Exponential revision question I can't work out?
In summary: If you have i/12.5 = 1 - e-t/cr, what can you add to the 1 on the right side to get rid of it? In other words, what + 1 =... equation does this solve to get i/12.5?i/12.5 = 1 - e-t/cr1 + e-t/cr = i/12.5This equation solves to i/12.5.
Ramjam
< Mentor Note -- Thread moved from the Calculus forum to HH/Calculus >
Hey everyone, I've started my new course and have been given revision and tutorial questions to do at home, this question has been bugging me for days now! I need to make "t" the subject to allow me to progress into the solution further.
Make t the subject in " i=12.5(1-e^-t/cr) "
I know that i need to use natural logs (ln) however i cannot seem to transpose the equation correctly. Could you please help me transpose this.
Thanks
Ramjam
p.s forgot to add my working so far, DUH!
ive transposed it to this form so far
i/12.5 = 1 - e ^-t/cr
this is where the logs come in and i have trouble, I am not sure what to do next?!?
Before taking logs, you must make [itex]e^{-t/cr}[/itex] the subject.
This is very unclear.
The quantity in parentheses could be any of the following:
##1 - \frac{e^{-t}}{cr}##
##1 - \frac{e^{-t}}{c}r##
##1 - e^{-t/c * r}##
Thanks
Ramjam
No, logs don't come in yet. You still have that 1 on the right side.
How do I go about removing the one on the right hand side, is it correct for me to move it to the left hand side, leaving e^-t/cr on the right?
He might even mean ##\frac{1-e^{-t}}{cr}##. For some unknown reason, he refuses to deal with your question.
My lecturer hinted that the 1 should be moved leaving e^t/cr on the right, however unsure how to transpose it to that
I moved this to the pre-calc forum since the issue is apparently about basic algebra.
Please address the question I asked in post #3.
1-e-t/cr sorry my phone cut your post so I didn't understand what you meant
You have
Ramjam said:
i/12.5 = 1 - e -t/cr
What can you do to both sides of this equation so that the 1 on the right side is gone? Possible choices are to add the same number toboth sides, subtract the same number from both sides, multiply both sides by the same nonzero number, or divide both sides by the same nonzero number.
If I was to add 1 to both sides e.g i/12.5 + 1 = 1-1e-t/cr is this acceptable? As then the one can be removed from the right ?
No, plus it's wrong.
i/12.5 = 1 - e-t/cr
If you add 1 to both sides, you get
i/12.5 + 1 = 1 - e-t/cr + 1 = 2 - e-t/cr
So that's no help at all.
Note that 1e-t/cr is exactly the same as e-t/cr, so there's no point in writing a coefficient of 1 here.
Nope.
Could you possibly take me through step by step how to remove 1 from the right leaving e-t/cr so that I can see how it's done, as confusing my self now
Ramjam
There is no "step by step" here - this is not a complicated process. Earlier in this thread you said,
You added 1 to the left side, but you didn't add 1 to the right side. Whatever you do to one side of the equation, you have to do the same to the other side.
If you have i/12.5 = 1 - e-t/cr, what can you add to the 1 on the right side to get rid of it? In other words, what + 1 = 0?
Okay so adding -1 to both sides i/12.5 -1 = 1-e-t/cr -1
which when becomes i/12.5 -1 = -e-t/cr
isnt the minus infront the the "e" become an issue? as you can log "-e"
Thankyou for your help on the matter
You can still multiply both sides by the same factor...
(and you should try those basic steps yourself)
Yes.
So what can you do to get rid of the minus sign? Remember to do the same thing to both sides of the equation.
Mark44 said:
Yes.
Umm... I am not actually to sure? :/
Then try different things. At least one of them will work.
Well I've been trying things for the past half hour with no luck, I am not seeing how i can multiply both sides to remove the minus from the "e"
Then show your work please.
What could you multiply a negative number with to get a positive number?
By multiplying -1 to let's say -1 you get 1, therefore I can see that by multiplying -1 to my equation will result in the right hand side becoming
e-t/cr
However if i was then to multiply the other side as required i don't see what i will get?
e-t/cr
Show us what you get when you multiply the left side by -1.
- l/12.5 -1 ?
Ramjam said:
- l/12.5 -1 ?
OK, what's the complete equation?
- l/12.5-1=e-t/cr
However doesn't this cause another issue with now there's a negative on the left preventing me logging?
Ramjam said:
- l/12.5-1=e-t/cr
i is a variable - it could be positive or negative.
In your original equation, which was ##i = 25(1 - e^{-t/(cr)})##, if e-t/(cr) > 1, then i will be negative.
The original equation was i = 12.5(1-e-t/cr the reason it became i over 12.5 was because i divided 12.5 on both sides to remove it from the right.
Heres the full question that i should of probably started with (my mistake) The current, i, flowing in a capacitor at time, t, is given by i = 12.5(1-e-t/cr where resistance, R, is 30KΩ and capacitance, C, is 20μF Determine the time for the current to reach 10 amperes?
So i know that by dividing both sides by 12.5 allows me to get i/12.5 = 1-e-t/cr and then by subtracting -1 from both sides gives me i/12.5 -1 = -e-t/cr, then by multiplying by -1 give me - i/12.5 = e-t/cr from this point on can i log both sides as the minus on the left is there?
Yes, you should have given us the complete problem statement. With the i, C and R, I figured this was a problem about an RC circuit.
No. Before you multiplied, the left side was i/12.5 - 1. After you multiplied by -1, what happened to the -1?
  • #31
opps sorry that should be -i/12.5-1=e-t/cr
  • #32
No, that's not right either. You really need to be more careful.
  • #33
in that case i don't under what you mean by
  • #34
What is -1 times i/12.5 - 1?
If you're having such a difficult time with basic algebra, I am very concerned about the prospects of you working with exponential and log equations.
  • #35
It was 2am in the uk and after a long working day which i also do along side my course probably wasn't the best idea.
Right here are my working so far now that I've been had some sleep,
we start with I=12.5(1-e-t/cr)
I then divide both sides by 12.5 removing the 12.5 from the right hand side.
I/12.5 = 1-e-t/cr
I then subtract -1 from both sides
I/12.5 -1 = -e-t/cr
I then times both sides by -1 giving me
(1- I/12.5) = e-t/cr
how ever to remove I am unsure of how to go on from here?
<h2>1. What is exponential revision and why is it important?</h2><p>Exponential revision is a study technique that involves reviewing material at increasingly spaced intervals. It is important because it helps to strengthen long-term memory and improve retention of information.</p><h2>2. How do I know when to use exponential revision?</h2><p>Exponential revision is most effective for studying complex or difficult material that requires long-term retention. It is also useful for preparing for exams or learning new skills.</p><h2>3. How do I create an exponential revision schedule?</h2><p>To create an exponential revision schedule, you can use a study planner or online tools that allow you to input the material you need to review and the intervals at which you want to review it. You can also manually create a schedule by spacing out your review sessions at increasing intervals.</p><h2>4. Can I use exponential revision for all subjects?</h2><p>Exponential revision can be used for most subjects, but it is most effective for subjects that require long-term retention and understanding. It may not be as useful for subjects that require more short-term memorization, such as vocabulary or math equations.</p><h2>5. How do I avoid burnout when using exponential revision?</h2><p>To avoid burnout, it is important to take breaks and not overload your revision schedule. It is also helpful to vary your study methods and incorporate active learning techniques, such as practice quizzes or teaching the material to someone else.</p>
Related to Exponential revision question I can't work out?
  • Quantum Physics
15K
  • Differential Equations
  • Mechanical Engineering
