Exploring Multi-Variable Integral Limits with $\sin(t)/t$
In summary, Boas provides a basic example of an integral with a multi-variable limit, but does not explain the concept of partial derivatives. I attempted to start from the basic and used:$$\frac {dF}{dx}=f(x) \Rightarrow \int_a^b f(t) dt = F(b) - F(a)$$. I then tried to solve the problem by using the formulas for integration, but I don't understand what is ##\frac{\partial u}{\partial x}; \frac{\partial u}{\partial y}; \frac{\partial y}{\partial x}##.
agnimusayoti
240
23
If $$u=\int_{x}^{(y-x)} \frac{sin t}{t} dt$$. Find ##\frac {\partial{u}}{\partial{x}}. \frac {\partial{u}}{\partial{y}}, \frac {\partial{y}}{\partial{x}}## at ##x=\frac{\pi}{2}; y=\pi##
Leibniz Rule.
Because the limit of the integral is multi-variable, which is not explained at the ML Boas's example, I tried to start from the basic. First, I use:
In my case now:
$$\int_{u(x)}^{v(x,y)} f(t) dt = F(v(x,y)) - F(u(x))$$
So,
$$\frac {d}{dx} \int_{u(x)}^{v(x,y)} f(t) dt = \frac {d}{dx} [F(v(x,y)) - F(u(x))]$$
$$\frac {d}{dx} \int_{u(x)}^{v(x,y)} f(t) dt = \frac {d}{dv} [F(v(x,y))]\frac {dv(x,y)}{dx} - \frac {d}{du} F(u(x)) \frac {du(x)}{dx}$$
$$\frac {d}{dx} \int_{u(x)}^{v(x,y)} f(t) dt = f(v) \frac {dv(x,y)}{dx} - f(u) \frac {du(x)}{dx}$$
where
$$dv(x,y)= \frac {\partial v}{\partial x} dx+\frac {\partial v}{\partial y} dy$$
So,
$$\frac {dv(x,y)}{dx}= \frac {\partial v}{\partial x} +\frac {\partial v}{\partial y} \frac {dy}{dx}$$
Now,
I put the detail on the question, where:
$$f(t) = \frac{\sin (t)}{t}$$
##v(x,y) = y - x/t## then ##dv = dy - dx##. So, ##\frac {\partial v}{\partial x}=-1## and ##\frac {\partial v}{\partial y} = 1##.
Now, with this, can I solve the problem? Thanks...
From your first post, the integral is ##u=\int_{x}^{(y-x)} \frac{sin t}{t} dt##
u is a function of both x and y. The Fundamental Theorem of Calculus is your friend here. In part, it says that $$\frac d{dx} \left(\int_a^x f(t)dt \right) = f(x)$$
A difference with your problem is that the integral is a function of both x and y, rather than just x, so partial derivatives are called for.
A pair of useful formulas are
##\int_a^b f(t)dt = -\int_b^a f(t)dt## -- I.e., switching the integration limits results in a sign change.
##\int_a^b f(t)dt = \int_a^c f(t)dt + \int_c^b f(t)dt## -- this one is helpful in changing one of the integration limits in your problem to a constant.
Does Boas mention these concepts?
No. Maybe Boas think the student should've understood this concept in Calculus class. However, the second one is lost in my mind. Huah.
Then, what should I do after changing the integration limits? Thanks
If you've already had a course in which one topic was integration, then, yes, it's a reasonable assumption on the part of Mary Boas.
Here's from your first post:
agnimusayoti said:
If ##u=\int_{x}^{(y-x)} \frac{sin t}{t} dt##. Find ##\frac {\partial{u}}{\partial{x}}. \frac {\partial{u}}{\partial{y}}, \frac {\partial{y}}{\partial{x}}## at ##x=\frac{\pi}{2}; y=\pi##
From the above, u is a function of x and y, so u = g(x, y) = ##\int_x^{y -x}\frac{\sin t}t dt##.
