MHB Express the value in a single fraction
  • Thread starter Thread starter anemone
    Fraction Value
The discussion revolves around solving the equation involving real numbers \(x_1, x_2, x_3, x_4, x_5\) that satisfy a specific condition for \(m = 1, 2, 3, 4, 5\). The solution yields the value of \(\dfrac{x_1}{37}+\dfrac{x_2}{38}+\dfrac{x_3}{39}+ \dfrac{x_4}{40}+\dfrac{x_5}{41}\) as the fraction \(\frac{187465}{6744582}\). Additionally, a continued fraction representation and a unit fraction expansion are provided, showcasing the complexity of the solution. Participants are encouraged to share their methods for solving the problem, emphasizing collaborative learning. The thread highlights the intricate relationship between algebraic expressions and their fractional representations.
anemone
MHB
POTW Director
Let $x_1, x_2, x_3, x_4, x_5$ be real numbers satisfying the following equation:
$\dfrac{x_1}{m^2+1}+\dfrac{x_2}{m^2+2}+\dfrac{x_3}{m^2+3}+\dfrac{x_4}{m^2+4}+\dfrac{x_5}{m^2+5}= \dfrac{1}{m^2}$ for $m=1, 2, 3, 4, 5$.
Find the value of
$\dfrac{x_1}{37}+\dfrac{x_2}{38}+\dfrac{x_3}{39}+ \dfrac{x_4}{40}+\dfrac{x_5}{41}$
Mathematics news on Phys.org
[sp]
Fraction:$\frac{187465}{6744582}$
Continued fraction: $[0,35,1,44,111,2,2,12,4]$
Unit fraction expansion: $\frac{1}{36}+\frac{1}{58395}+\frac{1}{9724688047}+\frac{1}{283708672824669334580}$
[/sp]
eddybob123 said:
[sp]
[/sp]
Thank you so much for participating, eddybob123.
Your answer is correct, but I hope you can share with me the method you used to solve this problem. :o
By sharing that means a brief explanation on the concept that you employed will suffice.
Find the value of
Solution provided by other:
Let $f(x)=\dfrac{x_1}{m^2+1}+\dfrac{x_2}{m^2+2}+\dfrac{x_3}{m^2+3}+\dfrac{x_4}{m^2+4}+\dfrac{x_5}{m^2+5}$, then
$f(\pm 1)=1$, $f(\pm 2)=\dfrac{1}{4}$, $f(\pm 3)=\dfrac{1}{9}$, $f(\pm 4)=\dfrac{1}{16}$, $f(\pm 5)=\dfrac{1}{25}$, and $f(6)$ is the value to be found.
Next, we let $g(x)=(x^2+1)(x^2+2)(x^2+3)(x^2+4)(x^2+5)$ and $h(x)=f(x)g(x)$.
Then for $m=\pm1, \pm2, \pm3, \pm4, \pm5$, we get $h(x)=f(x)g(x)=\dfrac{g(x)}{m^2}$, i.e. $g(x)-m^2h(x)=0$.
Since $g(x)-x^2h(x)$ is a polynomial of degree 10 with roots $\pm1, \pm2, \pm3, \pm4, \pm5$, we get
$g(x)-x^2h(x)=A(x^2-1)(x^2-4)(x^2-9)(x^2-16)(x^2-25)$ (*)
Putting $x=0$ we get $A=\dfrac{g(0)}{(-1)(-4)(-9)(-16)(-25)}=-\dfrac{1}{120}$.
Finally, dividing both sides of (*) by $g(x)$ gives
$\dfrac{g(x)-x^2h(x)}{g(x)}=-\dfrac{(x^2-1)(x^2-4)(x^2-9)(x^2-16)(x^2-25)}{120g(x)}$ (*)
$1-x^2\dfrac{h(x)}{g(x)}=1-x^2f(x)=-\dfrac{1}{120}\cdot\dfrac{(x^2-1)(x^2-4)(x^2-9)(x^2-16)(x^2-25)}{(x^2+1)(x^2+2)(x^2+3)(x^2+4)(x^2+5)}$ and hence
$1-36f(6)=\dfrac{35\cdot32\cdot27\cdot20\cdot11}{120 \cdot 37\cdot38\cdot39\cdot40\cdot41}=-\dfrac{231}{374699}$,
which implies $f(6)=\dfrac{187465}{6744582}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
