Exponential rate? when will the pressure be 2500 millibar?
In summary, exponential rate is a rate of change that is proportional to the current value of a quantity, resulting in a continuously increasing or decreasing value. It differs from linear rate, which is based on a constant numerical change. An example of a real-world phenomenon that follows an exponential rate is population growth. The formula for calculating exponential rate is (ln(Pt) - ln(P0)) / t, and it can be used to find the time at which a given value will be reached. For example, using an exponential rate of 5% per minute, the pressure will reach 2500 millibar in approximately 23.6 minutes. However, this is only an estimate and may vary depending on specific conditions.
i_m_mimi
[10] The air pressure in an automobile's spare tire was initially 3000 millibar.
Unfortunately, the tire had a slow leak. After 10 days the pressure in the tire had declined to 2800 millibar. If P(t) is the air pressure in the tire at time t,then P(t) satis es the di erential equation
dP/dt = −k(P(t)−A);
where k is a constant and A is the atmospheric pressure. For simplicity, take
atmospheric pressure to be 1000 millibar. When will the pressure in the tire be
2500 millibar?
answer:
10*[ln(4/3)]/[ln(10/9)]
P(t) = Ce^-kt
0 = 3000e^-k(0)
2800 = 3000 e^-k(10days)
k = -[ln 28/30]/10
2500 = 3000 e^[ln 28/30]t/10
t = 10 [ln 25/30]/[ln 28/30] wrong answer
dP/dt = 0.1 ln(28/30) (P(t) - 1000)
I can't figure out what is the function P(t) = ? or where to put in variable t, time. And where does the dP/dt equation come in? this is a complicated exam question worth 10 marks with 20 minutes allocated to it.
thank you
The function P(t) must satisfy the differential equation. Have you checked to see if this is the case?
Your problem appears to be that you have neglected the atmospheric pressure, A.
From "dP/dt = −k(P(t)−A)" with A= 1000, dP/(P- 1000)= -kdt so that ln(P- 1000)= -kt+ c and then
[itex]P- 1000= Ce^{-kt}[/itex]
Alternatively, define a new dependent variable, Q= P- 1000, the difference between the pressure in the tire and atmospheric pressure, so that your differential equation becomes
"dQ/dt= -kQ" and you CAN use "Q= Ce^{-kt}", but, of course remember to subtract 1000 from each of the given tire pressures: that is, initially Q= 3000- 1000= 2000, after 10 days, Q= 2800- 1000= 1800, and the question is asking for t when Q= 2500- 1000= 1500.
I'm closer to the answer now, but still something wrong
I tried using this equation, but my answer was something like t = 10*ln 0.5 / ln(3/5)
Tried it again using another equation you gave me:
dP/dt = −k(P(t)−A)
dP/[P(t)-A] = -kdt
took the integral of both sides
ln [P(t)-1000] = -kt + C
P(t)-1000 = e^-kt+c
3000-1000 = e^-k(0)+c
c = ln2000
2800 - 1000 = e^-k(10)+ln2000
k = -(ln9/10)/10
2500 - 1000 = e^(ln9/10)/10 (t)+ln2000
t = 10ln0.75/ln0.9
My fractions seem to be the inverses of the answer's fractions, what did I do wrong?
thanks
[tex]
\frac{\ln \left( \frac{3}{4} \right)}{\ln \left( \frac{9}{10} \right)} = \frac{\ln(3) - \ln(4)}{\ln(9) - \ln(10)} = \frac{-(\ln(4) - \ln(3))}{-(\ln(10) - \ln(9))} = \frac{\ln \left( \frac{4}{3} \right)}{\ln \left( \frac{10}{9} \right)}
[/tex]
Your result is correct but your derivation is hard to follow, e.g.:
P(t)-1000 = e^-kt+c
should be:
P(t)-1000 = e^(-kt+c)
etc.
Related to Exponential rate? when will the pressure be 2500 millibar?
1. What is the definition of "exponential rate" in scientific terms?
The exponential rate is the rate of change of a quantity over time that is proportional to the current value of the quantity. This means that the quantity is growing or decaying at a constant percentage rate.
2. How is exponential rate different from linear rate?
The main difference between exponential rate and linear rate is that exponential rate is based on a constant percentage change, while linear rate is based on a constant numerical change. This means that exponential rate results in a continuously increasing or decreasing value, while linear rate results in a steady increase or decrease.
3. Can you provide an example of a real-world phenomenon that follows an exponential rate?
One example of a real-world phenomenon that follows an exponential rate is population growth. As the population grows, the rate of growth increases, resulting in an exponential curve.
4. How can we calculate exponential rate?
The formula for calculating exponential rate is: r = (ln(Pt) - ln(P0)) / t, where r is the exponential rate, Pt is the final value of the quantity, P0 is the initial value of the quantity, and t is the time period over which the change occurs.
5. When will the pressure be 2500 millibar if it is increasing at an exponential rate of 5% per minute?
To find the time at which the pressure will be 2500 millibar, we can use the formula: t = ln(2500/1000)/ln(1.05). This gives us a time of approximately 23.6 minutes. However, please note that this is an estimate and the actual time may vary depending on the specific conditions and factors affecting the pressure change.