Split the integral into two integrals, like so:
$$u = \int_x^c \frac{\sin t}t dt + \int_c^{y - x} \frac{\sin t}t dt \\
= -\int_c^x \frac{\sin t}t dt + \int_c^{y - x} \frac{\sin t}t dt$$
Now take the partial with respect to x, using the Fundamental Theorem of Calculus (part of which I wrote in my earlier post).
This is the trick -- I'm afraid your work in post #1 was a wasted effort.
Similar idea to find ##\frac{\partial u}{\partial x}##. When you get those, we can look at ## \frac{\partial y}{\partial x}##.
From your suggestion, I did this:
Take differential on both sides:
$$du=-d{\int_{c}^{x} \frac{\sin t}{dt}} + d{\int_{c}^{y-x} \frac{\sin t}{dt}}$$
$$du=\frac{\sin {x}}{x} \frac {\partial {x}}{\partial x} dx +\frac{\sin (y-x)}{y-x} {\left[\frac {\partial \left(y-x \right)}{\partial x} dx +\frac {\partial {\left (y-x \right)}}{\partial y} dy \right]}$$
$$du=\frac{\sin {x}}{x} (1) dx +\frac{\sin (y-x)}{y-x} {\left[(-1) dx +(1) dy \right]}$$
$$du=\left [\frac{\sin {x}}{x} - \frac{\sin (y-x)}{y-x} \right] dx +\left[\frac{\sin (y-x)}{y-x} \right] dy$$
So:
$$\frac {\partial u}{\partial x} = \frac{\sin {x}}{x} - \frac{\sin (y-x)}{y-x} $$
$$\frac {\partial u}{\partial y} = \frac{\sin (y-x)}{y-x} $$But, I don't understand how to find ##\frac {\partial y}{\partial x}##?
This makes no sense. You can't have dt in the denominator of the integral, and you lost the t that was in the denominator.
Here's an example that uses the Fund. Thm. of Calculus.
##f(x) = \int_a^x \sin^2(t)dt##
##\Rightarrow f'(x) = \frac d{dx} \int_a^x \sin^2(t)dt = \sin^2(x)##
Notice that I don't ever attempt to actually perform the integration.
So:
I didn't wade through all of your work above, because it was wrong in the very first line. What you have below might be the correct answer (is it shown in the textbook's solution?), but your work doesn't support it.
If x and y are independent of each other then ##\frac {\partial y}{\partial x} = 0##.
I think i was mistaken in typing. I mean sin t/t dt. Yes that is the solution andthe solution of $$\frac {\partial y}{\partial x}=-\frac{\frac {\partial u}{\partial x}}{\frac{\partial u}{\partial y}}$$. But i don't know how it can be. The solution is only numeric solution since the problem ask the numeric solution at ##(\pi/2, \pi)##
Why i perform differential is because the book suggest to take differential. Thankss
I just noticed this near the bottom of post #1:
v appears to be a function of three variables: x, y, and t, not just x and y.
Is t in the expression y - x/t in there by mistake? The first integral below has y - x as the upper limit of integration, not y - x/t.
These are from elsewhere in post #1.
<snip>
##\frac {d}{dx} \int_{u(x)}^{v(x,y)} f(t) dt ##
I don't have the book, so I don't know what suggestions were given, but the problem is to find the partial derivatives of u (the integral) with respect to x and to y.
In my first post, I think I define so many functions and the same idea is used in your method to separate the limits of integration. By this, I can use fundamental theorem's of calculus since
$$\frac {d}{dx} \int_{x}^{c} \frac {\sin t}{t} dt = - \frac{ \sin x}{x}$$.
Nah, in #6 post, I did a mistake at earlier line, that is at 1st and 2nd line (actually they are the same). In that post, I write:
It supposed to be:
$$du=-d{\int_{c}^{x} \frac{\sin t}{t} dt} + d{\int_{c}^{y-x} \frac{\sin t}{t} dt}$$
Yeah, I'm afraid that was a mistake too. TT
So sorry for this mistake.
But, how about the ##\frac {\partial y}{\partial x}##? Could you explain why the solution seems satisfying this relation:
agnimusayoti said:
But, how about the
No idea, at least based on the information you have presented here.
u is a function of x and y; i.e., we could write u = g(x, y), with g(x, y) being the integral in post #1.
