A Expression of Shot noise when expanding ##a_{\ell m}## coefficients
The discussion focuses on deriving the expression for the quantity o_ℓ in the context of dark matter and Poisson noise. The proposed formula is o_ℓ = b_sp² C_ℓ^{DM} + B_sp, where B_sp represents the Poisson noise defined as B_sp = 1/𝑛̄. The expansion of o_ℓ leads to the conclusion that the term <(a_ℓm^P)²> must be justified as equal to 1/𝑛̄, raising questions about its relationship to variance. Clarification is needed on how B_sp relates to the variance of a non-centered Poisson distribution, given that <a_ℓm^P> does not equal zero. Ultimately, the total signal C_ℓ is expressed as C_ℓ = b_sp² C_ℓ^{DM} + B_sp.
fab13
TL;DR Summary
I would like to prove that Shot noise follows a Poisson distribution.
I would like to arrive at the following expression for the quantity ##o_{\ell}## ( with "DM" for Dark Matter ):
##o_{\ell}=b_{s p}^2 C_{\ell}^{D M}+B_{s p}##
with Poisson noise ##B_{s p}=\frac{1}{\bar{n}}(\bar{n}## being the average number of galaxies observed). the index "sp" is for spectro. I think for now that ##B_{s p}## is the variance of a Poisson noise but see the following below to really confirm: To arrive at this same expression, I would like to start from ##{ }_{\ell m}^{a D M}## (DM for Dark matter) and ##a_{\ell m}^P## (" ##\mathrm{P}## " for fish).
So I start from the fact that ##C_{\ell}=\operatorname{Var}\left(a_{\ell m}\right)## :
##o_{\ell}=<\left(b_{s p} a_{\ell m}^{D M}+a_{\ell m}^P\right)^2>##
If we expand, we have: ##o_{\ell}=<b_{s p}^2\left(a_{\ell m}^{D M}\right)^2+2 b_{s p} a_{\ell m}^{D M}+\left(a_{\ell m}^P\right)^2>##
##o_{\ell}=b_{s p}^2 C_{\ell}^{D M}+2 b_{s p}<a_{\ell m}^{D M}><a_{\ell m}^P>+<\left(a_{\ell m}^P\right)^2>##
##=b_{s p}^2 C_{\ell}^{D M}+<\left(a_{\ell m}^P\right)^2>##
because we have ##<a_{\ell_m}^{D M}>=0##
The problem comes from the term ##<\left(a_{\ell m}^P\right)^2>## : I don't know how to justify that this term is equal to ##\frac{1}{\bar{n}}##
Indeed, if ##B_{s p}## is a fish noise, we should have, to make the correspondence, ##B_{s p}=<\left(a_{\ell m}^P\right)^2>-<## ##a_{\ell m}^P>2## which is different from: ##B_{s p}=<\left(a_{\ell m}^P\right)^2>=\operatorname{Var}\left(a_{\ell m}^P\right)##.
How to obtain the quantity ##B_{s p}## which seems a priori equal to ##\frac{1}{\bar{n}}## ?
If ##B_{s p}## is equal to ##<\left(a_{\ell m}^P\right)^2>##, how to make the link with a variance since a Poisson law is not centered ( I mean ##<a_{\ell m}^P>\neq 0## ?
Astronomy news on Phys.org
There is a typo showed in attachment : the factor "2" is acutally an exponent in ##<a_{\ell m}^P>^2##.
Also (sorry), the initial quantity at the beginning ( ##o_{\ell}##) is simply the total signal ##C_\ell## :
is equal to :
##C_{\ell}=b_{s p}^2 C_{\ell}^{D M}+B_{s p}##
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
