Exponential and logarithmic Equation Problems
But you could have done it in one step as ##4^{2x} - 4\cdot4^x = 0## implies ##4^x(4^x - 4) = 0##. But anyway, the important thing is that you got the answer.
onemic
25
Evaluate each of the following expressions without using a calculator.
1) log216√8Solve for the unknown value in each of the following equations without using a calculator.
2) 3(x+4)−5(3x)=684
3) 7(42x)=28(4x)
Exponent law for multiplication
log2(16)√8
=log232√2
=log2321/2
Im not really sure what to do at this point or if my approach is just completely wrong
2)
3(x+4)−5(3x)=684
=(3x)(34)-5(3x)=684
Let a = 3x
(a)(34)-5a=684
Once again I am not sure if my approach is completely wrong or I am just at a loss on what to do afterward.
3)
7(42x)=28(4x)
7(4x)2=28(4x)
Let a=4x
7a2=28a
a2=28a/7
a2=4a
Im not sure what to do after this
##\log_2 ((16)\sqrt{8})## or ##\sqrt{8}\times \log_2 ((16))## ?
The former
I edited the OP to make it a little clearer
onemic said:
The former
Use ##\log_a(bc) = \log_a(b) + \log_a(c)##, ##16 = 2^4## and same for ##\sqrt{8}##.
For the other two you need to take log on both sides.
so the first one would be:
##\log_2(16) + \log_2(\sqrt{8})##
##\log_2(2^4) + \log_2(2\sqrt{2})##
and I am not really sure what to do with the square root
For the other two questions, is what I have so far correct and I need to take the log on both sides from the point where I am at or is the whole thing wrong?
No you are not getting it. You should try to use ##\log_a(b^c) =c\log_ab##. Now if ##a =b## then ##c\log_a(a) = ?##
What you did is correct, now you need to solve for 'a' then take log to 'x'.
Write ##\sqrt{8}## in form of 2a, power of 2 .
Likes onemic and SammyS
onemic said:
2)
3(x+4)−5(3x)=684
=(3x)(34)-5(3x)=684
Let a = 3x
(a)(34)-5a=684
How much is 34?
onemic said:
3)
7(42x)=28(4x)
7(4x)2=28(4x)
Let a=4x
7a2=28a
a2=28a/7
a2=4a
Rewrite the equation in form a2-4a =0, and factor out a. Remember, a product is zero if any of the factors is zero. What solutions do you get for a? Are both valid?
Likes onemic
Sorry for the super late reply. I decided to continue on with other questions and the next unit before coming back to this.
1)
##\log_2(2^4)(2^3)^{0.5}##
##\log_2(2^4)(2^{1.5})##
##\log_2(2^{5.5})##
##5.5\log_2(2)##
##=5.5##
2)
wow I don't know why this question shook me. The answer was in my face the entire time haha.
(starting from where I left off in the OP)
##81a-5a=684##
##76a=684##
##a=684/76##
##a=9##
##3^x=9##
##x=2##
3)
##a^2=4a##
##4^{2x}=(4)4^x##
##4^{2x}=4^{x+1}##
##2x=x+1##
##2x-x=1##
##x=1##
EDIT: thanks for the heads up on the typo
1)
##\log_2(2^4)(2^3)^\color{red}{0.5}##
##\log_2(2^{5.5})##
##5.5\log_2(2)##
##=5.5##
2)
##81a-5a=684##
##76a=684##
##a=684/76##
##a=9##
##3^x=9##
##x=2##
3)
##a^2=4a##
##4^{2x}=(4)4^x##
##4^{2x}=4^{x+1}##
##2x=x+1##
##2x-x=1##
##x=1##
I guess it is correct except one typo.
##81a-5a=684##
##76a=684##
##a=684/76##
##a=9##
##3^x=9##
##x=2##
It's a good habit to get into to check your answer by substituting your value of x in the original equation.
onemic said:
3)
##a^2=4a##
##4^{2x}=(4)4^x##
##4^{2x}=4^{x+1}##
##2x=x+1##
##2x-x=1##
##x=1##
You started off in the direction that @ehild suggested, but then went off in a different direction. Following the direction she suggested you would have this:
Are you sure there aren't solutions other than x = 1, which is the one you showed?
doing it that way I get:
##a^2-4a=0##
##a(a-4)=0##
##a=4## or ##a=0##
##a=4##
##4^x=4##
##x=1##
##a=0##
##4^x=0##
*no solutions*
therefore the correct answer is ##x=1##
##a^2-4a=0##
##a(a-4)=0##
##a=4## or ##a=0##
##a=4##
##4^x=4##
##x=1##
##a=0##
##4^x=0##
*no solutions*
Looks good!
Likes onemic
Related to Exponential and logarithmic Equation Problems
1. What is an exponential equation?
An exponential equation is an equation in which the variable appears as an exponent. It can be written in the form y = ab^x, where a and b are constants and x is the variable. Exponential equations are commonly used to model situations that involve growth or decay.
2. How do I solve an exponential equation?
To solve an exponential equation, you can use the properties of logarithms or take the logarithm of both sides of the equation. This will allow you to isolate the variable and solve for its value. You can also use a calculator to find the value of the variable.
3. What is a logarithmic equation?
A logarithmic equation is an equation in which the variable appears as the argument of a logarithm. It can be written in the form y = logbx, where b is the base of the logarithm. Logarithmic equations are commonly used to solve for the exponent in an exponential equation or to find the inverse of an exponential function.
4. How do I solve a logarithmic equation?
To solve a logarithmic equation, you can use the properties of logarithms or exponentiate both sides of the equation. This will allow you to isolate the variable and solve for its value. You can also use a calculator to find the value of the variable.
5. What are some real-life applications of exponential and logarithmic equations?
Exponential and logarithmic equations have many real-life applications, such as modeling population growth, radioactive decay, and compound interest. They are also used in physics, chemistry, and biology to describe various natural phenomena. Additionally, logarithmic equations are used in signal processing and earthquake magnitude scales.
