Extended Kalman Filter: Helping hand to a newbie
In summary, The conversation discusses the implementation of extended Kalman filter and simulating positions of a point using angle measurements. The MATLAB script is shown, but it does not converge due to an error in the state update. The update should account for the movement of the observer.
Bilal_00780
I trying to learn extended kalman filter. I am trying to simulate positions of point by angle mearsurments taken by an observer moving on a straight line. The EKF implementation does not converge. Below the MATLAB script
clear all; close all; clc;
%Generate staright line positions
T=300;
phi=[1 T 0 0; 0 1 0 0; 0 0 1 T; 0 0 0 1]; %Constant velocity motion
X=[130;-0.1;11;0.1]; %[x xdot y ydot]
for i=2:14
X=[X phi*X(:,i-1)];
end
%Calculate angles along the route, which would be passed to EKF as measured
%angles along the route
xpoint=141;
ypoint=141;
betas=atan2((ypoint-X(3,:)),(xpoint-X(1,:)));
noise=normrnd(0,sqrt((1*pi/180)),size(betas));
betas=betas+noise;
ownPos=[X(1,:);X(3,:)];
plot(X(1,:),X(3,:),'b-*');
axis equal;
hold on;
plot(xpoint,ypoint,'r*');
text(xpoint,ypoint,' Point to be found');
%Initialize variables
H=zeros(1,2,size(betas,2));
K=zeros(2,1,size(betas,2));
Xhat=zeros(2,1,size(betas,2));
X_=zeros(2,1,size(betas,2)+1);
Phat=zeros(2,2,size(betas,2));
P_=zeros(2,2,size(betas,2)+1);
%Initialize State, Pocess noise, State error covariance & measurment noise matrices
X_(:,:,1)=[135; 135]; %Initial Pricted state
Q=[0.1 0;0 0.1]; %Process noise
P_(:,:,1)=[25 0;0 25]; %Initial Pricted state error covariance
R=[(pi/180)^2]; %Measurment noise
phi=eye(2,2); %State transition matrix, since x,y are constants
Xhist=[]; %Variable to record history of state
for k=1:size(betas,2)
uk=tan(betas(k)); %Observed angle
%Calculate linearized measurment matrix
hk1=-(uk/(1+uk^2))*(1/(X_(1,1,k)-ownPos(1,k)));
hk2=(1/(1+uk^2))*(1/(X_(1,1,k)-ownPos(1,k)));
H(:,:,k)=[hk1 hk2];
%Calculate Kalman gain using linearized measurment matrix
K(:,:,k)=P_(:,:,k)*H(:,:,k)'*(inv(H(:,:,k)*P_(:,:, k)*H(:,:,k)'+R));
%Compute updated state
Xhat(:,:,k)=X_(:,:,k)+K(:,:,k)*(betas(k)-H(:,:,k)*X_(:,:,k));
%Update State Error Covariance
Phat(:,:,k)=[eye(2,2)-K(:,:,k)*H(:,:,k)]*P_(:,:,k);
%Predict state, since state is x,y of a static point predicted state
%is equal currently updated state
X_(:,:,k+1)=Xhat(:,:,k);
%Predict State Error Covariance
P_(:,:,k+1)=phi*Phat(:,:,k)*phi'+Q;
%Record history of state for plotting
Xhist=[Xhist Xhat(:,:,k)];
end
%Paint the state history
hold on;
pause;
for i=2:size(Xhist,2)
text(Xhist(1,i),Xhist(2,i),sprintf('X%2.0f',i),'Co lor','red');
pause;
end
Your error is in the update of the state. The target is constant, but the observer is moving.
The update should be:
[tex]x_{k+1} = Fx_k +Gu_k[/tex]
where [tex]Gu_k[/tex] acounts for the movement of the observer.
Related to Extended Kalman Filter: Helping hand to a newbie
1. What is an Extended Kalman Filter (EKF)?
An Extended Kalman Filter (EKF) is a type of recursive Bayesian filter used in the field of control systems and signal processing. It is a mathematical algorithm that uses a series of measurements taken over time to estimate the state of a dynamic system. It is an extension of the regular Kalman Filter, which is only applicable to linear systems, to nonlinear systems.
2. How does the Extended Kalman Filter work?
The EKF works by using a state transition model and a measurement model to predict and update the state of a system. The state transition model is a set of equations that describe how the system evolves over time, while the measurement model relates the state of the system to the measurements taken. The filter uses these models to estimate the current state of the system and then updates the state as new measurements are obtained.
3. When should I use an Extended Kalman Filter?
The EKF is useful when dealing with nonlinear systems, where the state transition and measurement models are not linear. It is also useful when dealing with noisy measurements, as it takes into account the uncertainty in the measurements and provides a more accurate estimate of the system state.
4. What are the limitations of the Extended Kalman Filter?
One limitation of the EKF is that it assumes the state transition and measurement models are differentiable. This means it may not be applicable to systems that have abrupt changes or discontinuities. Additionally, the EKF relies heavily on accurate initial state estimates, so if the initial state is incorrect, the filter's performance may degrade.
5. Are there any alternatives to the Extended Kalman Filter?
Yes, there are several alternatives to the EKF, such as the Unscented Kalman Filter (UKF) and the Particle Filter (PF). These filters are better suited for handling highly nonlinear systems and do not require the assumption of differentiable models. However, they may be more computationally expensive compared to the EKF.
