Exploring QM: Is Uncertainty a Physical or Measurable Limitation?
In summary: On the one hand, you can't measure the spin of one particle without affecting the spin of the other particle, and vice versa.On the other hand, if you do measure one particle's spin without measuring the other's spin, then the result is always correlated with the expectation value of the spin of the other particle...This means that you can't take the result of one measurement and use it to calculate the result of the other measurement.This means that you can't take the result of one measurement and use it to calculate the result of the other measurement.In summary, the uncertainty principle states that you can't know both the position and momentum of a subatomic particle with perfect accuracy.
Kevin Chieppo
I'm a hobbyist physicist and I just started studying QM through watching Leonard Susskind's lectures on the Stanford Youtube channel. I get the idea of it being impossible to precisely know both a subatomic particle's position and momentum, but is this actually a physical limitation? Or is it just a limitation by how we know how to measure subatomic particles today?
I don't have any idea how, but I feel like there will be a day when we understand matter on a small scale well enough that we can abandon this whole probabilistic model. Thanks for reading.
It is a physical limitation in quantum mechanics. It has absolutely nothing to do with the accuracy of your instruments.
Your feeling is common, but there are experiments that have ruled out hidden variables.
Likes bhobba
Local (!) hidden variables.
Valid point.
Well Its not a physical limitation rather its only a limitation of how we measure and see things using the most precise instruments we have.
So let's take an example where we want to know an electrons position. But we cannot directly see an electron, the only thing you can do is shine a light o an electron and it reflects it back to us so we see it through the interaction of photon with the electron.
Now you might be think how ?
Let me give you an elaboration of the above experiment.
We shot a photon at the electron to know its position and then the electron hit the photon and came back to us in a time of t.
Now we know that the Tie taken would be t = 2x/c where c = speed of light and x is distance b/w electron and the photon source.
So now we can calculate x easily.
But wait !
As soon as the electron hit the photon, it must have recoiled back because linear momentum must have conserved during the collision. And the Electrons velocity must have changed.
So now you see that you know the position well but since you changed the velocity of the electron, you no longer know the momentum.
So its not that uncertainty is physical law rather its just our inability to determine a systems states without disturbing it.
And Yes maybe in the future we will be able to remove this inability.
But the EPR experiment seems to show that this interpretation of the uncertainty principle is not correct.
Likes DrChinese
Well Its not a physical limitation...
This explanation of the uncertainty principle is not right, even though Heisenberg himself explained it that way at first and it's been repeated ever since. Not long after Heisenberg came up with this explanation, our understanding of the math behind quantum mechanics had advanced and it became clear that the uncertainty is fundamental to the theory - you cannot have a system with definite position and momentum even if you never measure either. No improvements in measurement technology can remove the limitation if QM is correct.
You will find the correct explanation of the uncertainty principle in some older threads here.
Likes bhobba and DrChinese
I agree. The only caveat being that the Bohmian interpretation of quantum mechanics actually does say that uncertainty is due to lack of precise knowledge about the state (and location) of a particle.
On the other hand, certain observables, such as the spin of an electron along an axis other than the one that you actually measure, just don't have values in the Bohmian interpretation. Whether an electron goes to the left or to the right in a Stern Gerlach device is a complicated (but deterministic) function of the state of the measuring device. So there is no unique answer to the question: "What would have happened if I had measured the spin along a different axis?"
... So its not that uncertainty is physical law rather its just our inability to determine a systems states without disturbing it...
An EPR pair (a system of 2 entangled particles) can be measured independently. They act as "clones" of each other, in the sense that the entangled properties obey certain conservation rules. Yet, you cannot exceed the Heisenberg limit when you measure non-commuting properties: one on one, another property on the other.
So no, as already pointed out by stevendaryl and Nugatory, you are quite incorrect. Yours is a common misconception.
Just wanted to say thank you for the thoughtful replies.
Related to Exploring QM: Is Uncertainty a Physical or Measurable Limitation?
1. What is quantum mechanics and why is uncertainty a fundamental concept?
Quantum mechanics is a branch of physics that deals with the behavior of particles at the atomic and subatomic level. Uncertainty is a fundamental concept in quantum mechanics because it describes the inherent unpredictability of certain physical properties, such as the position and momentum of a particle.
2. Is uncertainty a physical limitation or a measurement limitation?
Uncertainty in quantum mechanics is both a physical limitation and a measurement limitation. It is a physical limitation because it is a fundamental aspect of the behavior of particles at the quantum level. It is also a measurement limitation because the act of measuring a particle's properties can affect its behavior, making it impossible to know both its position and momentum with absolute certainty.
3. How does the Heisenberg uncertainty principle relate to uncertainty in quantum mechanics?
The Heisenberg uncertainty principle is a mathematical expression of the uncertainty principle in quantum mechanics. It states that it is impossible to know both the position and momentum of a particle with absolute certainty. This principle is a fundamental aspect of quantum mechanics and is related to the inherent unpredictability of particles at the quantum level.
4. Can uncertainty in quantum mechanics be overcome or eliminated?
No, uncertainty in quantum mechanics cannot be overcome or eliminated. It is a fundamental aspect of the behavior of particles at the quantum level. However, scientists have developed methods and theories, such as the Copenhagen interpretation and the many-worlds interpretation, to help explain and understand the implications of uncertainty in quantum mechanics.
5. How does uncertainty in quantum mechanics impact our understanding of the physical world?
Uncertainty in quantum mechanics challenges our classical understanding of the physical world, where everything is thought to be predictable and deterministic. It shows that at the subatomic level, particles behave in ways that are fundamentally different from our everyday experiences. This has led to new theories and technologies, such as quantum computing, that have the potential to revolutionize our understanding of the physical world and how we interact with it.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
