Extendidng Hamilton's Principle to Non-Holonomic sytems
In summary, there is no general Nonholonomic Constrained Action Principle that extends Hamilton's Principle. However, there are alternative principles such as the Bellman Principle and Dirac's Theory of Constrained Hamiltonian Systems that can be used for non-holonomic systems, but they may have limitations and are not equivalent to Hamilton's Principle unless the constraints are integrable. Additionally, a rigorous treatment of constrained variational problems can be found in Rund and Lovelock's book, but it may be difficult to understand.
pardesi
339
Can someone explain me how to extend Hamilton's principle to non-holonomic system's thru the lagrange undetermined multipliers?
PS:Assume the system is Semi-Holonomic that is [tex]f_{\alpha}(q_{i},q_{2} \cdots q_{n} ,\dot{q_{1}}, \dot{q_{2}}, \cdots \dot{q_{n}})=0[/tex] such a equation exists for [tex]\alpha=1,2,3 \cdots m[/tex]
If by "Hamilton's Principle," you mean "the Variational Principle that Hamilton's Action is Extremized," strictly speaking, no such "Nonholonomic Constrained Action Principle" exists, except in the special case that the "nonholonomic constraints" are "integrable" --- i.e., that they are really just "disguised" holonomic constraints that have been written in an apparently non-holonomic form. (One will find a few contrary claims in a few textbooks and papers, but on careful examination, these so-called "nonholonomic variational principles" are all either ill-posed or not self-consistent unless the constraints are integrable.)
IIRC, a mathematically rigorous treatment of constrained variational problems may be found in Rund and Lovelock's https://www.amazon.com/dp/0486658406/?tag=pfamazon01-20 but it's fairly heavy going. (Or perhaps I may be thinking of Rund's "Hamilton-Jacobi Theory of the Calculus of Variations," which is sadly now out of print...)
There is a modification of Hamilton's Principle called the "Hamilton-Jacobi-Bellman Principle" (or just the "Bellman Principle" for short), that is used to formulate "Optimal Control Problems" --- including problems with non-holonomic constraints. However, the Bellman Principle is not in general equivalent to Hamilton Principle, and it does in general lead to equations of motion that are "mathematically degenerate" --- i.e., they have a nontrivial "nullspace," implying that their solutions are non-unique.
There is also Dirac's Theory of Constrained Hamilitonian Systems, but Dirac's formalism cannot be derived from a variational principle except in the special case that the constraints are integrable --- i.e., the constraints are equivalent to holonomic constraints.
Extending Hamilton's principle to non-holonomic systems involves using Lagrange undetermined multipliers to account for the non-holonomic constraints in the system. These constraints can be represented by the equations f_{\alpha}(q_{i},q_{2} \cdots q_{n} ,\dot{q_{1}}, \dot{q_{2}}, \cdots \dot{q_{n}})=0, where \alpha=1,2,3 \cdots m.
To extend Hamilton's principle, we first need to understand the concept of holonomic and non-holonomic systems. In a holonomic system, the constraints can be expressed in terms of the generalized coordinates and their derivatives. In contrast, in a non-holonomic system, the constraints cannot be expressed in this way.
Hamilton's principle states that the true path of a system is the one that minimizes the action integral, which is the difference between the kinetic and potential energy of the system. However, this principle only applies to holonomic systems. To extend it to non-holonomic systems, we need to introduce additional terms in the action integral to account for the non-holonomic constraints.
This is where Lagrange undetermined multipliers come in. These multipliers are introduced into the action integral to incorporate the non-holonomic constraints. They act as additional variables that are determined by the equations of motion of the system.
In the case of a semi-holonomic system, where the constraints can be expressed as f_{\alpha}(q_{i},q_{2} \cdots q_{n} ,\dot{q_{1}}, \dot{q_{2}}, \cdots \dot{q_{n}})=0, we can use Lagrange undetermined multipliers to modify the action integral by adding terms involving these multipliers. This modified action integral can then be minimized to obtain the equations of motion for the system.
In summary, extending Hamilton's principle to non-holonomic systems involves using Lagrange undetermined multipliers to incorporate the non-holonomic constraints into the action integral. This allows us to find the true path of the system and determine its equations of motion.
Related to Extendidng Hamilton's Principle to Non-Holonomic sytems
1. What is Hamilton's Principle and how does it relate to non-holonomic systems?
Hamilton's Principle is a fundamental principle in classical mechanics that states that the true path of a system is the one that minimizes the action integral, which is the integral of the Lagrangian over time. Non-holonomic systems are those that have constraints that cannot be expressed as simple equations of motion, and Hamilton's Principle can be extended to these systems by using the principle of virtual work.
2. What is the principle of virtual work and how does it apply to non-holonomic systems?
The principle of virtual work states that the work done by any virtual displacement of a system is equal to the change in the potential energy of the system. In non-holonomic systems, this principle can be used to derive the equations of motion by considering the virtual displacements that satisfy the constraints.
3. How do Lagrange multipliers play a role in extending Hamilton's Principle to non-holonomic systems?
Lagrange multipliers are used to incorporate constraints into the action integral in Hamilton's Principle. In non-holonomic systems, these multipliers are used to introduce the virtual displacements that satisfy the constraints, allowing us to derive the equations of motion.
4. Is it always possible to extend Hamilton's Principle to non-holonomic systems?
No, it is not always possible to extend Hamilton's Principle to non-holonomic systems. This is because the constraints in these systems may not be expressible in terms of generalized coordinates, making it difficult to incorporate them into the action integral. In some cases, alternative approaches such as Lagrange-d'Alembert Principle may be used.
5. What are some real-world applications of extending Hamilton's Principle to non-holonomic systems?
Extending Hamilton's Principle to non-holonomic systems has applications in various fields such as robotics, control systems, and mechanical engineering. For example, it can be used to model the motion of a car or a robot with rolling wheels, taking into account the constraints imposed by the wheels. It can also be used in the design of mechanical systems with complex constraints, where traditional methods may not be applicable.
  • Mechanics
  • Classical Physics
  • Classical Physics
