Explore the Derivation of f'(x) from f(x) = x^2 + 3x + 6
  • MHB
  • Thread starter Jayden1
  • Tags
    Derivation
In summary: I'm not sure.I just asumed that the turning point of a quadratic would always have a tangent line with a gradient of 0...On a quadratic graph, the gradient will be 0 at the vertex which is also where the graph changes directions. If you have a quadratic in the form of f(x)=ax^2+b then the gradient at x=0 is 0 but your equation is different. I think...I'm not sure.
Jayden1
So I started with this function: f(x) = x^2 + 3x + 6
I then got this from it:
m = ((((x + h)^2) + (3*(x + h)) + 6) - (x^2 + 3x + 6)) / ((x + h) - x)
Which I eventually simplified to 2x + h^2 + 3h
And then: limit h -> 0: 2x + h^2 + 3h = 2x
So f ' (x) = 2x
Is that right? By doing this, I ended up getting a tangent line gradient of 19 (for x value of 8).
The reason I keep thinking this is wrong is because I thought f(x) = x^2 also ended up with f ' (x) = 2x
Which I eventually simplified to 2x + h^2 + 3h WRONG
It should have simplified to [TEX]2x+h+3.[/TEX]
Can you please show me the steps you took in simplifying to I know what I did wrong.
\(\displaystyle \frac{(x+h)^2+3(x+h)+6-(x^2+3x+6)}{h}\)
\(\displaystyle \frac{x^2+2xh+h^2+3x+3h+6-x^2-3x-6}{h}\)
\(\displaystyle \frac{2xh+h^2+3h}{h}\)
What h are you supposed to get rid of at this point?
We need to get rid of h because you can't divide by 0. It's just unclear which one of the numerator h's should be divided out...
Or are you supposed to divide every part by h. So you get 2x + h + 3?
is h^2 / h = h?
EDIT: I get it now. Just blame my terrible fractions skills.
Hi Jayden, :)
\[m=\frac{((x + h)^2 + 3(x + h) + 6) - (x^2 + 3x + 6)}{(x + h) - x}\]
\[\Rightarrow m=\frac{x^2+2hx+h^2+3x+3h+6-x^2-3x-6}{h}\]
\[\Rightarrow m=\frac{2hx+h^2+3h}{h}\]
\[\Rightarrow m=\frac{h(2x+3+h)}{h}\]
\[\therefore m=2x+3+h\]
By the way Jayden, as I http://www.mathhelpboards.com/threads/1180-Help-with-limits-tangent-line?p=5743&viewfull=1#post5743, it would be better if you can refresh your knowledge about the order of operations. :)
Kind Regards,
Sudharaka.
Sudharaka said:
Hi Jayden, :)
Kind Regards,
Sudharaka.
Saved my life with that. It's not that I don't know the order. It's that I forget things like what you just did with factoring out h. I always forget these things and it makes me get them wrong -.-
Computing derivatives like this always depends on factoring out an "h" at the end and canceling it with an "h" in the denominator, otherwise you divide by 0 and it won't work. So with these problems always be looking for a way to factor out and cancel an "h".
1 question. If you end up with 2x + h + 3.
Then limit -> 0 to get 2x + 3...
f ' (0) = 2*0 + 3
f ' (0) = 3.
Shouldn't the tangent line to x = 0 have a gradient of 0 not 3?
Jayden said:
f ' (0) = 3.
Why in the world would you say that?
Why should the tangent at x=0 be any particular value?
f ' (0) = 2*0 + 3
f ' (0) = 3.
It doesn't always have to be 0. You'll find tons of examples where it's not 0 so don't worry. In this case it should be 3 at x=0 so everything is good. :)
lets say we plot the point a on (0, f(0)) (the function being f(x) = x^2 + 3x + 6)
now the derivative of f(x) = x^2 + 3x + 6 is apparently f ' (x) = 2x + 3
f ' (a) = 2*a + 3
f ' (a) = 2*0 + 3
f ' (a) = 3
Is there a different method of getting the derivative with functions like x^2 and f(x) = x^2 + 3x + 6 ?
EDIT: Awesome. Thanks Jameson. I just asumed that the turning point of a quadratic would always have a tangent line with a gradient of 0...
On a quadratic graph, the gradient will be 0 at the vertex which is also where the graph changes directions. If you have a quadratic in the form of \(\displaystyle f(x)=ax^2+b\) then the gradient at x=0 is 0 but your equation is different. I think the original question is answered so keep the questions coming if you want and make a new thread!
FAQ: Explore the Derivation of f'(x) from f(x) = x^2 + 3x + 6
What is the formula for finding the derivative of a quadratic function?
The formula for finding the derivative of a quadratic function, such as f(x) = x^2 + 3x + 6, is f'(x) = 2x + 3. This can be derived using the power rule, which states that for a function of the form f(x) = x^n, the derivative is f'(x) = nx^(n-1).
How do you derive the formula for f'(x) from f(x) = x^2 + 3x + 6?
To derive the formula for f'(x), we first use the power rule to find the derivative of each term in the function. The derivative of x^2 is 2x, the derivative of 3x is 3, and the derivative of 6 is 0. Combining these derivatives, we get f'(x) = 2x + 3. This is the formula for the derivative of f(x) = x^2 + 3x + 6.
What is the significance of the derivative of a function?
The derivative of a function represents the rate of change of the function at any given point. It can also be thought of as the slope of the tangent line to the function at a specific point. The derivative is used to find the maximum and minimum points of a function, as well as to solve optimization problems.
Can the derivative of f(x) be negative?
Yes, the derivative of f(x) can be negative. This means that the function is decreasing at that point, and the slope of the tangent line is negative. For example, the derivative of f(x) = -x^2 is f'(x) = -2x, which is negative for all values of x.
How is the derivative of a function used in real-world applications?
The derivative of a function is used in many real-world applications, such as physics, engineering, and economics. It can be used to calculate velocity and acceleration, find the optimal production level for a business, and determine the maximum profit for a product. Essentially, the derivative helps us understand how a function is changing and how we can use that information to make decisions.
