run slow, but partly wrong because it explained it as if it it's not symmetrical. In other words as if people on the rocket would experience less proper time because they are moving at a speed that is "closer to the speed of light".
Related to Explanation of time dilation due to c being the maximum speed
What is time dilation?
Time dilation is a phenomenon in which time appears to pass slower for an observer who is moving at high speeds relative to another observer. This is due to the fact that the speed of light (c) is the maximum speed at which all objects and information can travel, and as an object's speed approaches c, time appears to slow down for that object.
How does the speed of light affect time dilation?
The speed of light, which is approximately 299,792,458 meters per second, is the maximum speed at which all objects and information can travel. As an object's speed approaches the speed of light, time dilation occurs and time appears to slow down for that object. This is because the faster an object moves, the more energy it requires, and as an object approaches the speed of light, it requires an infinite amount of energy to continue accelerating.
What is the theory of relativity and how does it relate to time dilation?
The theory of relativity, developed by Albert Einstein, is a fundamental theory in physics that describes the relationship between space and time. It states that the laws of physics are the same for all observers in uniform motion, and the speed of light is constant for all observers. Time dilation is a consequence of this theory, as it shows that time is relative and can be affected by an observer's relative motion and the speed of light.
Does time dilation only occur at very high speeds?
Yes, time dilation only becomes noticeable at very high speeds, approaching the speed of light. At everyday speeds, the effects of time dilation are negligible and cannot be observed. However, as an object's speed increases, the effects of time dilation become more significant.
Is time dilation just a theoretical concept or has it been proven?
Time dilation is a well-established phenomenon that has been proven through various experiments and observations. One of the most well-known examples is the Hafele-Keating experiment, which used atomic clocks on airplanes to demonstrate time dilation due to the planes' high speeds. Additionally, the effects of time dilation are also accounted for in the functioning of GPS satellites, which need to take into account the difference in time between Earth's surface and the satellites' high speeds in order to provide accurate location data.
