Expression for Electric Field Outside Sphere
The discussion centers on understanding the electric field outside a sphere using Gauss's law. Participants express confusion over a question that describes a sphere as both uniformly charged and having a variable charge density, which is contradictory. Clarification is sought on the intended meaning of the question. The importance of making an effort to solve the problem before seeking help is emphasized. Overall, the conversation highlights the need for precise language in physics problems.
eric11201120
The charge desnsity within a sphere of radius R is ρ = ρ0 - ar2, where ρ0 and a are constants and r is the distance from the center. Find an expression for a such that the electric field outside the sphere is zero.
Electric Field outside a sphere
E = KQ/r2
Electric flux
ΦE=∫EdA
I'm not quite sure where to start. If someone could help me I would very much appreciate it.
Hint 1: What does Gauss's law tell you?
Hint 2: Given that expression for charge density, what's the total charge within the sphere?
Likes eric11201120
Likes eric11201120
Steve4Physics said:
But there seems to be a mistake in the question. The sphere can't be both 'uniformly charged' and have a charge density which is a function of r.
Yes, a very sloppily worded question!
Likes eric11201120
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
