Express the equation in rectangular coordinates
In summary, in spherical coordinates, x is the radial coordinate, y is the angular coordinate, and z is the distance coordinate. X^2-y^2=z when the equation is expressed in rectangular coordinates.
Mdhiggenz
327
An equation is given in spherical coordinates. Express the equation in rectangular coordinates.
r2cos2∅=z
So first thing I did was used a half angle formula
r2 (cos2∅-sin2∅=z
Now, I'm stuck.
The answer is x2-y2=z
Guidance is appreciated (:
r2cos2∅=z
So first thing I did was used a [STRIKE]half[/STRIKE] double angle formula
r2 (cos2∅-sin2)=z
Now, I'm stuck.
That looks fine.
(You might like to use a symbol such as theta, θ, for an angle rather than the symbol used for the null set, ∅ . I don't know why phi, ϕ, is not include in the symbol box.)
Thanks for the response and sorry for the minor errors, I'm still a bit confused on how I can manipulate what I have to make it to look more like x^2-y^2=z.
What I'm thinking is if I just distribute the r^2. I will get (r^2cosθ^2)-(r^2sinθ^2)=z
and if rcosθ=x and rsinθ =y
then these are just the same values but squared. Which would give me X^2-y^2=z.
Would that be a correct assumption?
r2cos2∅=z
I assume that ∅ is meant to be [itex]\phi[/itex]?
There are 2 common conventions for spherical coordinates [itex](r, \theta, \phi)[/itex]. In one convetion,[itex]\theta[/itex] is the polar angle and [itex]\phi[/itex] is the azimuthal angle[/itex], and vice versa in the other convention. Which convention are you using?
r2 (cos2∅-sin2∅=z
What are [itex]x[/itex], [itex]y[/itex], and [itex]z[/itex] in terms of spherical coordinates? What is [itex]x^2-y^2[/itex]?
FAQ: Express the equation in rectangular coordinates
What does it mean to express an equation in rectangular coordinates?
Expressing an equation in rectangular coordinates means representing the equation in terms of x and y, with x being the independent variable and y being the dependent variable.
Why is it important to express equations in rectangular coordinates?
Expressing equations in rectangular coordinates allows for easier visualization and manipulation of the equation. It also allows for easier comparison and analysis of multiple equations.
What are the steps to express an equation in rectangular coordinates?
The steps to express an equation in rectangular coordinates are:
1. Identify the variables in the equation (usually x and y).
2. Isolate the dependent variable (y) on one side of the equation.
3. Simplify the equation by combining like terms.
4. Rewrite the equation in the form of y = mx + b, where m is the slope and b is the y-intercept.
Can any equation be expressed in rectangular coordinates?
Yes, any equation can be expressed in rectangular coordinates as long as it includes at least one independent variable (usually x) and one dependent variable (usually y).
What is the difference between polar coordinates and rectangular coordinates?
Polar coordinates use a distance (r) and angle (θ) to represent a point, while rectangular coordinates use horizontal (x) and vertical (y) distances. Polar coordinates are commonly used in fields such as physics and engineering, while rectangular coordinates are commonly used in algebra and calculus.
