Expressing phase space differential in terms of COM
In summary, the Hamiltonian for a single diatomic molecule of identical atoms can be expressed in terms of the center of mass and relative coordinates. By using these coordinates, the Hamiltonian simplifies to a form that is easier to work with. The grand canonical partition function for a gas of such molecules can be calculated by integrating over the momenta and positions of the molecules, and neglecting interactions between them.
ghostfolk
59
The Hamiltonian for a single diatomic molecule of identical atoms is given as $$H=\dfrac{\vec{p_1}\cdot\vec{p_1}}{2m}+\dfrac{\vec{p_2}\cdot\vec{p_2}}{2m}+\dfrac{K}{2}(\vec{r_1}-\vec{r_2})\cdot(\vec{r_1}-\vec{r_2})$$. Find the grand canonical partition function for a gas of such molecules, neglecting the interactions between molecules.
2. Homework Equations
$$Z=\dfrac{1}{N!}\int\dfrac{d^3p_id^3x_i}{h}e^{-\beta H}$$
I know that if we can express the momenta in terms of the center of mass coordinates and the relative coordinates, $$R=(r_1+r_2)/2$$ and $$r=r_1-r_2$$. However I am not sure how to express the differential in terms of the center of mass and relative coordinates.
You have the relative coordinate r = r1-r2 and the COM coordinate R = (r1m1 + r2m2)/(m1+m2). It's easy to show that:
∂ /∂r1 = m1/(m1+m2)∂ /∂R + ∂ /∂r and
∂ /∂r2 = m2/(m1+m2)∂ /∂R - ∂ /∂r.
The Hamiltonian becomes
H(r,R) = -ħ2/(2M)(∂2 /∂R2 )- ħ2/(2μ))(∂2 /∂r2) + K/2(r⋅r)
where M = m1+ m2 and μ=(m1m2)/(m1+ m2).
FAQ: Expressing phase space differential in terms of COM
What is phase space differential?
Phase space differential is a mathematical concept used in physics to describe the behavior of a physical system over time. It takes into account both the position and momentum of a particle or group of particles in a given space.
What does COM stand for in the context of expressing phase space differential?
COM stands for "center of mass." It is a point in a physical system where the overall mass is equally distributed on all sides. In the context of phase space differential, it is used as a reference point for calculating the position and momentum of particles.
How do you express phase space differential in terms of COM?
In order to express phase space differential in terms of COM, you must first define the position and momentum of each particle in the system relative to the COM. Then, you can use mathematical equations, such as the Lagrange equations, to determine the overall behavior of the system in terms of the COM.
Why is it important to express phase space differential in terms of COM?
Expressing phase space differential in terms of COM allows us to simplify the mathematical calculations and better understand the behavior of a physical system. It also provides a useful reference point for analyzing the overall motion and dynamics of particles in the system.
Are there any limitations to expressing phase space differential in terms of COM?
While expressing phase space differential in terms of COM is a useful approach, it may not be applicable to all physical systems. For example, if the particles in the system are not symmetrically distributed around the COM, this method may not accurately represent the behavior of the system. Additionally, it may not be suitable for systems with complex interactions or non-uniform mass distributions.