There is no information shown here about a relationship between x and y, so we would conclude that ##\frac {dy}{dx} = \frac{\partial y}{\partial x} = 0##.
Is there some information you have left out?
I think I have an idea.
Maybe I can modify this to:
$$du- \left [\frac{\sin {x}}{x} - \frac{\sin (y-x)}{y-x} \right] dx = \left[\frac{\sin (y-x)}{y-x} \right] dy$$
Therefore I have y(u,x).
So,
$$\frac {\partial y}{\partial x}= \frac {- \left [\frac{\sin {x}}{x} - \frac{\sin (y-x)}{y-x} \right] }{\left[\frac{\sin (y-x)}{y-x} \right] } $$
Since, $$\left [\frac{\sin {x}}{x} - \frac{\sin (y-x)}{y-x} \right] = \frac {\partial u}{\partial x}$$ and $$\left[\frac{\sin (y-x)}{y-x} \right] = \frac {\partial u}{\partial y}$$ there fore,
$$\frac {\partial y}{\partial x}= - \frac {\frac {\partial u}{\partial x}}{\frac {\partial u}{\partial y}} $$
This idea just popped out when I see the equation again and again and again. Oh gee. But, thanks for your method, Mark44.
Let me stop you right there. The original equation ##u = \int_x^{y - x} \frac{\sin t} t~dt##.
The suggestion to calculate the total differential is a good one, so we have:
$$du = \frac{\partial u}{\partial x} dx + \frac{\partial u}{\partial y} dy$$
Here the first partial derivative is the partial derivative of the integral with respect to x, and the second one is the partial derivative of the integral with respect to y.
To get each partial derivative, you have to use the Fundamental Theorem of Calculus, as I have been saying several times.
So, I get this for ##\frac {\partial u}{\partial x}##:
$$\frac {\partial u}{\partial x} = \frac{ -\sin x} x - \frac{\sin(y - x)}{y - x} $$
This is different from what you have.
For ##\frac {\partial u}{\partial y}##, I get the same as what you show below.
agnimusayoti said:
So,
This makes no sense algebraically. What happened to ##du## in your equation in the first quote?
Are you getting this from a solution published in the Boas book? If so, I don't see that your work supports this conclusion.
Why negative?
No, the book just give final numeric solution.
I move dx from right side to the left, so I have y as a function of u and x.
But, it's interesting that with your work is very simple. Could you explain how you get $$\frac {\partial u}{\partial x}$$ instantly? Thanks.
agnimusayoti said:
Why negative?
Like I said before, that algebra doesn't work.
Here's what you had before:
No, you don't have y as a function of u and x. What you have is an equation that involves x, y, dx, dy, and du.
So,
$$\frac {\partial y}{\partial x}= \frac {- \left [\frac{\sin {x}}{x} - \frac{\sin t}{t} \right] }{\left[\frac{\sin (y-x)}{y-x} \right] } $$
And somehow, u completely disappeared. That's why I said that the algebra doesn't work.
Edit: Fixed an error I had in one of the integrals.
Well, it wasn't instantly, but it wasn't too hard.
##\frac {\partial u}{\partial x} = \frac \partial {\partial x} \left(\int_x^c \frac{\sin t}{t} dt + \int_c^{y-x} \frac{\sin t}{t}dt\right)##
##= \frac \partial {\partial x} \left(-\int_c^x \frac{\sin t}{t} dt + \int_c^{y-x} \frac{\sin t}{t}dt\right)##
The first term simplifies to ##-\frac{\sin x}{x}##. The other term simplifies to ##\frac{\sin(y - x)}{y - x} \cdot (-1)##. That final factor of -1 comes from using the chain rule: ##\frac \partial {\partial x} (y - x) = -1##.
Likes agnimusayoti
@Mark44 at your last post the second term inside the equality for ##\frac{\partial u}{\partial x}## should be $$\int_c^{y-x}\frac{\sin t}{t} dt$$ right? I believe you have a "serious" typo there (probably something that occurred from copy/paste thing))
Note: I (Mark44) had an error in the post quoted below. I have fixed the error in my post as well as in the quoted material below.
