How Does Theorem 4.29 Illustrate Continuity Issues in Inverse Functions?
In summary, according to Theorem 4.16, if f^{-1} is continuous at a point, then it is continuous at all points in the domain of f^{-1}. However, in the example given, f^{-1} is not continuous at the point $f(0)$, because the sequence \{x_n\} does not converge in S.
Math Amateur
MHB
3,998
48
I am reading Tom M Apostol's book "Mathematical Analysis" (Second Edition) ...
I am focused on Chapter 4: Limits and Continuity ... ...
I need help in order to fully understand the example given after Theorem 4.29 ... ... Theorem 4.29 (including its proof) and the following example read as follows:
In the Example above we read the following:
" ... ... However, \(\displaystyle f^{ -1 }\) is not continuous at the point \(\displaystyle f(0)\). For example, if \(\displaystyle x_n = 1 - 1/n\), the sequence \(\displaystyle \{ f(x_n) \}\) converges to \(\displaystyle f(0)\) but \(\displaystyle \{ x_n \}\) does not converge in \(\displaystyle S\). ... ... "My question is as follows:
Can someone please explain exactly how/why ... the sequence \(\displaystyle \{ f(x_n) \}\) converges to \(\displaystyle f(0)\) but \(\displaystyle \{ x_n \}\) does not converge in \(\displaystyle S\) ... ... implies that \(\displaystyle f^{ -1 }\) is not continuous at the point \(\displaystyle f(0)\) ... ... ?
-----------------------------------------------------------------------------------------------------------------------------------------------My thoughts ...
I think that the relevant theorem regarding answering my question is Apostol, Theorem 4.16 which reads as follows:View attachment 9239
If we let \(\displaystyle t_n \in f(S)\) be such that \(\displaystyle t_n = f(x_n)\) ... so the sequence \(\displaystyle \{ t_n \} = \{ f(x_n) \}\) is in the domain of \(\displaystyle f^{ -1 }\) ...
Then ... sequence \(\displaystyle \{ t_n \} = \[ f(x_n) \}\) converges to \(\displaystyle f(0) = t_0\) say ...
Then following Theorem 4.16 above ... for \(\displaystyle f^{ -1 }\) to be continuous we need \(\displaystyle \{ f^{ -1 } (t_n) \} = \{ f^{ -1 } ( f(x_n) ) \} = \{ x_n \}\) to converge in \(\displaystyle S\) ... but it does not do so ...
(mind you ... I'm not sure how to prove it doesn't converge in \(\displaystyle S\) ...)
Is that correct?
Hope that someone can help ...
Peter
Hi Peter,
Your idea is correct. Now, the sequence $\{x_n\}$ converges to $1$ in $\mathbb{R}$, but, as $S$ does not contain $1$, that sequence does not converge in $S$.
Intuitively, what happens is that, when a point $P$ travels counterclockwise in circles in $f(S)$, the image $f^{-1}(P)$ jumps discontinuously from $(1-\varepsilon)$ to $0$ in $S$ whenever $P$ passes through $f(0)=1$.
castor28 said:
Hi Peter,
Thanks castor28
Appreciate your help ...
Peter
