MHB Expressing zeta(3) in terms of a Glaisher-Kinkelin-like constant
  • Thread starter Thread starter polygamma
    Constant Terms
The discussion focuses on expressing the Riemann zeta function at three, $\zeta(3)$, in terms of a constant related to the Glaisher-Kinkelin constant. It establishes that $\zeta(3) = 4 \pi^{2} \log B$, where $\log B$ is defined through a limit involving a summation and the Euler-Maclaurin summation formula. The thread also derives that $\zeta'(-2) = -\log B$, linking it to the functional equation of the Riemann zeta function. The existence of the constant $B$ is confirmed through convergence tests, and it is suggested that similar constants could express other zeta values, like $\zeta(5)$. The exploration highlights the intricate relationships within zeta functions and their constants.
polygamma
In a previous thread I showed how to express $\zeta'(-1)$ in terms of the Glaisher-Kinkelin constant.
http://mathhelpboards.com/challenge-questions-puzzles-28/euler-maclaurin-summation-formula-riemann-zeta-function-7702.html
This thread is about expressing $\zeta(3)$ (sometimes referred to as Apery's constant) in terms of a constant similar to the Glaisher-Kinkelin constant.
Specifically, $$\zeta(3) = 4 \pi^{2} \log B$$ where $$\log B = \lim_{n \to \infty} \left[ \sum_{k=1}^{n} k^{2} \log k - \left(\frac{n^{3}}{3} + \frac{n^{2}}{2} + \frac{n}{6} \right) \log n + \frac{n^{3}}{9} - \frac{n}{12} \right] $$
Use the Euler-Maclaurin summation formula (or perhaps summation by parts) to show that the constant $B$ exists.Then using the representation of the Riemann zeta function derived in the other thread,
$$ \zeta(s) = \lim_{n \to \infty} \left( \sum_{k=1}^{n} k^{-s} - \frac{n^{1-s}}{1-s} - \frac{n^{-s}}{2} + \frac{s n^{-s-1}}{12} \right) \ \ \big(\text{Re}(s) > -3 \big) $$
show that
$$ \zeta'(-2) = - \log B $$Finally use the functional equation of the Riemann zeta function to show that $$ \zeta(3) = 4 \pi^{2} \log B $$
Mathematics news on Phys.org
Let $f(x) = x^{2} \ln x$.
Then
$$ \sum_{k=1}^{n-1} f(k) = \sum_{k=1}^{n} f(k) - n^{2} \ln n = \int_{1}^{n} f(x) \ dx + B_{1} \Big(f(n) -f(1) \Big) + \frac{B_{2}}{2!} \Big( f'(n) - f'(1) \Big) $$
$$ + \frac{1}{3!} \int_{1}^{n} B_{3} (x - \lfloor x \rfloor) f^{'''}(x) \ dx$$$$ = \frac{x^{3} \log x}{3} - \frac{x^{3}}{9} \Big|_{1}^{n} - \frac{1}{2} \Big(n^{2} \ln n -0 \Big) + \frac{1}{12} \Big(2n \ln n + n -1 \Big) + \frac{1}{6} \int_{1}^{n} B_{3} (x - \lfloor x \rfloor) \frac{2}{x} \ dx$$
$$ = \frac{n^{3} \log n}{3} - \frac{n^{3}}{9} + \frac{1}{9} - \frac{n^{2} \ln n}{2} + \frac{n \log n}{6} + \frac{n}{12}- \frac{1}{12} + \frac{1}{3} \int_{1}^{n} \frac{B_{3} (x - \lfloor x \rfloor)}{x} \ dx$$$$ \implies \sum_{k=1}^{n} k^{2} \ln k - \Big( \frac{n^{3}}{3} + \frac{n^{2}}{2} + \frac{n}{6} \Big) \ln n + \frac{n^{3}}{9} - \frac{n}{12} = \frac{1}{36} + \frac{1}{3} \int_{1}^{n} \frac{B_{3} (x - \lfloor x \rfloor)}{x} \ dx$$Now take the limit of both sides of the equation.
The integral $ \displaystyle \int_{1}^{\infty} \frac{B_{3} (x - \lfloor x \rfloor)}{x} \ dx$ converges (condtionally) by Dirichlet's convergence test for integrals.
Therefore,
$$ \log B = \lim_{n \to \infty} \left[ \sum_{k=1}^{n} k^{2} \log k - \left(\frac{n^{3}}{3} + \frac{n^{2}}{2} + \frac{n}{6} \right) \log n + \frac{n^{3}}{9} - \frac{n}{12} \right] $$
exists.From the other thread,$$ \zeta'(s) = \lim_{n \to \infty} \Bigg[- \sum_{k=1}^{n} k^{-s} \log k - \frac{-n^{1-s} (1-s) \log n +n^{1-s}}{(1-s)^{2}} + \frac{n^{-s} \log n}{2} $$
$$ + \frac{1}{12} \left(n^{-s-1}- sn^{-s-1} \log n \right) \Bigg] \ \ (\text{Re}(s) > -3)$$Plug in $s=-2$ to get
$$ \zeta'(-2) = \lim_{n \to \infty} \Bigg[- \sum_{k=1}^{n} k^{2} \log k - \frac{-3n^{3} \log n +n^{3}}{9} + \frac{n^{2} \log n}{2} + \frac{1}{12} \left(n+2n \log n \right) \Bigg] $$
$$ = \lim_{n \to \infty} \left[ -\sum_{k=1}^{n} k^{2} \log k + \left(\frac{n^{3}}{3} + \frac{n^{2}}{2} + \frac{n}{6} \right) \log n - \frac{n^{3}}{9} + \frac{n}{12} \right] = - \log B$$Next differentiate the functional equation of the Riemann zeta function.
$$ \zeta'(s) = \log (2) 2^{s} \pi^{s-1} \sin \left( \frac{\pi s}{2} \right) \Gamma(1-s) \zeta(1-s)+ \log(\pi) 2^{s} \pi^{s-1} \sin \left( \frac{\pi s}{2} \right) \Gamma(1-s) \zeta(1-s)$$
$$ + \frac{\pi}{2} 2^{s} \pi^{s-1} \cos \left( \frac{\pi s}{2} \right) \Gamma(1-s) \zeta(1-s) - 2^{s} \pi^{s-1} \sin \left( \frac{\pi s}{2} \right) \Gamma'(1-s) \zeta(1-s)$$
$$ -2^{s} \pi^{s-1} \sin \left( \frac{\pi s}{2} \right) \Gamma(1-s) \zeta'(1-s)$$At $s=-2$,
$$ \zeta'(-2) = \frac{\pi}{2} 2^{-2} \pi^{-3} \cos \left( -\pi \right) \Gamma(3) \zeta(3) = -\frac{\zeta(3)}{4 \pi^{2}}$$Which implies
$$ \zeta(3) = -4 \pi^{2}\zeta(-2) = 4 \pi^{2} \log B $$
As far as I know, the constant $B$ doesn't have a name. But it can be found in several papers.
I'm pretty sure you could express $\zeta(5)$ in terms of a similar constant. But that would require using a different representation of the Riemann zeta function.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
