Exploring the Mystery of Space's Cold Temperature
In summary: The comparison that you really want here is to wave hands and dismiss the other lethal effects of vacuum and concentrate on the warmth of a suit.In summary, a person wearing an unheated, oxygen supplied, airtight suit of moderate albedo in 2.735o K space would lose less heat than if one were to fall into ice-cold salt water.
  • #36
I sure did, is it than reasonalbe to assume the windchill temperature rather than the air temperature in this example?
Science news on Phys.org
  • #37
Well, quick back of envelope results given convection heat loss is 1/2 of radiative loss in wind from http://www.drphysics.com/convection/convection.html,where 1/3 of heat loss is due to convection without wind condition.
I got something order of 1000 W , due to conduction, convectin, radiation. No condensation, evaporation, prespiration assumed.
It seem that somebody was very interested in the body heat loss in the year 1937 :)
JSTOR: http://www.jstor.org/view/00278424/ap000883/00a00090/0?frame=noframe&userID=89c65748@hamptonu.edu/01cce4405b00501cbca2a&dpi=3&config=jstor
  • #38
sneez said:
Now that I am thinking about it, is the wind actually relevant? The wind acts only to slow down the process of equilibriation between body and the air, by keeping theT gradient between the body and air by blowing off the near skin molecules of air that my body heated.
Stop and think about that for a sec - you've felt wind before, right? You've worn heavy clothes, right? The purpose of heavy clothes (insulation) is to create a shallow temperature gradient. With no clothes and a heavy wind, you have the steepest possible temperature gradient and since heat loss is proportional to that gradient, you have the maximum possible heat loss.
You have it exactly backwards.
The body, even in hight wind, cannot cool bellow the ambient air temperature, right?
Of course. But that's the steady-state condition where you are frozen solid and in a normal winter, that takes hours. We're talking about the heat loss in the beginning, when your body temperature is near normal and you are not dead.
I don't think that's Integral's point. The point is that "wind chill" is a measure of convective heat loss. It is basically how cold still air would have to be to provide the same convective heat loss as windy air at a higher temperature.
  • #39
I'm not sure where you are getting the 1/2 number, and in the "other work" section, others who have calculated the ratio got .7 instead of 1/3 (2nd and fourth paragraphs). With wind, the first saw a 40% increase in convective rate with a 1mph wind (very, very low wind) and the fourth saw a 178% increase (10W/m^2) in a 3 m/s (2 mph) wind. So as that shows, the effect of wind is huge. With a very light wind (ie, just by walking), the convective heat loss rate swamps the radiative heat loss rate.
Note that these calculations are for room temperature air...
  • #40
thanx for the input russ
Thats exactly what I thought I said.
1st point:Are you implying that it is possible for anybody temperature to cool below the T of the air due to wind effects at certain conditions?
2nd: explain how that is not applicable in the beginning
Thats exactly why I posed it as a question , do you have an answer? And due to its definition I think its reasonable to use the concept in the wind condition. Basically, I use wind chill temperature in calculation as a temperature surrounding air would "have" given no wind.
I sort of arbitrarily assumed it. The article claims 1/3 and other sources also cite that, but that's for no wind condition, I thought with wind convection gets more and more important as you say, so I gave it more importance .
  • #41
You said the wind slows the body reaching equilibrium with the air - it speeds it up.
Certainly not.
The body isn't frozen solid, so talking about how heat would be removed when it is frozen solid is irrelevant.
?? An answer to what? If we should assume wind chill temp? I guess if your equation doesn't have a term for wind speed, you can use the wind chill temp instead.
  • #42
Yes! That is why we sweat. Otherwise everyone in Phoenix would die.
However, I think sweat would be a pretty small factor in Antartica :-)
  • #43
Right, speed up by faster heat removal, i stand corrected.
DaeSpam, sweat is cooling by evaporation, I was trying to see if object will cool below the air temperature just due to wind alone.
(I don't think I am understanding the russ's comment on the steady state of frozen solid)
  • #44
So neglecting evaporation just considering convection? No, I don't think that convection can cool things below the air temperature. I think the only way that would even be theoretically possible is for the the flow to cause some unusually low pressure region which would experience an adiabatic drop in temperature. But surely such effects would be negligably small and very difficult to model for a human. The wind-tunnel tests might be fun though!
  • #45
that depends on how you define heat. if you mean hot or warm for a human, then there is very little heat in the universe. if you mean above absolute zero, then most of the universe has heat.
