Exploring the Sign of a 2nd Derivative Function
In summary: Yes, please write something similar for the second derivative, related to the original function. In which cases may that one be... undefined?
greg_rack
79
$$y=\sqrt[3]{e^x-1}$$
Theorems for second derivatives
Since the index of the root is odd, the domain is going to be ##R##, and I can calculate the second derivative to be:
$$y''=\frac{1}{3}\times \frac{e^x(e^x-3)}{3(e^x-1)^{\frac{5}{3}}}$$
Studying the sign of this function, it results positive for ##x<0 \vee x>ln(3)##, so the main function will be convex in these intervals.
My doubt comes with the inflection points: ##ln(3)## will surely be one since it's a root of the nominator and in its neighborhood the derivative switches sign, but what about ##0##, for which the second derivative is not zero, but instead undefined(denominator=0)?
How do I treat such critical points?
Likes Delta2
The first derivative is also undefined at x = 0. An inflection point is a point for which the slope changes sign; i.e., changes from pos. to neg. or from neg. to pos.
Likes greg_rack
greg_rack said:
Homework Statement:: $$y=\sqrt[3]{e^x-1}$$
Relevant Equations:: Theorems for second derivatives
At an inflection point, the concavity of the function changes between opening up and opening down. Thus, the sign of the second derivative is different on each side of the inflection point. Of course the function must be continuous there, but the derivatives may be undefined at an inflection point.
Likes greg_rack
Got it! @Mark44 @SammyS
This thing of undefined derivatives is always confusing me up... I often can't really get the geometrical/mathematical meaning of an undefined derivative.
Anyway, in conclusion, the research for inflection points should only be based on analyzing the neighborhoods of critical points(being either roots or points excluded from the domain of the derivative), and looking for changes in concavity?
Here are a few tips that might help you with this:
A function f whose derivative at a point ##x_0## doesn't exist usually implies at least one of the following things:
  1. The function f is not defined at the point ##x_0## i.e ##f(x_0)## doesn't exist. In this case the graph of f(x) will have a gap at the point ##x=x_0##.
  2. The function f is defined at the point ##x_0## but it is not continuous at the point ##x_0##. In this case the graph of f(x) will have a jump at the point ##x=x_0##
  3. The function f is defined at the point ##x_0## and is continuous at the point ##x_0## but the derivative does not exist at this point. In this case the graph of f(x) will have a sharp corner at the point ##x=x_0##. In order for the derivative to exist all changes in the slope of the graph must be done in a smooth curved way, not with sharp corners. Typical example of such function is ##f(x)=|x|## at the point ##x_0=0##.
It also worth to take a look at the following wikipedia article
Weierstrass function - Wikipedia
which is a function that is continuous everywhere but nowhere differentiable.
That was really exhaustive and helpful, thank you!
And could we write something similar for the second derivative, related to the original function? In which cases may that one be undefined, and why?
Likes Delta2
The same three hold for ##f''(x_0)## existence but in addition two more things
  1. f' is defined at ##x_0## but f' is not continuous at ##x_0##. Unfortunately I don't know how to reduce this condition in terms of the original function f.
  2. f' is defined at ##x_0## and f' is continuous at ##x_0## but f' is not differentiable at ##x_0## because the graph of f' has sharp corner at ##x_0##. Again I don't know how to reduce this condition in terms of the original function f.
This situation ( function f is defined at the point ##x_0## and is continuous at the point ##x_0## but the derivative does not exist at this point) can also occur if the tangent line at ##x_0## is vertical. That is the case for the function in this thread.
@greg_rack: Have you graphed the function?
Added in Edit:
A better view window:
Likes Delta2
FAQ: Exploring the Sign of a 2nd Derivative Function
1. What is the second derivative of a function?
The second derivative of a function is the derivative of the first derivative. It represents the rate of change of the slope of the original function.
2. How is the second derivative of a function calculated?
The second derivative can be calculated by taking the derivative of the first derivative using the rules of differentiation. Alternatively, it can also be found by taking the derivative of the function twice.
3. What does the sign of the second derivative tell us about a function?
The sign of the second derivative can tell us about the concavity of a function. A positive second derivative indicates a concave up function, while a negative second derivative indicates a concave down function.
4. How can the second derivative be used to find inflection points?
An inflection point is where the concavity of a function changes. This can be found by setting the second derivative equal to zero and solving for the x-value. The x-value at which the second derivative changes sign is the inflection point.
5. Can the second derivative be used to determine the maximum and minimum points of a function?
Yes, the second derivative can be used to determine the maximum and minimum points of a function. A maximum point occurs when the second derivative changes from positive to negative, and a minimum point occurs when the second derivative changes from negative to positive.
