Exploring Microscopic Particles: Interactions & Measurement
In summary, the conversation discusses the nature of non-interacting microscopic particles and their values of physical parameters, the use of probability distributions to explain the behavior of particles in experiments, the concept of measurement and its role in quantum mechanics, and the extrapolation of classical ideas and equations in quantum mechanics. The conversation also raises questions about the foundation of quantum mechanics and the limitations of our understanding of particles when they are not interacting.
Suryabarta Saha
1.How is that possible for us to say that a non-interacting microscopic particle can have numerous values of a physical parameter in a given instant? the mixed state of a microscopic particle is simply the probability distribution of the particle having those values of a given physical parameter if a measurement/interaction with a macroscopic object takes place. When a particle doesn't interact how we can know what it really is?
2.From the single photon/electron double slit experiment i.e the interference pattern of separate,discrete particles and the apparent break of casualty, we arrived at the conclusion that it can't really have a trajectory (i.e a definite position at any given instant, so it can't have a definite velocity, lenear momentum, angular momentum, kinetic energy etc. at any given instant in a classical sense) and we have to treat it as a complex probability wave function in between source and screen. Photons/electrons are always registered as discrete particles, it originates as a discrete particle at the source and vanishes as a discrete particle at the screen/detector, to give a reasonable explanation of the interference pattern, from source to screen we have to consider it as a wave of probability which fills up the space between source and screen. Moreover we declared the particle isn't going through one particular slit to protect the casualty.
a)But can we really know what electron/photon is between the emitter and the screen(detector) ? I know we can't separate a particle from its 'associated' probability wave or think it as a discrete classical particle but don't we have a very vague idea about what it really is when it does't interract i.e measured?
b) what makes it to take a perticular/definite value of a physical parameter when measured?
c)What is the meaning of 'measurement' we are talking about? it isn't any kind of interaction, an interaction with another microscopic particle doesn't count as a 'measurement'. An electron in a hydrogen atom interacts with the proton, it isn't a 'measurement'.
d)Does 'measurement' really mean interaction only with macroscopic objects like the screen/detector? but the detector is also made of microscopic particles. If Quantum mechanics use 'interaction with macroscopic objects' as the physical foundation then how it can be a fundamental theory from which we will derive the macroscopic physics?
3.Lastly in our textbooks it seems there are extrapolation of classical ideas/equations in qm, as an example how can we take a term which 'represents the repulsive coulomb interaction between the i-th and j-th electron'? Even in classical physics when a charge is moving it's electric field is not given by coulomb's law. So how can we use potential energy term derived from coulomb's law in Schrodinger equation of many-eletron atom. When the position of an electron is not defined classically how are we even using |ri−rj|? When we are talking about electric field created by an electron in an atom it's obviously not an classical electrostatic situation, electrons are accelerating charged particles (Though I don't clearly understand what 'acceleration' of a microscopic particle means, and whether it's right to use the term 'moving' for something whose physical parameters aren't defined uniquely)
We can’t. Quantum mechanics doesn’t even try - it is a theory about the results of interactions and refuses to answer questions about what is happening in between.
Likes dextercioby, Dale and Suryabarta Saha
But then the question remains: if QM uses 'interaction with macroscopic objects' as the foundation, then how it is a 'fundamental' from which we can built up macroscopic physics?
what makes it to take a perticular/definite value of a physical parameter when measured?….What is the meaning of 'measurement' we are talking about? it isn't any kind of interaction, an interaction with another microscopic particle doesn't count as a 'measurement'. An electron in a hydrogen atom interacts with the proton, it isn't a 'measurement'.
A measurement is an interaction that is thermodynamically irreversible. A Google search for “quantum decoherence” will bring up some good references, and David Lindley has written a good layman-friendly book on the subject: “Where does the weirdness go?”
Likes dextercioby, vanhees71 and Suryabarta Saha
We cannot, so we don't make any such claims.
The double slit experiment doesn't break causality.
Because it works.
This is really the only reasonable question you have in your long post. All of the rest of them are based on misunderstandings.
Your post is really all over the place. This is a fallacious style of argument called the "Gish Gallop", and is made famous by politicians. This is not an appropriate form of discussion in politics and certainly not appropriate for physics forums. I am closing this thread.
Please choose ONE topic, and expand on that ONE topic in sufficient detail that the reader can understand your key concerns and reasoning. We can see the obvious Gish Gallop and do not appreciate it being used here. Focus on your strongest concern only.
Likes Vanadium 50
FAQ: Exploring Microscopic Particles: Interactions & Measurement
What are microscopic particles?
Microscopic particles are tiny entities that are too small to be seen with the naked eye. They include atoms, molecules, and various nanomaterials. These particles often require specialized instruments such as microscopes or other high-resolution imaging techniques to be observed and studied.
How do microscopic particles interact with each other?
Microscopic particles interact through various forces such as electromagnetic forces, van der Waals forces, and chemical bonds. These interactions can lead to the formation of larger structures, influence the physical properties of materials, and drive chemical reactions. The nature of these interactions is often studied using principles from quantum mechanics and thermodynamics.
What techniques are used to measure microscopic particles?
Several techniques are used to measure microscopic particles, including electron microscopy, atomic force microscopy, and dynamic light scattering. Each technique has its own strengths and limitations, and the choice of method depends on the specific properties and scale of the particles being studied. Other methods like spectroscopy and diffraction techniques are also commonly used.
Why is it important to study microscopic particles?
Studying microscopic particles is crucial for advancing our understanding of fundamental scientific principles and for the development of new technologies. Insights gained from this research can lead to innovations in fields such as materials science, medicine, environmental science, and nanotechnology. For example, understanding the behavior of nanoparticles can lead to breakthroughs in drug delivery systems and the creation of new materials with unique properties.
What challenges are faced in the study of microscopic particles?
One of the main challenges in studying microscopic particles is the difficulty in observing and manipulating them due to their small size. Additionally, accurately characterizing their interactions and behaviors often requires sophisticated and expensive equipment. Another challenge is the complexity of theoretical models needed to describe these interactions, which often involve advanced mathematics and computational simulations.
