MHB Exponential and Logarithmic Functions
The discussion revolves around solving the exponential function y = Ce^(kt) using given values to find constants k and C. Participants suggest using the provided data points, y = 100 when t = 2 and y = 300 when t = 4, to compute k. To find C, either of the two values can be substituted back into the equation. The conversation also hints at converting the exponential equation into logarithmic form for further analysis. The overall focus is on applying mathematical techniques to derive the constants from the exponential function.
qtheory
y=CektA) First find k. [Hint:Use the given information of y=100 when t=2, and y=300 when t=4 to compute k.]
B) Finally, find the value for C. [Hint use ine of the two pieces of information given in the problem to solve for C. in other words, use either y=100 when t=2 or use y=300 when 4=4 to compute C]. [Hint: to find t use y=1].
Mathematics news on Phys.org
DISCLAIMER: Beer soaked rambling/opinion/observation/reckoning ahead. Read at your own risk. Not to be taken seriously. In no event shall the wandering math knight-errant Sir jonah in his inebriated state be liable to anyone for special, collateral, incidental, or consequential damages in connection with or arising out of the use of his beer (and tequila) powered views.
Is that a challenge problem? I'm heavily intoxicated at the moment so it's not obvious if it is or not.
We are given:
$$y=Ce^{kt}$$
First, divide through by $C\ne0$ to get:
$$\frac{y}{C}=e^{kt}$$
Next convert from exponential to logarithmic form...what do you get?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
10K
