Exploring Exoplanets: Could We Zoom In on Their Surfaces?
In summary, it is physically impossible for us to collect enough light from a planet in a distant planetary system with our current technology to achieve a resolution that would allow us to see surface features. This is due to the diffraction limit and the overwhelming brightness of the parent star. Even using the sun as a gravitational lens or utilizing advanced techniques such as interferometry would not be enough to overcome these challenges. However, there are proposed methods such as using an occulter or numerical solutions that may offer some potential for improving resolution in the future.
hiddenvariabl
I keep seeing reports about how all the planets similar to Earth in other nearby planetary systems are now being discovered. Since we won't have the technology to send probes or go there ourselves for some time, all we can do is look at them. My question is: Could we ever get better resolution images of those planets with a telescope located in our solar system? In other words can we ever make telescopes that can zoom in on the surface of another planet in another planetary system or is it just physically impossible for us to collect that much light from something so far away? Wouldn't we need a telescope with a really big collection area to do so?
Astronomy news on Phys.org
Let's start with the easy questions - where are you going to find millions of square miles of glass for your lense?
How about using the sun as gravitational lense? If we can't do that we could work with interferometers.
Having a big collection area in order to be able to see fainter and fainter objects is always helpful, but it's not the primary reason why you'd need a REALLY big telescope. Due to diffraction, the fundamental physical limit on your angular resolution (the minimum angular separation of two points that you can resolve as being distinct from each other) is determined by your telescope aperture size. In fact, your diffraction limit scales inversely with telescope diameter (and it scales linearly with wavelength). At a wavelength of 550 nm, in order to have an angular resolution corresponding to a physical object size of 1 Earth radius at the distance to Alpha Centauri (the closest star at ~4.3 ly), you'd need a telescope aperture of >4200 m in diameter. That's more than 100 times larger in diameter than the largest optical telescope that's currently even being proposed to be built (I believe that TMT is supposed to be 30 m and E-ELT is supposed 40 m). And that's just to get an angular resolution such that the smallest feature you can see in your image is about 6400 km at the distance of the closest star (which is an angular resolution of about 1.5x10-10 radians or 32 microarcseconds. To see features of 10 km in size at that (unrealistically close) distance you'd need a telescope aperture of almost 3 million metres (3000 km or almost half an Earth radius). Since the diffraction limit size scales linearly with wavelength, the situation would be even worse in the infrared (where the contrast ratio of the planet's emission to the emission from its parent star is much more favourable).
Contrast ratios are another important point. A good analogy is that directly (visually) detecting a planet is like "looking for a firefly next to a searchlight." Its tiny emission is going to get drowned out in the much much larger emission from its parent star, which is at least 10,000 times brighter, but probably a few factors of 10 more. On those few occasions in which direct imaging of planets was achieved, the light from the parent star was blocked out using an occultation disk. But even then, there was all kinds of messy spillover light that (again due to diffraction and imperfections in the optics) looked like speckles. Guess what? Any planets that might have been there would have looked very much like these speckles. Very fancy image processing techniques had to be employed in order to even see which features were real objects and which were due to optical artefacts in the image. It was also necessary to observe the same system on multiple occasions that were widely separated in time (in order to try and discern the orbital motion of the planets). So, astronomers have enough trouble as it is identifying whether or not a planet is present in an image let alone resolving it into a disc, let alone resolving surface features on that disc.
You mean apart from the fact that the sun is in your way? Your next problem is that a gravitational lens doesn't have a true focal point. The one after that is that the image, such as it is, is out way past Pluto.
Agreed, you would need a big chunk of glass. Our largest telescopes strain to view the nearest stars as anything more than a point source.
This problem can simply be solved by an occulter.
This problem can be solved numerically: http://arxiv.org/pdf/astro-ph/0304162v1
This problem can be solved with swing by and a lot of time.
Yes
http://www.oamp.fr/lise/publis/labeyrieAA96.pdf
The problem isn't light collection. The problem is that since light is a wave, you have to have a big telescope to keep the light from spreading.
But it's only ten times larger than the largest interferometers that are now in operation. CHARA has a baseline of 300m and COAST has a baseline of 100m.
There's no engineering reason I can think of that we can't build a 10km space interferometer.
The problems are political and financial, which unfortunately trumps engineering.
http://en.wikipedia.org/wiki/Terrestrial_Planet_Finder
http://en.wikipedia.org/wiki/Space_Interferometry_Mission
The question is not can we image extrasolar planets. The real question is do we think it's important enough to try.
I am unfamiliar with the details of an interferometer. Is it possible to have 2 relatively small telescopes set 10km apart as an interfermoeter?
Yes.
Also with radio waves it's possible to have two telescopes on the different parts of the Earth and then "electronically" combine the readings to give you a telescope that is effectively the size of the planet.
twofish-quant said:
Yes.
Any idea how difficult it would be to set up a small interferometer as an amatuer?
Actually, we might be pretty close to having the technology to send a probe, although we'd be long dead before our distant descendants got any information from it. The Kepler system is out of reach, but a nearby star might make an interesting goal. (In reality, of course, only the most dedicated of visionaries would be willing to fund such a project.)
Not at all easy. Radio dishes have to be pretty large ... and you need some very heavy-duty computing power.
(I don't think you can do optical interferometry, because the interference patterns would be much smaller than the sensor elements of a CCD. Two optical telescopes, even if many miles apart, will generate identical images.)
Yep, we can do optical interferometry. http://en.wikipedia.org/wiki/Astronomical_interferometer
Well, yes ... but "we" doesn't include amateurs. Optical inteferometers require you to merge the light (not the images) from the two telescopes, with mind-boggling precision. It's quite amazing, really, that the professionals -- multi-million-dollar budgets notwithstanding -- can do it at all.
Ah ok I see what you meant. Well, never say never, but you're probably right.
e.g. something like this: http://www.spacedog.eu/astronomy/historic-astronomy/first-ligth-for-virtual-360-000km-telescope.html
That...is...awesome...
There are a lot of people doing amateur radio interferometer.
http://www.radio-astronomy.org/node/185
And speckle interferometry with a webcam...
http://www.jdso.org/volume4/number3/caloi.pdf
Also anything in which the bottleneck is computing power is going to be quickly amateurized.
I'm not convinced it can't be done. There are people doing amateur holography
FAQ: Exploring Exoplanets: Could We Zoom In on Their Surfaces?
What exactly are exoplanets?
Exoplanets are planets that orbit stars other than our Sun. They can range in size from small rocky planets to gas giants like Jupiter.
Why is it important to study exoplanets?
Studying exoplanets can help us better understand our own solar system and the formation of planets. It can also provide insights into the potential for habitable environments and the possibility of extraterrestrial life.
How do scientists find and study exoplanets?
Scientists use a variety of methods to find and study exoplanets, including the transit method (observing a planet passing in front of its star), the radial velocity method (measuring the wobble of a star caused by an orbiting planet), and direct imaging (taking pictures of the planet itself).
What do we know about the surfaces of exoplanets?
Currently, we have limited information about the surfaces of exoplanets. Most of our knowledge comes from indirect methods, such as analyzing the composition of their atmospheres. However, with advances in technology, we are starting to gather more data about the surfaces of exoplanets.
Could we ever zoom in on the surfaces of exoplanets?
It is possible that in the future, with more advanced telescopes and imaging techniques, we will be able to directly observe and study the surfaces of exoplanets. However, due to the vast distances involved, it may still be difficult to get a clear picture of the surface details of these planets.
