greg_rack
- 79
- Homework Statement
- Given a geometric angle of attack of 3deg, and the lift-curve below(measured compressible CL, M>0.3), use the Prandtl-Glauert correction to calculate the lift coefficient of the wing assuming incompressible flow.
DISCLAIMER: with Cl I mean the lift of the wing profile, the airfoil, and with the CL the lift of the whole wing
- Relevant Equations
- Induced AOA: ##\alpha_i=\frac{57.3C_L}{\pi e_1 A}##
This situation is really confusing me. First of all, does accounting compressibility affect the measurements for CL? If yes, how does CL change as a function of the increasing mach number?
Back to the problem, above is the "in-flight" lift curve for a plane traveling at high speeds, so the CLs are supposed to be for compressible flow.
To find the related CL for incompressible flow, since we can apply the Prandtl-Glauert(PG) correction only to profile Cl, we must first switch to the lift-curve of the airfoil(Cl versus alpha).
We find that a Cl of 0.5 is obtained for alpha=1.8, so the slope changes and is higher, as expected.
Now, we can apply the "reverse" PG correction to this Cl coefficient to get the airfoil incompressible curve: a Cl of 0.433 is obtained for alpha=1.8.
And here is where I got stuck... how do I get from the Cl curve, to the CL curve(to find incomp. CL at alpha is 3), if I don 't know the induced angle of attack?
