Extending a Continuous Function a Closed Set
In summary: So, in summary, we define a function ##g## that is equal to the original function ##f## on the closed set ##E## and uses linear interpolation on any open intervals in ##\mathbb{R} - E## to ensure continuity. This proof relies on the fact that linear functions are continuous.
Bashyboy
1,421
Let ##E## be a closed set of real numbers and ##f## a real-valued function that is defined and continuous on ##E##. Show that there exists a function ##g## defined and continuous on all of ##\Bbb{R}## such that ##f(x) = g(x)## for each ##x \in E##.
Since ##E## is closed, the set ##U = \Bbb{R} - E## must be open, which means that it can be written as a union of disjoint intervals like so: ##U = \bigcup_{i \in I} (a_i,b_i)##. Now, if ##x \in E##, simply define ##g(x) = f(x)##. However, if ##x \in U##, then there exists a ##i## such that ##x \in (a_i,b_i)##. In this case, let ##g(x) = \frac{f(b_i)-f(a_i)}{b_i-a_i}(x-a_i) + f(a_i)##. So, in other words,
$$g(x) = \begin{cases} f(x), & x \in E \\
\frac{f(b_1)-f(a_1)}{b_1-a_1}(x-a_1) + f(a_1), & x \in (a_1,b_1) \\
\frac{f(b_2)-f(a_2)}{b_2-a_2}(x-a_2) + f(a_2), & x \in (a_2,b_2) \\
\vdots & \vdots \\
\end{cases}$$
Now we prove continuity. To do this, we need only concern ourselves with the endpoints of the intervals. Take one of these intervals ##(a,b)##, and without loss of generality we will verify continuity at ##x = a##. I think only need to compute the right-hand limit (using the definition of course, but I will omit it since it is trivial). Since linear functions are continuous, the right-hand limit exists and equals the actual limit; i.e.,
$$\lim_{x \to a^+} g(x) = \frac{f(b)-f(a)}{b-a} \lim_{x \to a} (x-a) +f(a) = f(a),$$
which shows ##g## is continuous at ##x=a##.
What worries me is that left and right hand limits have not been introduced, and if they were suppose to be used, then they would be introduced, since Real Analysis by Royden and Fitzpatrick is a rigorous graduate level book. However, this is the only method of proof I could come up with. Maybe the book is presupposing knowledge of left and right handed limits. What do you think? Is there a better way to solve the problem?
I just realized that I left out the case in which one of the open intervals being is unbounded. That shouldn't be too hard though; I just make the sure the one finite endpoint 'matches up' with ##f##, as I did above.
In your write-up, you refer to ##f(a_i) ## and ##f(b_i)##. Since ##f## is only defined in ##E##, wouldn't this mean that all your points ##a_i, b_i \in E## as well?
I gather that the function you defined is sort of a 'connect the dots' sort of linear interpolation between disjoint points.
What if ##E## is a closed interval? This seems more likely since ##f## is defined to be continuous.
Yes. The ##a_i## and ##b_i## are going to be in ##E##, since the open intervals are disjoint, and so the only other place for them is in ##E##. I don't see why it's more likely that ##E## is a closed interval. Nonetheless, this case can be treated in the same way as the case where there is at least one unbounded open interval. So is my solution acceptable?
Got it. Since you didn't make that explicit in the proof, I was not following your logic. In that case, the only thing missing are the infinite endpoints. If ##\exists m \in \mathbb{E} \, s.t. \forall x \in E, x \geq m## and likewise if ##\exists M \in \mathbb{E} \, s.t. \forall x \in E, x \leq M##, then you might use any continuous function to extend the infinite tails...but your existing definition does not sufficiently describe that case.
Okay. Here is an attempt. Suppose there exists an unbounded open interval in the union ##U = \bigcup_{i \in I} (a_i,b_i)##. Then it must be either ##(-\infty, a)## or ##(a, \infty)##, or both. We will just deal with first case. In this situation, just take our function ##g## defined above and stipulate that ##g(x) = (x-a) +f(a)##, and for the rest of the open intervals that are bounded, define ##g## as I did in my first post. Clearly the left-hand limit of ##g## at ##a## is ##f(a)##, which proves continuity.
That makes sense.
Likes Bashyboy
FAQ: Extending a Continuous Function a Closed Set
What is the definition of a continuous function?
A continuous function is a mathematical function where small changes in the input result in small changes in the output. This means that the function has no sudden jumps or breaks in its graph.
What is the significance of extending a continuous function to a closed set?
Extending a continuous function to a closed set allows us to expand the domain of the function and make it defined for all points within the closed set. This can help us better understand the behavior of the function and make more accurate predictions.
How do you extend a continuous function to a closed set?
To extend a continuous function to a closed set, we use the concept of continuity, which states that a function is continuous if the limit of the function at a point is equal to the value of the function at that point. We can use this concept to determine the value of the function at the boundary points of the closed set, and then extend the function to those points.
What are some examples of extending a continuous function to a closed set?
One example is extending a polynomial function to a closed interval by using the endpoints of the interval to determine the value of the function. Another example is extending a trigonometric function to a closed set by using the periodicity of the function to determine its value at the endpoints of the set.
What are the benefits of extending a continuous function to a closed set?
Extending a continuous function to a closed set allows us to make more accurate calculations and predictions for the function. It also helps us to better understand the behavior of the function and its relationship to the closed set. Additionally, it allows us to apply the function to a wider range of inputs, which can be useful in various practical applications.
