Exploring the Relationship between Lorentz Transformations and Rocket Frames
  • Thread starter accidentprone
  • Tags
    Lorentz
In summary, accidentprone was stuck on a question from a past exam and was unable to figure out how to start answering it. He was able to solve it after realizing that beta was v/c.
accidentprone
Consider the Lorentz transformations:
ct' = gct - Bgx
x' = gx - Bgct
y'=y
z'=z
Show that the primed frame corresponds to a "rocket" frame moving at speed v in the x direction relative to the unprimed frame.
(Sorry about my notation: g = gamma)
The above Lorentz transformations.
I understand the Lorentz transformations and the basics of special relativity, but I'm stuck on this question from a past exam. I'm simply not sure how to set about showing this? A few hints in the right direction would be most appreciated!
hi accidentprone! :smile:
(have a gamma: γ :wink:)
hint: in the "rocket" frame, anything in the rocket at a particular value of x' will be at the same x' for all t' :wink:
Hey! Thanks for replying :)
I understand your hint, but I'm still unable to get going on the answer. Could you tell me how I should start answering the problem?
Many thanks again for your time!
show us what you've tried, and where you're stuck, and then we'll know how to help :smile:
Ok so I've drawn two graphs - one of x' against y' and one of x against y for the frames and tried fiddling around with them. I think I might be going down the wrong track though! I'm confused as to how I will show what's being asked... Where will v come from?
since you're asked to prove something from the equations, i don't see a graph helping, just stick to using the equations …
v should come out as a ratio of x to t :wink:
Hey sorry to be posting in an old thread, but I wanted to say that I've solved the problem. I hadn't seen the Lorentz transformations in that form before. My book makes no mention of beta being v/c. Once I knew that it all came together! Thanks for your help.
FAQ: Exploring the Relationship between Lorentz Transformations and Rocket Frames
What are Lorentz transformations?
Lorentz transformations are a set of equations used in special relativity to describe how space and time coordinates of an event appear to an observer in a different inertial frame of reference.
Why are Lorentz transformations important?
Lorentz transformations are important because they allow us to understand the effects of relative motion on the measurements of space and time. They are essential in reconciling the principles of special relativity with classical mechanics.
How are Lorentz transformations derived?
Lorentz transformations can be derived mathematically from the postulates of special relativity, which state that the laws of physics are the same in all inertial frames of reference and that the speed of light is constant for all observers.
What is the difference between a Lorentz transformation and a Galilean transformation?
A Lorentz transformation takes into account the time dilation and length contraction effects predicted by special relativity, while a Galilean transformation does not. This means that Lorentz transformations are valid for all speeds, while Galilean transformations are only valid for speeds much slower than the speed of light.
Can Lorentz transformations be applied to everyday situations?
Yes, Lorentz transformations can be applied to everyday situations that involve high speeds or precise measurements of time and space. For example, they are used in GPS systems and particle accelerators.
