Exponents - Numbers with Variables
In summary, the term (9x)^{-1/2} can be simplified to 1/3sqrt(x), and the term [(25xy)^3/2] / x2y can be simplified to 125x^-1/2y^1/2.
cgr4
(9x)^-1/2
So, I'm not entirely sure how to go about this question.
It's got a negative exponent, so I assume its 1 / something.
My guess for the answer would be:
1 / 3x
[(25xy)^3/2] / x2y
For this question, would I compute 253/2 and then x3/2 y3/2 and then divide by x2y
Mathematics news on Phys.org
cgr4 said:
(9x)^-1/2
1 / 3x
Close. Remember that in addition to taking the square root of the $9,$ you also need to take the square root of the $x.$
\begin{align*}
(9x)^{-1/2} &= \frac1{(9x)^{1/2}}\\
&= \frac1{9^{1/2}x^{1/2}}\\
&= \frac1{3\sqrt x}.
\end{align*}
cgr4 said:
[(25xy)^3/2] / x2y
Yes. What do you get after you do that?
For the second question. It would look something like this?
125x3/2y3/2
x2y
then I would subtract x2 and y
which would equal 125x1/2y ?
No, you want to apply the property of exponents:
\(\displaystyle \frac{a^b}{a^c}=a^{b-c}\)
In other words, for each like base, you want to subtract the exponent in the denominator from the exponent in the numerator.
Still a little confused about the 2nd problem.
So
125x(3/2-2)y(3/2-2)
correct?
resulting in 125x-1y
125y
x
125y over x
So
125x(3/2-2)y(3/2-2)
correct?
Very close!
You have made a small typo.
125x(3/2-2)y(3/2-2) should read: 125x(3/2-2)y(3/2-1)
The final result should be:
\(\displaystyle 125 \cdot x^{-\frac12} \cdot y^{\frac12}\)
Re-write this term without the fractional exponents.
FAQ: Exponents - Numbers with Variables
What is an exponent?
An exponent is a number that represents the number of times a base number is multiplied by itself. It is written as a superscript to the right of the base number, such as 24 where 2 is the base and 4 is the exponent.
How do you simplify expressions with exponents?
To simplify expressions with exponents, you can use the exponent rules. These rules state that when multiplying terms with the same base, you add the exponents. When dividing terms with the same base, you subtract the exponents. When raising a power to a power, you multiply the exponents.
Can an exponent be a negative number?
Yes, an exponent can be a negative number. This indicates that the base number is being divided by itself a certain number of times. For example, 2-3 means 1 divided by 2 multiplied by itself 3 times, or 1/(2x2x2) = 1/8.
What is a variable exponent?
A variable exponent is an exponent that contains a variable, such as x2 or y3. This means that the base number is being multiplied by itself a certain number of times, where the number of times is represented by the variable.
How are exponents used in real life?
Exponents are used in many real life situations, such as calculating compound interest, representing population growth, and measuring sound intensity on the decibel scale. They are also used in scientific notation to represent very large or very small numbers more efficiently.
9K
