I Exploring Work Done in Quasi-Static & Non Quasi-Static Expansion
The discussion highlights the differences between quasi-static and non-quasi-static processes in thermodynamics, particularly regarding work done by and on the system. In a quasi-static process, the gas performs work as it expands, maintaining equilibrium, while in a non-quasi-static process, the gas does not move fast enough to exert work effectively, leading to additional complexities such as friction and viscous effects. The second law of thermodynamics plays a crucial role, indicating that entropy changes in non-quasi-static processes require more work to account for irreversible effects. The equations governing these processes, such as the ideal gas law, apply primarily to reversible conditions, emphasizing the challenges in calculating work during irreversible processes. Understanding these distinctions is essential for accurate thermodynamic analysis and applications.
happyparticle
I'm wondering what's the difference between work done on quasi-static and non quasi-static expansion.
In a quasi-static process, the gas inside the system must do a work to "extend".
However, in a non quasi-static process, where the gas inside the system doesn't move fast enough to "push" the "edge" to do a work, what happen exactly?
Is the work on the system in a quasi-static process lower than in a non quasi-static process, since there's no work done by the system, but only to the system?
Another way I see it is since ##w = p\delta v## for a similar ##\delta v## p must be greater for a greater work, but I'm not convinced.
Science news on Phys.org
This would be explained by the second law of thermodynamics:
https://en.wikipedia.org/wiki/Second_law_of_thermodynamics#Introduction said:
For an actually possible infinitesimal process without exchange of mass with the surroundings, the second law requires that the increment in system entropy fulfills the inequality
$$ \displaystyle \mathrm {d} S>{\frac {\delta Q}{T_{\text{surr}}}}$$
This is because a general process for this case (no mass exchange between the system and its surroundings) may include work being done on the system by its surroundings, which can have frictional or viscous effects inside the system, because a chemical reaction may be in progress, or because heat transfer actually occurs only irreversibly, driven by a finite difference between the system temperature (T) and the temperature of the surroundings (Tsurr).
Combining this with the concept of enthalpy:
$$\partial W = \partial Q - dU$$
$$\partial W = TdS - dU$$
Now imagine a reversible process where a heat transfer is made to only change the internal energy, thus ##\partial Q = dU## or ##\partial W = 0##.
But with an irreversible process, we would measure that ##T_{surr}dS## is greater than the expected, ideal, ##\partial Q## and thus ##T_{surr}dS > dU## and the actual work ##\partial W## is also greater than zero. To get the ##dU## desired, you will have to put in some extra work to take into account, for example, the frictional or viscous effects.
But @Chestermiller understands this better than me and would probably explain it better than me.
The equation of state for a gas, such as the ideal gas law or the Van Der Waals equation is valid only for thermodynamic equilibrium or for a reversible (quasi static) process, which is comprised of a continuous sequence of thermodynamic equilibrium states. The reason for this is that in an irreversible (non-quasistatic) process, there are viscous stresses present in the rapidly deforming gas which affect the forces exerted by the gas. For an irreversible (non-quasistatic) process, we can only calculate the work done by the gas by imposing (i.e., controlling) the forces acting on the gas (and from Newton's 3rd law)the forces imposed by the gas on its surroundings) manually. This can be done by imposing an external medium at constant pressure or by embedding a force transducer into the piston face, and using a feedback system.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
