Exploring How Radio Waves Make Electrons Move
In summary, the movement of electrons in an antenna to generate an induced current is caused by the force exerted on them by the oscillating electric and magnetic fields of an incoming radio wave. This creates oscillating currents in the antenna, which can then be encoded. The electric and magnetic fields are not cancelled out by each other, even though they are perpendicular, due to the complex and dynamic nature of the situation. The voltage induced on a short conductor can be calculated by multiplying its length by the incoming E-field. However, it is the electric field that primarily causes the movement of electrons, not the magnetic field.
FilipLand
52
Hi!
What exactly makes electrons in the antenna move to generate an induced current which then can be encoded?
Is it radio waves that hits the antenna and makes the electrons move? If so, why/how? :)
All I get from this link is that "the radio waves makes the electrons wiggling back and forth", but how? http://www.explainthatstuff.com/radio.html
Thank you!
I found the same thing here "during reception, the oscillating electric and magnetic fields of an incoming radio wave exert force on the electrons in the antenna elements, causing them to move back and forth, creating oscillating currents in the antenna."
A radio wave is a electromagnetic wave, does not the force from the magnetic field and the electric field (acting on an electron in the antenna) cancel each other out? Because the B and E-field is perpendicular right?
FilipLand said:
Thank you!
FilipLand said:
Thank you!
My view is that it is the electric field which causes the electrons to move and stationery electrons are not moved by a magnetic field.
The voltage induced on a short conductor can be found by multiplying its length by the incoming E-field.
The E and B fields are perpendicular to each other, but that doesn't cancel out the force on the electrons.
Perhaps, but the electrons are not stationary in an antenna receiving a signal. The electric and magnetic fields aren't static either, so you really have a complicated situation.
Likes davenn
Related to Exploring How Radio Waves Make Electrons Move
1. How do radio waves make electrons move?
Radio waves are a type of electromagnetic radiation that carry energy and information through space. When these waves encounter an object, such as an antenna, the oscillating electric and magnetic fields of the wave interact with the electrons in the object. This interaction causes the electrons to move, thus transferring the energy and information carried by the radio wave.
2. What is the relationship between radio waves and electrons?
Radio waves and electrons are both part of the electromagnetic spectrum. They are both forms of energy and can interact with each other. Radio waves are used to carry information and energy, while electrons are the particles that make up matter and can be moved by the energy of the radio wave.
3. How are radio waves used in modern technology?
Radio waves are used in a variety of modern technologies, including radio and television broadcasting, cellular phones, Wi-Fi, and GPS. They are also used in medical imaging, such as MRI machines, and in radar systems for navigation and communication.
4. Can radio waves be harmful to humans?
In general, radio waves are not considered harmful to humans. However, at high enough frequencies and intensities, radio waves can cause damage to living tissue. This is why safety standards and regulations are in place to limit exposure to certain types of radio waves, such as those used in cell phones.
5. How do scientists study the effects of radio waves on electrons?
Scientists use a variety of methods and experiments to study the effects of radio waves on electrons. This can include using specialized equipment, such as antennas and receivers, to detect and measure the movement of electrons. They may also use simulations and mathematical models to understand and predict the behavior of electrons in the presence of radio waves.
  • Electrical Engineering
  • Quantum Physics
