Exploring the Enormous Organisms of the Carboniferous Period
  • Thread starter Eagle9
  • Tags
    Period
In summary: When the levels of oxygen were higher, there were more trees and other plants to take up oxygen and produce more carbon dioxide.In summary, the increased oxygen levels during the Carboniferous led to the growth of giant insects.
Eagle9
238
Hello :oldsmile:
I have heard that various organisms in Carboniferous period had gigantic sizes because of relatively high Oxygen level in atmosphere. Today it is equal to 21 %, but at that time it was higher:
The growth of these forests removed huge amounts of carbon dioxide from the atmosphere, leading to a surplus of oxygen. Atmospheric oxygen levels peaked around 35 percent, compared with 21 percent today. It also may explain the giant creepy-crawlies that now emerged—the size reached by insects and similar creatures is thought to be limited by the amount of air they are able to breathe.
Deadly poisonous centipedes some six feet (two meters) in length crawled in the company of mammoth cockroaches and scorpions as much as three feet (one meter) long. Most impressive of all were dragonflies that grew to the size of seagulls. One exquisitely detailed fossil of a dragonfly that died 320 million years ago shows it had a wingspan of 2.5 feet (0.75 meters).
https://www.nationalgeographic.com/science/article/carboniferous
So, organisms were very big, but I do not really understand why. What is the biochemical grounding for linkage between Oxygen’s level in atmosphere and organisms’ size? Is there really a direct correlation? Can one make such experiment - creating orangery where Oxygen’s level will be 35 % and then let’s see if plants (ferns for example), insects and other organisms become larger. Of course, many years are needed for plants to grow up, but insects grow much faster. It will be very interesting to see human-size fly or bee in such simulated experiment. Has anybody done this? Will it be very expensive? Or can we apply to genetic engineering to make current insects so large again? :oldeyes:
Biology news on Phys.org
It would be easy to do the experiment you propose; raise some fruit flies in an increased oxygen atmosphere.
It takes about a week or two for a Drosophila egg to grow to an adult.
I don't know that that has been tried, but if it worked it probably would have been in the science news.
I would not expect it to work because there was probably some genetic involvement in size the insects would be able to achieve. It's obtainable size would be part of their adapting to their environment.
Raising flies in an increased oxygen environment for a long enough time for them to evolve increased size would be more difficult because many generations would have to be held in that atmosphere for many generations (probably many, many). You might be able to speed it up by mutating the flies at some level, to increase genetic variability, but it seems unlikely (to me) that you would see any effect very quickly.
Likes Bandersnatch and pinball1970
The carboniferous gigantism concerns mainly arthropods (not all organisms; while fern sizes are unrelated to oxygen concentration, but rather due to simple filling of evolutionary niches).
These animals got so large through evolutionary selection over many generations - not by individual exposure to higher levels of oxygen.
And it helped those animals specifically, because they have inefficient respiratory and circulatory systems. When you don't have no fancy lungs, nor veins, to carry the oxygen around your body, and instead have to rely on mostly passive diffusion, you can't grow your body too large. Else the deepest tissues will suffocate.
Likes BillTre and pinball1970
Eagle9 said:
Hello :oldsmile:
In terms of why these animals were able to get so large, the oxygen levels would enable effective ATP metabolism.
ATP provides energy to build and getting large would confer an evolutionary advantage for competing for food and mates.
Likes BillTre
Their respiratory system is considered less efficient, but it is a tracheal system to distribute air (for oxygen going in and CO2 going out). Body movements (during exercise, when gas exchange demands would be greater) help pump air in and out of the blind ended tracheal tubes. The trachea branch throughout the insect's body.
More turnover of tracheal air would increase the concentration differences across the membranes separating the body fluids and inhaled air. The concentration differences would drive the gas exchange. The upper limit of concentration differences ,would be limited by the (oxygen) concentrations in the atmosphere.
