Exploring Integer Ordered Pairs in a Unique Equation
  • MHB
  • Thread starter juantheron
  • Tags
    Integer
In summary, the number of positive integer ordered pairs (a,b) in the equation 4^a+4a^2+4=b^2 is limited to a maximum of 6 for a. This is because when we simplify the equation, we can see that it is equivalent to 4^a + 4a^2 + 4 < (2^a+1)^2. This means that we cannot have a perfect square for b because we are always less than the next square. Therefore, we only need to check for a = 1 to a = 6 for possible solutions.
juantheron
247
The no. of positive Integer ordered pair $(a,b)$ in $4^a+4a^2+4 = b^2$
Mathematics news on Phys.org
it may have a solution as 4^a = 2^ 2a
if
(4^a + 4a^2 + 4) >= (2^a+1)^2
or 2 * 2^a + 1 <= 4a^2 + 4
this gives a <= 6 and we need to check for a = 1 to 6.
rest is trivial
To kaliprasad
I did not understand it
it may have a solution as $4^a = 2^ {2a}$
if $\left(4^a + 4a^2 + 4 \right) >= (2^a+1)^2$
or $2 \cdot 2^a + 1 \leq 4a^2 + 4$
this gives $a\leq 6$ and we need to check for $a =1$ to $a = 6$
rest is trivial
would you like to explain me.
Thanks
jacks said:
To kaliprasad
rest is trivial
Thanks
you know 4^a = (2^2a) = (2^a)^2
so square root is 2^a
next square has to be (2^a+ 1)^2
if 4^a + 4a^2 + 4 < (2^a+1)^2 we cannot have a pefect squre because we are less than the next square
FAQ: Exploring Integer Ordered Pairs in a Unique Equation
What are integer ordered pairs?
Integer ordered pairs refer to a set of two integers, written in the form (a,b). The first integer, denoted by a, is called the x-coordinate and the second integer, denoted by b, is called the y-coordinate. These coordinates represent a specific point on a graph.
How are integer ordered pairs represented?
Integer ordered pairs are typically represented on a coordinate plane, which is a grid with two perpendicular number lines. The horizontal axis represents the x-coordinate and the vertical axis represents the y-coordinate.
What is the relationship between integer ordered pairs and equations?
Integer ordered pairs can be used to graph equations. Each point on the graph represents a solution to the equation and can be represented as an integer ordered pair. Similarly, given an integer ordered pair, an equation can be written to represent the point on the graph.
How are integer ordered pairs used in real-life situations?
Integer ordered pairs are used to represent and analyze real-life situations that can be graphed. For example, they can be used to represent the relationship between time and distance in a car trip or the relationship between cost and quantity in a business.
What are some properties of integer ordered pairs?
Some properties of integer ordered pairs include symmetry, where the point (a,b) is symmetric to the point (-a,-b) with respect to the origin, and distance, where the distance between the points (a,b) and (c,d) can be calculated using the Pythagorean theorem.
