Exploring the Physics of Spinning Astronauts with Bowling Balls
In summary, two astronauts in outer space are stationary relative to each other, except for one who is spinning at one revolution per second while holding a bowling ball tethered to him. The spinning astronaut has potential energy in his body and spin, and can manipulate his rotation by releasing or pulling in the ball. When he violently throws the ball, he will experience a recoil and begin moving backwards as the ball moves forward, but his rotation will continue. The recoil may not completely negate the relative motion created by the throw, and it may also alter the rotation rate of the astronaut. However, due to momentum conservation, there is no way for the spinning astronaut to gain motion relative to his buddy without sacrificing mass or cutting the tether. The only way for
moses1592
Consider this scenario: two astronauts are floating in outer space with no other frame of reference other than themselves. Relative to one another they are stationary and have no motion between them, except that one astronaut is spinning at one revolution per second. The astronaut that is spinning is tightly holding a bowling ball against his chest. The bowling ball is also tethered to him on a long cable.
The spinning astronaut has potential (muscle) energy in his body which allows him to toss the bowling ball if he desires. He also has potential energy in his spin. If he slowly releases the bowling ball on the tether his rotation will slow down but he will remain stationary and won't feel a force of acceleration. If he pulls it back in then his spin will increase back to its original 1 rotation per second. Let's say he violently throws the ball as hard as he can.
The moment he let's go he will be pushed and begin moving backwards as the ball proportionally moves forward, except he will still be spinning while the ball is moving. I believe the ball Will have some rotation as well. This of course will be negated (at least partially) when the ball reaches the end of the tether and recoils.
Will this inevitable recoil always 100% negate any relative motion created by throwing the ball? Would this act alter the rotation rate of the astronaut since energy was spent in the act of the throw/recoil? I know any time an object/system expends energy it loses a tiny amount of mass, but for this scenario assume it's so small as to be negligible.
In closing, is there any way for the spinning astronaut to use his tethered bowling ball, potential muscle and/or rotational energy to gain motion relative to his buddy astronaut without sacrificing mass or cutting the tether?
Think about the implications of momentum conservation here...
He will gain motion relative to his buddy due to gravitational attraction. Without sacrificing reaction mass all he can do is using the bowling ball to increase this effect.
Related to Exploring the Physics of Spinning Astronauts with Bowling Balls
1. How does the motion of a spinning astronaut with a bowling ball differ from that of an astronaut without a bowling ball?
The addition of a bowling ball to an astronaut's spinning motion creates a change in the distribution of their mass. This results in a change in their moment of inertia, causing them to spin at a different rate than they would without the bowling ball.
2. Why do astronauts use bowling balls for experiments in space?
Bowling balls are used in space experiments because they have a consistent and predictable mass and shape, making it easier to study the effects of different forces and motions on them. Additionally, they are relatively easy to handle and can be manipulated with minimal effort in a zero-gravity environment.
3. How does the spin of a bowling ball affect the spin of the astronaut?
The spin of the bowling ball and the astronaut are interconnected due to the conservation of angular momentum. As the astronaut begins to spin with the bowling ball, they will continue to spin at the same rate as the ball unless acted upon by an external force.
4. Can the spin of a bowling ball and astronaut be controlled in space?
Yes, the spin of a bowling ball and astronaut can be controlled in space by manipulating the distribution of mass and the forces acting on them. By changing the position of the bowling ball or the astronaut's body, the rate of spin can be altered.
5. How does the spin of the astronaut and bowling ball affect their trajectory in space?
The spin of the astronaut and bowling ball can affect their trajectory in space due to the conservation of angular momentum. As the objects spin, they will continue to travel in the same direction unless acted upon by an external force. This can be seen in the movement of objects in orbit, where their spin and trajectory are both influenced by the gravitational forces of other objects.
  • Mechanics
21K
