Exploring the Compact Structure of Universe
In summary, the global geometry of the universe is determined by its energy density -- the universe can be closed, flat, or open, depending on whether the energy density is greater than, equal to, or less than the critical energy density, respectively. If the the universe is closed, the spatial topology/geometry is that of a sphere, and an observer could indeed 'wrap around' the universe and return to their starting point. A flat universe can be planar or have the topology of a torus. An open universe has hyperbolic geometry. In each of these cases, the time coordinate is non-compact.
thehangedman
69
If the universe is filled with matter, and that matter causes space-time to bend, wouldn't the over-all structure be closed? Meaning, if I fly off in some random direction I would eventually "wrap around" the universe like a person moving across the surface of a sphere?
If so, is this compact structure inherent in the universe or just caused by matter? Is it just space dimensions that are compact or is time also compact?
Space news on Phys.org
The global geometry of the universe is determined by its energy density -- the universe can be closed, flat, or open, depending on whether the energy density is greater than, equal to, or less than the critical energy density, respectively. If the the universe is closed, the spatial topology/geometry is that of a sphere, and an observer could indeed 'wrap around' the universe and return to their starting point. A flat universe can be planar or have the topology of a torus. An open universe has hyperbolic geometry. In each of these cases, the time coordinate is non-compact.
So, which mode is currently accepted or is this still undetermined? If the spatial dimensions are compact (closed due to high energy density), wouldn't a non-compact time dimension break the symmetry between space and time? If time can't be compact, would that tend to make you think that space cannot as well?
Thank you for your help!
Current cosmological observations (from CMB experiments, like NASA's WMAP probe) indicate that the observable universe is very close to being flat -- to within a percent or so. However, this measurement tells us nothing about the global geometry -- a nearly flat local geometry is consistent with any of the global geometries mentioned previously (for example, the Earth looks flat locally, but has the global geometry of a sphere.)
The symmetry between space and time arises as a result of Lorentz symmetry in local inertial frames. These frames do not accommodate gravity and are consequently flat. The Lorentz symmetry is generally not applicable to cosmological spacetimes globally, and so global geometry of the universe is not constrained by this requirement.
This isn't entirely true. This is a simplification that results from the assumption that the energy density of the universe is a constant everywhere, which it isn't (obviously: the Earth is a bit more dense than the space between the Earth and the Moon, for instance).
When you take into account the fact that the density of the universe varies from place to place, this assumption breaks down. For instance, if we end up measuring our region of the universe to be closed, that could just be due to our observable region being slightly overdense. It doesn't mean the universe as a whole is closed, because the rest of it could, on average, be less dense.
Instead, we are forced to separate between the global geometry (whether or not the universe wraps back on itself) and our local geometry. Whether we measure a local universe that is closed, open, or flat, the universe as a whole might well wrap back on itself or not depending upon whether or not the locally-measured curvature is representative of the global curvature.
And even then, it is also possible for a flat or open universe to wrap back on itself. This is most easily understood in the context of a flat universe, with the simple arcade game of asteroids: in the game of asteroids, the play field is flat (and yes, it does have perfectly flat geometry in the proper General Relativistic sense). And yet, the game field wraps back on itself: when you go off the right side of the screen, you reappear on the left side. This is known as a toroidal topology, because if you took a sheet and wrapped it up into a tube so that its edges touched, then wrapped that tube so that the ends of the tube met, you'd have a torus (a donut shape).
So unfortunately, measuring the local curvature will tell us very little about whether or not the universe wraps back on itself. It may, it may not. We don't know.
Chalnoth, had you read my last entry, you'd realize I am well aware of the distinction between local and global geometries.
Ah, sorry.
Related to Exploring the Compact Structure of Universe
1. What is the Compact Structure of the Universe?
The Compact Structure of the Universe refers to the overall organization and arrangement of matter and energy in the universe. It describes how objects and structures, such as galaxies and clusters, are distributed and interact with each other on a large scale.
2. How do scientists study the Compact Structure of the Universe?
Scientists study the Compact Structure of the Universe through various methods, including observations with telescopes and satellites, computer simulations, and theoretical models. These methods allow scientists to gather data and make predictions about the structure and evolution of the universe.
3. What are some current theories about the Compact Structure of the Universe?
There are several theories about the Compact Structure of the Universe, including the Big Bang theory, which suggests that the universe began as a singularity and has been expanding ever since. Other theories, such as the inflationary model and the multiverse theory, attempt to explain the large-scale structure of the universe and its origins.
4. How does the Compact Structure of the Universe impact our understanding of the universe?
The Compact Structure of the Universe is crucial in helping scientists understand the origins, evolution, and fate of the universe. By studying the structure, scientists can also gain insight into the fundamental laws of physics and the nature of dark matter and energy, which make up the majority of the universe.
5. What are some recent discoveries related to the Compact Structure of the Universe?
In recent years, scientists have made significant discoveries related to the Compact Structure of the Universe, including the detection of gravitational waves, the mapping of the cosmic microwave background radiation, and the identification of large-scale structures such as galaxy clusters and filaments. These discoveries have provided new insights into the structure and history of the universe.
