Exploring Problem 167 in Serge Lang's Complex Analysis
In summary, Problem 167 in Serge Lang's Complex Analysis is a challenging mathematical problem that requires a deep understanding of complex analysis and the ability to apply various techniques and theories. Some possible approaches to solving this problem include using Cauchy's integral formula, the Cauchy-Riemann equations, and the Laurent series expansion. To solve it, one needs to have a strong understanding of complex numbers, analytic functions, contour integration, and series expansions, as well as knowledge of Cauchy's integral formula, the Cauchy-Riemann equations, and the residue theorem. While there are known solutions to this problem, the specific function that satisfies the given criteria may vary.
Dustinsfl
2,281
I am trying to understand a problem in my book (for reference pr 167 Serge Lang Complex Analysis).
f(z) = \frac{1}{z} + \sum_{n = 1}^{\infty}\frac{z}{z^2-n^2}
Let R>0 (is this R representing the radius of convergence?) and let N>2R (where did this come from and why?).
Write $f(z) = g(z)+h(z)$ where
g(z) = \frac{1}{z}+\sum_{n = 1}^{N}\frac{z}{z^2-n^2} \quad\text{and}\quad
h(z) = \sum_{N+1}^{\infty}\frac{z}{z^2-n^2}
g is a rational function and is meromorphic on C (why are rational functions automatically meromorphic?).
We see that g has simple poles at the integers n such that $|n|\leq N$ (why are we looking at the absolute value of n?)
For $|z|<R$ we have the estimate
\left|\frac{z}{z^2-n^2}\right|\leq\frac{R}{n^2-R^2}=\frac{1}{n^2}\frac{R}{1-\left(R/n)\right)^2}
(\frac{R}{n^2-R^2} why is that?)
The denominator satisfies $1-\left(R/n\right)^2\geq 3/4$ for $n>N>2R$ (Why is this?).
R is not a radius of convergence, it is a positive constant whose significance will only emerge later in the proof. Ditto for N.
A rational function is analytic everywhere except where its denominator is zero. The denominator is a polynomial, so it has only finitely many zeros, each of which is a pole of g. Thus g is analytic except at finitely many poles, and is therefore meromorphic.
The poles of g occur at points where $\color{blue}z^2-n^2=0$ for some n with $\color{blue}n\leqslant N.$ Thus $\color{blue}z=\pm n.$ So the poles occur at negative as well as positive points on the real axis.
It doesn't say so, but at this stage we must be assuming that $\color{blue}|n|>N.$ Thus $\color{blue}n^2>N^2>R^2>|z|^2$, and so $\color{blue}|z^2-n^2| > n^2-R^2$ (triangle inequality).
That follows trivially from the fact that $\color{blue}R/n<1/2.$
Since the summation is only cycling through positive values, how would n every be negative?
So for the triangle inequality, $z^2 < R^2\iff z^2-n^2+n^2<R^2\iff z^2-n^2<R^2-n^2\iff |n^2-z^2|<|n^2-R^2|$.
The reason this is confusing is that $n$ is being used in two different senses. In the summation, $n$ is a positive integer. But when indicating the points where $g$ has a pole, it also takes negative values.
In response to your question, Problem 167 in Serge Lang's Complex Analysis deals with the function $f(z)$, which is defined as $\frac{1}{z} + \sum_{n=1}^{\infty} \frac{z}{z^2-n^2}$. The goal of this problem is to understand the behavior of this function and its properties.
First, let's address the notation used in the problem. The letter $R$ in this context is representing the radius of convergence, which is the radius of the largest circle centered at the origin within which the series will converge. The letter $N$ is simply a variable used to represent any number greater than $2R$, which will be explained in the following steps.
Now, let's break down the problem and understand the reasoning behind each step. The first step is to write $f(z)$ as the sum of two functions, $g(z)$ and $h(z)$, where $g(z)$ is a rational function and $h(z)$ is a series. This will help us understand the properties of $f(z)$ better.
Next, we see that $g(z)$ has simple poles at the integers $n$ such that $|n|\leq N$. This means that $g(z)$ will have poles at $n=\pm 1, \pm 2, ..., \pm N$. This is because the denominator of $g(z)$ will be equal to zero at these points, making the function undefined.
Now, we come to the main part of the problem, which is estimating the function $f(z)$ for $|z|<R$. The estimate given in the problem is $|\frac{z}{z^2-n^2}|\leq \frac{R}{n^2-R^2}$. This estimate is based on the fact that for $|z|<R$, the terms in the series will become smaller and smaller as $n$ increases. This is because as $n$ increases, the denominator of the terms, which is $z^2-n^2$, will also increase, making the overall fraction smaller.
The denominator in the estimate, $1-(R/n)^2$, satisfies the inequality $1-(R/n)^2 \geq 3/4$ for $n>N>2R$. This is because for $n>N>2R$, the value of $R
FAQ: Exploring Problem 167 in Serge Lang's Complex Analysis
What is Problem 167 in Serge Lang's Complex Analysis?
Problem 167 in Serge Lang's Complex Analysis is a mathematical problem that involves finding the explicit form of a function that satisfies certain criteria in the complex plane.
What is the significance of Problem 167?
Problem 167 is significant because it is a challenging problem that requires a deep understanding of complex analysis and the ability to apply various techniques and theories to find the solution.
What are some possible approaches to solving Problem 167?
Some possible approaches to solving Problem 167 include using Cauchy's integral formula, the Cauchy-Riemann equations, and the Laurent series expansion.
What are the key concepts and theories needed to solve Problem 167?
To solve Problem 167, one needs to have a strong understanding of complex numbers, analytic functions, contour integration, and series expansions. Knowledge of Cauchy's integral formula, the Cauchy-Riemann equations, and the residue theorem is also crucial.
Are there any known solutions to Problem 167?
Yes, there are known solutions to Problem 167. However, the specific function that satisfies the given criteria may vary depending on the chosen approach and the particular values of the parameters involved in the problem.
