Exploring Relativistic Thermodynamics Experiments
In summary, diffusion occurs more slowly in a container moving close to relativistic velocity. Diffusion is a mundane process that has been studied in many experiments, but the theory of relativistic thermodynamics is still controversial.
bwana
82
TL;DR Summary
is there evidence of relativistic change in processes occurring at the level of large populations of particles
In most experiments of SR, we look at atomic and subatomic particles or the frequency of EM radiation.
The Haefele-Keating experiment looked at the resonance of cesium atoms stimulated by a certain EM frequency
https://en.wikipedia.org/wiki/Hafele–Keating_experiment
The Ives-Stillwell experiment looked at Doppler shift
https://en.wikipedia.org/wiki/Ives–Stilwell_experiment
The lifetimes of muons and other particles were investigated in other experiments.
https://en.wikipedia.org/wiki/Experimental_testing_of_time_dilation
But consider the mundane process of diffusion. Does diffusion occur more slowly in a container moving close to relativistic velocity? I guess doing this experiment is technically very difficult. But haven't we developed tools improved enough to allow this?
Or consider the Carnot cycle. Or perhaps something even more fundamental- heat transfer between two bodies. A simple experiment would consist of an insulated (adiabatic) container. In this container are two separate containers of water separated by a gap of air. Each container has a thermocouple to measure its temperature. One container is then heated to a specific temperature. The containers are brought into contact and the time it takes for the temperature equilibration is measured and a curve is generated. If this experiment is done on an airplane (like the Hafele–Keating_experiment) we should expect different rates of cooling compared to the ground experiment as well as the direction of flight compared to the ground (as in the Hafele–Keating_experiment)
But the theory of relativistic thermodynamics is still controversial
https://www.nature.com/articles/s41598-017-17526-4
The initial treatment by Planck and Einstein suggested
\begin{array}{ccc}T^{\prime} =\frac{T}{\gamma }\,, & S^{\prime} =S, & p^{\prime} =p\,,\end{array}where γ = (1 − (w/c))−1/2 is the Lorentz factor, c is the speed of light, and primed quantities correspond to the thermodynamic measurements in I’. These results mean that a body should appear cooler for a moving observer, but both entropy and pressure are relativistic invariants.
But even to this day, there is no consensus about how to theoretically treat relativistic thermodynamics. Even when the theory is written down, I can make no sense of it.
https://arxiv.org/abs/gr-qc/9803007
https://link.springer.com/article/10.1007/s10701-020-00393-x
https://www.researchgate.net/post/Why-is-relativistic-thermodynamics-not-included-in-the-general-physics-textbooks-and-special-theory-of-relativity-textbooks
But most of these treatises look at the question trying to understand whether a body “looks hotter or colder” from the point of view of the other. My question has more to do with the intrinsic thermodynamic behavior of a process at relativistic speeds.
But really, the theory has to fit the data. So where are the data?
This is interesting, but maybe not what you’re looking for. https://en.m.wikipedia.org/wiki/Relativistic_quantum_chemistryThe most interesting to me is the section on lead.
“Without relativity, lead would be expected to behave much like tin, so tin–acid batteries should work just as well as the lead–acid batteries commonly used in cars. However, calculations show that about 10 V of the 12 V produced by a 6-cell lead–acid battery arises purely from relativistic effects, explaining why tin–acid batteries do not work.”The citation is number 14.
Likes vanhees71
Don’t guess when you can calculate.
What is a reasonable mass for a container in which we might observe diffusion? Maybe 100 grams, .1 kg.
What is the maximum acceleration it can tolerate without breaking up? Something like 100g, which we is within the realm of possibility for a railgun.
So we’re going to use a railgun to accelerate a .1kg object at 100g until it reaches some relativistic velocity, something like .8c or thereabouts.
How long of a railgun do we need?
How much energy is required (assume 100% efficiency for simplicity)?
I'm a little confused as to what about diffusion might be interesting. How about studying the internal combustion engine relativistic speeds?
And why would you seriously propose substituting the cooling of a tank of water for a precision cesium clock as a measure of time. Better you use an hourglass.
As the OP suspects, none of this makes much sense.
Likes Grasshopper
It's easy to show that if one time measuring process appears to "run slow" so must all others and by the same factor, or else you can detect your absolute speed by comparing tick rates of two clocks. In other words, your question boils down to a test of the principle of relativity, of which there are many. See the experimental basis of special relativity FAQ linked in a sticky post at the top of the forum.
Likes Twigg and hutchphd
FAQ: Exploring Relativistic Thermodynamics Experiments
What is relativistic thermodynamics?
Relativistic thermodynamics is a branch of physics that studies the behavior of matter and energy at high speeds or in strong gravitational fields. It combines the principles of thermodynamics with Einstein's theory of relativity to describe the behavior of systems moving at relativistic speeds.
How is relativistic thermodynamics different from classical thermodynamics?
Classical thermodynamics only applies to systems that are at rest or moving at low speeds, while relativistic thermodynamics applies to systems moving at speeds close to the speed of light. Relativistic thermodynamics also takes into account the effects of strong gravitational fields, which are negligible in classical thermodynamics.
What are some examples of relativistic thermodynamics experiments?
Some examples of relativistic thermodynamics experiments include studying the behavior of particles in a particle accelerator, measuring the temperature of objects moving at high speeds, and observing the effects of gravity on the behavior of gases.
What are the practical applications of relativistic thermodynamics?
Relativistic thermodynamics has many practical applications, such as in the design of spacecraft and satellites, understanding the behavior of matter in extreme environments like black holes, and in the development of nuclear energy and weapons.
How does relativistic thermodynamics affect our understanding of the universe?
Relativistic thermodynamics plays a crucial role in our understanding of the universe, as it helps us explain phenomena such as the expansion of the universe, the behavior of stars and galaxies, and the existence of black holes. It also allows us to make more accurate predictions about the behavior of matter and energy in extreme conditions.
