- #36
Jonathan Scott
- 1,152
The scale and shape of space and time is determined by the sum of m/r which is generally dominated by distant masses everywhere in the observable universe (except when very close to compact objects), regardless of how empty it is locally.PeterDonis said:But even in our actual universe there are regions where there are no masses but only vacuum--yet it is not "the distant stars" that immediately determine which states of motion are inertial and which are not in such regions, but the local geometry of spacetime (at least according to GR). So for the interpretation of Mach's Principle that you appear to be using, even the GR solution that describes our actual universe does not satisfy Mach's Principle. In other words, I don't think the interpretation of Mach's Principle that you appear to be using only requires that spacetime can only exist if there are masses somewhere in it; I think the interpretation you are using requires that there is some invariant meaning to "the distance from here to distant masses" at every event, even events in the middle of a vacuum region. GR does not satisfy that requirement.
GR requires additional boundary conditions to match it to the actual universe, and it does not give a reason for the actual value of G. For the actual universe, the sum of Gm/rc^2 is of order 1, which is very Machian and suggests a relationship between G and the distribution of mass in the universe, which might for example turn out to be related to such boundary conditions via additional physical constraints on GR or something similar.
