- #36
chroot
Staff Emeritus
- 41
Okay, you should never mention miles again. Ever. If you ever even think of miles again, you're doing something wrong. Do not call c 186282 miles/second. Do not call c 300,000 km/sec either. Call c one light-year per year.Prague said:Why you are dividing [tex]\gamma[/tex] by [tex].99 * c[/tex].
Also, when I try to convert 3 light years to actual numbers and then change the .99 * c to 184140 the equation doesn't work. So I don't know what 3 light years or even c represents if it doesn't work.
Basically what I am trying to say is, if I were to do this on an actual calculator, not google.com how would I write it (with numbers included). I can't put a c so I assume its 186000, I can't write 3 light years so I assume its 558000, but putting these in they don't calculate to the 156 days.
I hope you understand what I am getting at.
That's right -- c is just one in units where you use light-years and years as your units of length and time.
Now, gamma's easy to calculate, as I showed you. When you're considering velocities as fractions of c, then the c's cancel out. When you're considering 0.99c, for example, the term (0.99c)^2/c^2 can be simplified to just 0.99^2. Gamma is then just 1/(1-0.99^2), which you can do on any calculator. No miles. No unit conversions. If you ever attempt to use miles ever again, you're doing something wrong.
Now, gamma is dimensionless. It does not have units of time, or length, or anything. Gamma is just a number, a multiplicative factor.
When you want to use gamma in the time-dilation or length-contraction equations, leave the times in years, and the lengths in light-years.
If the twin is traveling three light-years at 0.99c, that three light-years will be contracted to 3/gamma light-years (about 0.423 light-years). Simple division. No miles.
The twin will cross those 3/gamma light-years in (3/gamma)/0.99c. Remember in our units c is one-light yer per year. Here are the units:
[tex]\frac{3 \,\textrm{light-years}}{\gamma} \, \cdot \, \frac{1}{0.99 \,\textrm{light-years per year}} = 0.427 \,\textrm{years}[/tex]
Or, about 156 days.
- Warren