Well youre right about this. But I am pretty sure about /partial y and x. Because implicitly there is a function of y(x,u)?
Yes, you are right. The integrand should be ##\frac{\sin t}{t}## throughout. I have edited my earlier post.
Not a copy/paste error, I was just thinking too far ahead of what I was typing.
Likes Delta2
agnimusayoti said:
Note: I had an error in the post quoted below. I have fixed the error in my post as well as in the quoted material below.
I think I understand what you're trying to say, but that's different from what you're actually saying. When you write y(x, u), you're saying that y is a function of x and u (which is a function of x and y).
For this problem, I think we can get ##\frac{\partial y}{\partial x}## from this relationship:
$$\frac{\partial y}{\partial x} = \frac{\frac{\partial u}{\partial x}}{\frac{\partial u}{\partial y}} $$
Negative isn't it? Because, if
$$du=\frac{\partial u}{\partial x} dx +\frac{\partial u}{\partial y} dy $$
then
$$du - \frac{\partial u}{\partial x} dx = \frac{\partial u}{\partial y} dy $$
To make total differential y in terms of dx and du, I divide both sides with ##\frac{\partial u}{\partial y}##:
$$\frac{1}{\frac{\partial u}{\partial y}} du- \frac{\frac{\partial u}{\partial x}}{\frac{\partial u}{\partial y}} dx = dy $$
Implicitly:
$$dy = \frac{\partial y}{\partial x} dx + \frac{\partial y}{\partial u} du$$
Then,
$$ \frac{\partial y}{\partial x} = - \frac{\frac{\partial u}{\partial x}}{\frac{\partial u}{\partial y}} $$
I will concede that your work seems correct. I had to try things out with a simpler example.
In my work, I'm going to write partial derivatives with subscripts, so ##u_x## means ##\frac{\partial u}{\partial x}##.
Let ##u = x^2y##
##u_x = 2xy## and ##u_y = x^2##.
From the equation, I can solve for y, with y being an implicit function of x and u.
##y = \frac u {x^2} = ux^{-2}##
So ##y_u = x^{-2}## and
##\frac{\partial y}{\partial x} = y_x = -2ux^{-3} = \frac{-2u}{x^3} = \frac{-2x^2y}{x^3} = \frac{-2y}{x}##
From the formula you derived,
##\frac{\partial y}{\partial x} = -\frac{u_x}{u_y} = -\frac{2xy}{x^2} = \frac{-2y} x##
Likes agnimusayoti
FAQ: Exploring Multi-Variable Integral Limits with $\sin(t)/t$
1. What is a multi-variable integral?
A multi-variable integral is a mathematical concept that involves finding the area under a curve in a multi-dimensional space. It is a generalization of a single-variable integral, which involves finding the area under a curve on a single axis.
2. What is the significance of using $\sin(t)/t$ in multi-variable integral limits?
The function $\sin(t)/t$ is commonly used in multi-variable integral limits because it is a continuous and oscillatory function that allows for a wide range of values to be integrated over. This makes it a useful tool for exploring various limits and evaluating complex integrals.
3. How is the limit of a multi-variable integral calculated?
The limit of a multi-variable integral is calculated by first setting up the integral with the desired function and limits, and then using mathematical techniques such as substitution, integration by parts, or trigonometric identities to evaluate the integral. The limit is then found by taking the limit of the resulting expression as the variables approach their respective limits.
4. Can the limits of a multi-variable integral be changed?
Yes, the limits of a multi-variable integral can be changed as long as the new limits still fall within the original limits. This can be done by using mathematical techniques such as substitution or integration by parts to transform the integral into a new form with different limits.
5. What real-world applications use multi-variable integrals with $\sin(t)/t$ as limits?
Multi-variable integrals with $\sin(t)/t$ as limits have many real-world applications, including in physics, engineering, and economics. For example, they can be used to calculate the work done by a varying force, the electric potential of a charged particle, or the expected value of a stock portfolio over time.
