Explosion of firecracker on pond
In summary, a firecracker with a mass of 0.70 kg explodes on a frozen pond, resulting in three pieces. The first piece, with a mass of 0.20 kg and a velocity of 100 m/s, moves at a right angle to the second piece, with the same mass but a velocity of 125 m/s. To find the speed of the third piece, we use the principle of momentum conservation, which states that the initial momentum is equal to the final momentum. Therefore, the equation m1v1 + m2v2 + m3v3 = 0 can be used to solve for the speed of the third piece.
omc1
100
A firecracker (mtot = 0.70 kg), sitting on a frozen pond, explodes into three pieces, each of which moves horizontally. Piece 1 (m1 = 0.20 kg; v1 = 100 m/s) moves at a right angle to piece 2 (m2 = 0.20 kg; v2 = 125 m/s). What is the speed of the third piece?
mv=p=j=ft
m(tot)v1+v2+v3=ft i think t=v(final)/a and a would be equal to gravity but iam just not sure. thanks for help!
hi omc1! :smile:
m(tot)v1+v2+v3=ft
what is this supposed to be? :confused:
what principle do you think applies here?
(and what topics have you been lectured about this week?)​
we have only talked bout impulsion and momentum so far i think thurseday we begin collision...
the formula applies to mas total times the sum of the velocities is the force times time...
an explosion is a type of collision (in reverse!)
what happens to momentum in a collision? :smile:
(and do you need to answer this before thursday?!)
momentum is conserved in a collision, yes my homework is due wednesday night.
ok, the initial momentum is zero :wink:
(because the question says the firecracker is "sitting")
sooo …​
mmmm ok so m(tot)v1+v2+v3=0 iam not sure
no, that's multiplying the total mass by the sum of the velocities
you need to add the individual momentums (ie individual mass times individual velocity) :wink:
soo m1v1+m2v2+m3v3=0 ??
yup! :biggrin:
Related to Explosion of firecracker on pond
1. What causes an explosion of a firecracker on a pond?
An explosion of a firecracker on a pond is caused by the rapid combustion of the explosive materials inside the firecracker. When ignited, the materials produce a large amount of gas and heat, which creates pressure that causes the explosion.
2. Is it safe to set off firecrackers on a pond?
No, it is not safe to set off firecrackers on a pond. The explosion can be unpredictable and can cause harm to both humans and animals. Additionally, the debris from the explosion can pollute the water and harm aquatic life.
3. Can an explosion of a firecracker on a pond cause damage to the surrounding area?
Yes, an explosion of a firecracker on a pond can cause damage to the surrounding area. The force of the explosion can break windows, damage buildings, and even injure people nearby. It is important to always use caution when setting off firecrackers.
4. How can the impact of an explosion of a firecracker on a pond be minimized?
The impact of an explosion of a firecracker on a pond can be minimized by following safety precautions such as setting them off in a designated area away from people and structures. Additionally, using smaller and less powerful firecrackers can also help reduce the impact of the explosion.
5. What are the potential risks of an explosion of a firecracker on a pond?
The potential risks of an explosion of a firecracker on a pond include physical injuries, damage to property, and environmental harm. It is important to always handle and set off firecrackers responsibly to avoid these risks.
