Why Are Exponential Growth Equations Different?
In summary, The book says an amount is growing by 2% per year, and says that K, the growth constant, in this case is k = .02. My confusion is, I thought you could set up the equation of this to be Y=A(1.02)^(t) "A" being the initial amount, and here I can see it is also Y=A*e^(.02*t) since k=.02 yet these equations are not the same and I am very confused because if you plug in one year length (t=1) then the initial amount has grown by 1.02 (or increased by 2%) and this is not the case for the
Jonnyb42
186
I am learning calculus from a book of mine, and it gave an example problem of exponential growth (as derived from the exponential differential equation of dy/dx = ky to be y=Ce^kt) saying a population is growing at a rate of 2% per year, and says that K, the growth constant, in this case is k = .02. My confusion is, I thought you could set up the equation of this to be Y=A(1.02)^(t) "A" being the initial amount, and here I can see it is also Y=A*e^(.02*t) since k=.02 yet these equations are not the same and I am very confused because if you plug in one year length (t=1) then the initial amount has grown by 1.02 (or increased by 2%) and this is not the case for the second equation. Could someone explain to me whether the book has set k to the wrong value (if an amount grows by x% by some time, the growth constant k is not that percentage) or why these equations are different, or if one is incorrect.
(The book says an amount is growing by 2% and then says that the growth constant k=.02)
hmm. k should be ln(1.02)
This is the difference between descrete time recurrence relation and continuous time "recurrence" relation.
In descrete time Y[n+1]=k*Y[n] you are dealing with sequences, and here the solution is a geometric series with q=k. In descrete time the equation implies a direct relation between the current value and the next value.
In continuous time the relation y'(t)=ky(t), you are dealing with function. Here the equation implies a relation between the current value of the function and its current rate of change.
That what sets the difference.
But by "sampling" you can rearrange the latter equation to take the form of the first equation.
Let's say we sample our function at intervals of [tex]\delta t[/tex] and we define Y[n] to be [tex]y(t=n\delta t)[/tex]. So the approximate derivative will be
[tex]\frac{Y[n+1]-Y[n]}{\delta t}[/tex]
Comparing with kY[n] (as the diff. equation gives) you have:
[tex]Y[n+1]=(k\delta t + 1)Y[n][/tex]
Here, as you said yourself, the discrete solution is:
[tex]Y[n]=Y[0](k\delta t +1)^{n}[/tex]
Now let's connect this to the continuous case:
Remember that [tex]n=\frac{t}{\delta t}[/tex]
So an approximate evaluation of y(t) is:
[tex]y(t)=y(0)(k\delta t +1)^{\frac{t}{\delta t}}[/tex]
To get this approximation more and more accurate, we need to sample more frequently, or in other words, have [tex]\delta t[/tex] be as small as possible. We take the limit of the left-havd expression at [tex]\delta t --> 0[/tex], and if you remember the defenition of e, you get back your expected solution:
[tex]y(t)=y(0)e^{kt}[/tex]
wow, thanks elibj. I believe the book was incorrect, the growth constant K refers to the relation between the current value and it's rate of change, which is not the same constant as the relation between current value and next value. Thanks again you guys.
elibj123 said:
...We take the limit of the left-havd expression at [tex]\delta t --> 0[/tex], and if you remember the defenition of e, you get back your expected solution:
I know this is off subject, but what do I need to load onto my computer in order to see your nicely formatted latex formulas? I can see the source code but not the resulting image.
Related to Why Are Exponential Growth Equations Different?
What is the exponential growth constant?
The exponential growth constant, also known as the natural growth rate or e, is a mathematical constant that represents the rate at which a quantity increases exponentially over time.
What is the significance of the exponential growth constant?
The exponential growth constant is significant in many fields of science, including biology, economics, and physics. It is used to model natural phenomena such as population growth, compound interest, and radioactive decay.
How is the exponential growth constant calculated?
The exponential growth constant, e, is approximately equal to 2.71828. It can be calculated using the formula e = limn→∞ (1 + 1/n)n, where n is a very large number.
What are some real-world examples of exponential growth?
One example of exponential growth is the spread of a virus in a population. As more people become infected, the rate of growth increases exponentially. Another example is the growth of a bank account with compound interest, where the balance increases exponentially over time.
How does the exponential growth constant differ from other growth constants?
The exponential growth constant, e, is unique in that it is the only growth constant that has a rate of change proportional to its current value. Other growth constants, such as the golden ratio and the silver ratio, have fixed values and do not change over time.
  • Differential Equations
  • Calculus