The insect circulatory system, which could move internal fluids, to distribute dissolved gasses to some extent. around, is an open system where the eart pumps blood out to the tissues. However, the flow back from the tissues is through tissue spaces and sinus-like spaces (probably also enhanced by body movements).
The simple answer has been given a couple of ways. Arthropods - insects, scorpions, centipedes - have holes in the side of the thorax. Spiracles. They provide oxygen by diffusion only. Passive, no diaphragm. What counts is the oxygen concentration (partial pressure of oxygen) in the atmosphere.
The flip side of this is there have been times of lower levels. The range is 15% to 30% per the link below.
See ##O_2## levels during the Phanerozoic (550 mya to today):
https://www.pnas.org/content/96/20/10955
It explains why.
Also, humans have high elevation (lower total oxygen) genetic adaptations for dealing with hypoxia:
http://genesdev.cshlp.org/content/28/20/2189.full
Likes hutchphd and BillTre
But if genetic alterations are not absolutely necessary, then during several years (and hence about 100 generations?) we can probably achieve desired goal? :oldeyes:
So, can they in principle grow 30-40 m height? If only “niches” matter, then why nobody tried to receive such giant ferns? It would be very attractive achievement :oldsmile:
So to conclude, primitive internal organs and systems enabled those organisms to reach big sizes, is it correct? :oldeyes:
pinball1970 said:
In terms of why these animals were able to get so large, the oxygen levels would enable effective ATP metabolism.ATP provides energy to build and getting large would confer an evolutionary advantage for competing for food and mates.
So, no genetic changes/engineering is needed in order to receive such giant species?
See O2 levels during the Phanerozoic (550 mya to today):
Perhaps, but I am speaking about Carboniferous period of Paleozoic Era :oldsmile: I love this period since my childhood :smile:
If genetic alterations (meaning evolutionary changes) were not necessary, then I would expect changes like these to happen in one to a few generations.
One generation would be the simplest case, all depends only on oxygen concentration.
Possibly, a few generations if there were some "meta-genomic" changes involved.
A hundred generations might be the result of some selection on the genome (but you would need a source of genetic variation which could be selected).
Sound easy to do, why nobody tried to do it? :oldeyes:
Perhaps for the same reason you haven't done it; doesn't seem to be worth the effort for the possible returns.
Likes BillTre
But the reference you quoted states,
Atmospheric oxygen levels peaked around 35 percent, compared with 21 percent today. It also may explain the giant creepy-crawlies that now emerged.
With an emphasis on the word 'may;.
A higher oxygen level should provide a potential for a larger organism to exist, but it would not be the only deciding factor.
Likes pinball1970 and BillTre
But it seems to be quite easy and interesting (I mean results) :oldeyes:
Perhaps :cool:
But if I had free money I would make such experiments regardless it will yield some practical resulst in biology or not, it is just curiosity :oldsmile:
Likes 256bits
FAQ: Exploring the Enormous Organisms of the Carboniferous Period
What is the Carboniferous Period?
The Carboniferous Period was a geological period that lasted from approximately 358.9 million years ago to 298.9 million years ago. It is known for its abundance of plant life and the formation of coal deposits.
What were the organisms like during the Carboniferous Period?
The Carboniferous Period was known for its enormous organisms, including giant insects and amphibians. The land was covered in lush forests, and the oceans were teeming with diverse marine life.
Why were the organisms of the Carboniferous Period so large?
One theory is that the high oxygen levels during the Carboniferous Period allowed for larger organisms to thrive. Another factor could be the lack of large predators, allowing for these organisms to grow to massive sizes.
What impact did the organisms of the Carboniferous Period have on the environment?
The abundance of plant life during this period led to the formation of vast coal deposits, which have been used as a major source of energy for centuries. The organisms also played a crucial role in shaping the Earth's climate and atmosphere.
How do scientists study the organisms of the Carboniferous Period?
Scientists use a variety of methods to study the organisms of the Carboniferous Period, including fossil records, geological data, and computer simulations. By analyzing these sources of evidence, scientists can gain a better understanding of the organisms and their impact on the Earth's history.
